Old 09-11-2015, 05:41 PM   #57
CSG Mike
CSG Mike's Avatar
Originally Posted by sprintamx View Post
Mike, did you find that a higher rated (or new OE clutch) was required in general for the higher boost pulley, or specifically for the pulley + E85 + track conditions?
If I've read and understood the reporting correctly, you can run the pulley on 93 octane under street conditions, but you need E85 or 100+ octane for track conditions. That's straightforward enough, but if a higher spec clutch is also a must for track conditions (or even street conditions) then I'd like to confirm this for a proper set-up.
Thanks.
It's only necessary with E85. It's also necessary with E85 with the standard pulley and most supporting mod setups.
A clutch will either hold or not hold the torque output. As a general rule, we recommend a clutch for every E85 + JRSC car, as the stock clutch will usually not last long.
sprintamx (09-11-2015)
Old 09-11-2015, 05:50 PM   #58
sprintamx
Thanks. I'm running flex fuel, a higher rate pump and 700cc injectors. I don't constantly run E85 and haven't yet felt any slippage when I do run back-to-back tanks. The highest E-rating I've recorded is about 70.
Honestly, I've been waiting for some slippage, and have been happy not to experience any yet . . .
sprintamx is offline   Reply With Quote
Old 09-11-2015, 06:36 PM   #59
CSG Mike
CSG Mike's Avatar
Reducing output via tune is always an option to prevent need a clutch
Old 09-11-2015, 08:13 PM   #60
350z
Drives: 350z
Originally Posted by ATL BRZ View Post
+1 for HBP driving videos
CSG Mike, why do you keep skipping the comments asking for videos?
350z is offline   Reply With Quote
Old 09-11-2015, 08:14 PM   #61
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Because that's not his job?
Sent from my XT1095 using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 09-11-2015, 08:15 PM   #62
350z
Drives: 350z
He drives the car doesn't he?
Old 09-11-2015, 08:16 PM   #63
DaiTT500
DaiTT500's Avatar
Drives:
Wow
DaiTT500 is online now   Reply With Quote
The Following User Says Thank You to DaiTT500 For This Useful Post:
kch (09-14-2015)
Old 09-11-2015, 08:25 PM   #64
JS + BRZ
Drives: 2010 MS3
Even I wouldn't want to make a video for people like you.
The Following 2 Users Say Thank You to JS + BRZ For This Useful Post:
KR-S (11-30-2015), ScionOfHorus (09-11-2015)
Old 09-11-2015, 08:28 PM   #65
350z
Drives: 350z
For people who want to see a product in actual use? I'm not the only one asking and I'm sure others would like to see something visual as well.
Old 09-11-2015, 08:30 PM   #66
350z
Drives: 350z
It doesn't take an hour to fulfill this request potential customers are asking for.
Old 09-11-2015, 08:32 PM   #67
juliog
juliog's Avatar
Drives: 86
There might be video(s) after the next 86CUP event on the 19th
juliog is offline   Reply With Quote
Old 09-11-2015, 08:41 PM   #68
JS + BRZ
Drives: 2010 MS3
Oooooh potential customers
clayrush (09-12-2015), ScionOfHorus (09-11-2015)
Old 09-11-2015, 09:46 PM   #69
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I thought they were just asking for track/drag videos. After all, they asked for the videos after you mentioned the amount of track time with both kits.
No need for bickering.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 09-14-2015, 02:52 PM   #70
DaiTT500
DaiTT500's Avatar
Drives:
Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release
Here's a video.
The Following 2 Users Say Thank You to DaiTT500 For This Useful Post:
Jmonty (09-16-2015), Scottemad123 (09-14-2015)
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 08:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
