Old 09-04-2015, 02:11 AM   #15
churchx
churchx's Avatar
Drives: 2014 GT86
I wonder though, if it's known that lighter pulleys/flywheel and other similar components won't change HP measurable on dyno, but will affect rpm changes over time / acceleration .. why were dyno runs performed at all instead of several drag race runs? Sure, those will be way more imprecise and with higher margin of error .. but if done many enough times, shouldn't it somewhat average/smooth out results? This particular test looks to me like choice to use scales for measuring distance or clock to measure volume.
Old 09-04-2015, 02:36 AM   #16
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I am hypothesizing that the margin of error is just part of the noise. That is, because the difference between oem and aftermarket is so small any variation will be just part of experimental error.
why? (09-04-2015)
Old 09-04-2015, 03:01 AM   #17
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, then i guess it needs to add something more for change to be bigger then experimental error. For example to not change just CP, but also lighter driveshaft/flywheel. Won't suggest lightened wheels/brake kits, as they will change not just rotational weight but also unsprung weight and thus very possibly grip. Though still, things like how good shifting was and how good start from stationary was and such will affect 0-60 times a lot. I'd rather see performed on dyno (to lessen changes by differences in grip when driven on normal road with varying surface quality) chart with rpms over time with chart segments per each gear starting/ending at specific rpm ranges to take out any gear switch variables.
Old 09-04-2015, 05:48 AM   #18
Captain Snooze
Drives: Red Herring
But then there is more than one variable so the test is no longer valid.
Given the small diameter,small width and small mass I am suggesting there is negligible benefit in a lighter crankshaft pulley. The greatest angular inertia items in the drive train (to the best of my understanding) are the flywheel and wheels. The wheels are tricky because the tyres have the greatest diameter so probably contribute most to the angular momentum.
In the test from Motoriq, who I respect but take issue with on this occasion, they are claiming a 1.37 hp difference between the Perrin and oem. This is less than 1% difference!! I am suggesting it is possible to get more than this sort of error even on exactly the same car at different times of the day due to variations in temperature, pressure and humidity.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
SPCorBUST (09-04-2015), why? (09-04-2015)
Old 09-04-2015, 05:54 AM   #19
churchx
churchx's Avatar
Drives: 2014 GT86
Spinning up (or slowing down with breaking) heavier wheels+tyres and larger diameter at that needs more energy, sure. Crank pulley/flywheel turn at higher rpms then wheels though.
Old 09-04-2015, 08:07 AM   #20
raven1231
Regardless of if they work or not the potential gain is negligible, especially for the cost.
Old 09-04-2015, 09:14 AM   #21
stugray
Drives: 2013 GBS BRZ Limited
On another thread I calculated that reducing the driveshaft weight from 30 pounds to ZERO pounds made a difference of .032 seconds in a 0-100 MPH run.
Based on the rotational energy of the shaft only.
So reducing to rotating mass of the pulley by 4 pounds would make ev en less of a difference.
Old 09-04-2015, 09:20 AM   #22
celek
Resident Gear Head
celek's Avatar
Except when you have a $2400 crank shaft and you want to protect the investment from harmonics and premature bearing wear.
celek is offline   Reply With Quote
The Following 5 Users Say Thank You to celek For This Useful Post:
ATL BRZ (10-26-2015), CSG Mike (09-04-2015), Kuri (09-04-2015), Naco (11-19-2015), Ultramaroon (09-05-2015)
Old 09-04-2015, 09:41 AM   #23
raven1231
I was talking about whether or not they're harmful, just the potential or lack of potential performance gains.
celek (09-04-2015)
Old 09-04-2015, 01:36 PM   #24
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
This is the biggest problem with this "test". They admitted they did one dyno run for each, and have almost no variation and did no other real testing. No one I have ever talked to would even try to say such a variation was due to aftermarket parts, because you could probably test all 3 pulleys all day and they each would take a turn getting the highest hp.
This is not real data, this is a paid fluff piece and nothing more.
why? is offline   Reply With Quote
Old 09-04-2015, 03:20 PM   #25
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
To me you buy one of these for peace-of-mind, if you are going to push a lot of power, rpm, or abuse the motor frequently.
It's not about making power. It's about using a high quality component as one of those little things than cumulatively add up to a less problematic setup.
uspspro is offline   Reply With Quote
The Following User Says Thank You to uspspro For This Useful Post:
Brzzee (11-09-2015)
Old 09-04-2015, 04:15 PM   #26
Slowmotion
Drives: 04.5 GLI, 01 A4 Avant, RS 1.0
Even if they only did 1 run a piece, it still is real data, they were probably just being cheap and getting the standard 3 dyno pulls for $125. They put the car on a dyno and measured it. Is it accurate real data? No.
Though, no matter how many dyno runs they do, on a rolls, your inputs to the engine are never the same so whatever average you get is a fluctuating average where this data will just wash out. Unless you can control the intake air temperature, barometric pressure, oil temperature, coolant temperature and cell temperature (there are probably a few more I'm missing) to about +/-1 deg/in-Hg of nominal and do it say, 10-20 times, The actual benefit or detriment will never be known.
Slowmotion is offline   Reply With Quote
Old 09-04-2015, 06:18 PM   #27
stugray
Actually it is a test that provides real data that agrees 100% with the predictions made by sound PHYSICS.
I dont care if you remove a 30 pound pulley and replace it with a ZERO pound magic pulley.
You still will not see a difference in horsepower on a dyno.
So I dont know what you were expecting to see.
Old 09-04-2015, 06:32 PM   #28
why?
why?'s Avatar
Drives: series.blue
I wasn't expecting to see anything. I was pointing out the reality that there are no people on the planet that I've ever talked to or read that would take 1 dyno run and even think about reporting what it said as fact.
I was also pointing out this paid review cannot be used as evidence of anything at all, because there was no real test, and there was no real comparison.
It is disingenuous at best to try and use it as proof of anything at all. It does nothing to further our knowledge base about anything.
It is real data that says there is no statistical difference whatsoever between the three pulleys and nothing more. Not data you can draw any conclusions from.
And if a person can get consistent repeatable runs on a dyno then the data can be considered valid. No one will ever be able to perfectly repeat everything, which is why 2 or 3 hp is usually considered to be no gain at all.
The Following User Says Thank You to why? For This Useful Post:
stugray (09-05-2015)
Perrin Lightweight Crank Pulley (RED) JarredH Canada Classifieds 1 08-12-2015 07:05 AM
Lightweight crank pulley Vlady Engine, Exhaust, Transmission 112 01-09-2014 09:28 PM
Lightweight Crank Pulley Vlady Want-To-Buy Requests 3 01-02-2014 11:31 AM
Perrin Lightweight Crank Pulley protpibe Engine, Exhaust, Bolt-Ons 4 12-04-2013 07:46 PM
FS: AgencyPower Lightweight Crank Pulley Firestorm_86 Engine, Exhaust, Bolt-Ons 0 11-22-2013 04:13 PM
