Old 08-28-2015, 05:30 PM   #1513
CrispyCheddar
CrispyCheddar's Avatar
Drives: the white one
Originally Posted by Bamsterman View Post
Posted in the 'Will it Fit' thread, but figured you guys might be able to help too...
I've done some research on a wheel setup and it looks like it'll "fit". I would just like to confirm and possibly get any pics of the setup, if available.
17x9 +30 245/40
Stock suspension for now, but will be lowering it soon. I know it'll poke at stock, so I might just wait till I lower it to put them on.
Thanks in advance!
I'm running 18x9 +30 with 245/35s stock suspension, no rub issues. A little pokey pokey, but I like it. Next year it'll get dialed in. -2.5 all the way around and some coils
Sent from my SM-G920V using Tapatalk
If you can't win a race, beat the person in front of you
CrispyCheddar is offline   Reply With Quote
Old 08-31-2015, 09:22 PM   #1514
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by c4lvinnn View Post
I'm on -3.2 rear camber at this height:
terrible alignment specs for running a meaty tire on the street, you won't even use 1/4 of it then.
Jive Turkey is offline   Reply With Quote
Old 08-31-2015, 10:39 PM   #1515
c4lvinnn
Drives: Toyobaruion
Yeah well you can run whatever the hell you want on your own car lol
c4lvinnn is offline   Reply With Quote
The Following 3 Users Say Thank You to c4lvinnn For This Useful Post:
chas3wba0 (09-17-2015), Higher Being (10-11-2015), mmmcambelsoup (09-18-2015)
Old 09-01-2015, 01:05 AM   #1516
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
lol this is true.
Also, I don't think 3.2 is excessive camber by any means. If you're running 0 camber all around, it just means you aren't gripping as well in the corners.
I'm at -2.5 all around (265/295) and my contact patch is fine, thank you
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 09-01-2015, 02:38 PM   #1517
Bamsterman
Drives: 13' Scion FRS
What would you recommend?
Bamsterman is offline   Reply With Quote
Old 09-01-2015, 05:34 PM   #1518
c4lvinnn
Drives: Toyobaruion
Probably what he personally runs which by the first page he runs -1.7 rear.
I have a whole 1.5 degrees more. Oh noessssssss
Old 09-01-2015, 05:42 PM   #1519
CrispyCheddar
I don't solely use this beast of track car on the street. I think -2.5 is fairly mild actually. I track and autox. I thought it'd be a happy medium for street and track.
What is your opinion on a good alignment spec?
CC
Old 09-01-2015, 10:21 PM   #1520
s2d4
s2d4's Avatar
While there are worse things people do, I do agree with him that is on the excessive side for mostly straight line day to day traffic.
Old 09-01-2015, 10:34 PM   #1521
c4lvinnn
Drives: Toyobaruion
Why? ...and dont say tire wear.
Old 09-01-2015, 11:33 PM   #1522
s2d4
s2d4's Avatar
So, why is your setup better?
Old 09-02-2015, 09:19 AM   #1523
c4lvinnn
Drives: Toyobaruion
Why would I answer that when you or Jive have a technical response to the original comment?
This is the meaty tire thread not the bitch about and say how "excessive" or "terrible" a whole 2.5 or 3.2 rear camber is.
Old 09-04-2015, 01:43 PM   #1524
Jive Turkey
the tuna, no crust.
no need for that attitude.
And yes, tire wear does have something to do with it. My RE11 at the end of their life had pretty noticeable camber wear and I rotated them often and i'm always checking pressures. If majority of what you do is street driving then you will for sure see it wear unevenly with that much camber. Mind you I was only running -1.8 in the rear.
Running camber in the front is one thing, the rear is another.
May I ask what your toe specs are?
What suspension do you run?
Right now i'm running -1.6 in the rear..08 toe in per side. -1.9 in the front with slight to out.
my favorite setup was when the front was at -2.2 slightly toe out, rear at -1.8 toe in a bit. car turned in so nicely.
The Following User Says Thank You to Jive Turkey For This Useful Post:
Hicklinc (02-25-2018)
Old 09-04-2015, 02:08 PM   #1525
c4lvinnn
Drives: Toyobaruion
Attitude? You're the one who called two people's specs out and said they were "terrible." My brash attitude is along the same lines as yours.
BC Coilovers. 0.08 toe in as well, -3.5* front camber with toe at 0.
This isn't my first rodeo with camber. I used to run -6.4* (natural from just the drop) on a double wishbone front suspension and drove that like a madman. Rears were around -4.5. Tires lasted me 10-12k miles. Completely negligible to me so don't use tire wear as an explanation as this is less than half of that specific set up. Oh and that was with 360 treadwear which isn't much...
My car is very reactive to input which I want and has no negative effects, no squirelly, no unstable high speeds from toe or camber, etc.
Does everyone forget that toe kills tires, not camber?
Old 09-04-2015, 11:10 PM   #1526
s2d4
s2d4's Avatar
There is more to it than what you think you know, and yes it is because of the attitude that I cbf to participate in further discussions with you.
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
