#295 |
Turbo E85
Drives: 13 wrb brz
we wait a couple months between DIY days due to people obviously need $ to collect parts and then we can get started but.. it should be close to another DIY day.
Flex Fuel Turbo BRZ
| The Following User Says Thank You to BRZtoni For This Useful Post: | V_86 (08-27-2015) |
#296 |
WtsTofu
Drives: Ultramarine fr-s
I need to paint and install some bayson r rear spats that has fitment issues, wrap my dash, install my dashcam, and splice and dice my hids into my spec d head lights.... everything came on the same day and i don't know where to start lol
#297 |
Drives: 2014 FR-S Monogram, Whiteout 6MT
Let's wrap at AU! I'm going to wrap my sub and interior trim soon.
2007 Honda CBR600RR-Pearl White/Silver - Totaled ![]() 2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build) φφκα |
| The Following User Says Thank You to LXXXV1 For This Useful Post: | Vincenttam (08-29-2015) |
#298 |
WtsTofu
#299 |
Drives: 2015 Subaru BRZ
Anybody have any tips for fixing an exhaust leak? I've tried to reposition the pipes but it's still there. Might need to show up to the next meetup to get that fixed.
#300 |
Did you use new gaskets and/or torque everything down correctly?
#301 |
#302 |
Can you isolate the source of the leak? Like which pipe/end?
#303 |
It sounds like it's the front pipe to over pipe connection. I installed a header last week and one side of the gasket (op to fp) was black. If it helps all the pipes are aftermarket except for the over pipe.
#304 | |
Drives: Scion FR-S 10 Series #2263
When exhaust is cool to touch, brush/spray some soap/water mix onto the connection and start up the car. Bubbles = bad. If it is the OP/FP connection, I would guess either the FP/OP flanges aren't flat or the FP wasn't aligned just right. If the flanges are flat, try snugging up the OP/FP bolts first, before the FP/midpipe, then the FP hanger? |
| The Following User Says Thank You to aegisdrgn For This Useful Post: | VIC_BRZ (08-31-2015) |
#305 | |
#306 |
If they aren't flat, depending on how bent they are, you might be able to get away with a different gasket, but it'll probably be less of a headache to get it straightened by the shop.
#307 |
Drives: 2015 Asphalt FR-S
So I'm installing exhaust in the next couple weeks (used TRD). I ordered a new midpipe to to muffler OEM gasket, and I'll be reusing the front to midpipe donut gasket. Anything I'm missing?
Also, I know the front to midpipe should be torqued to 14.3, but what is the specs for the midpipe to muffler? Last edited by V_86; 09-01-2015 at 04:09 PM. |
#308 | |
http://www.trdsparks.com/install/PTR03-18131inst.pdf Make sure it comes with the 3 bolts/nuts. Removing the exhaust brackets may be a pain in the ass if you don't have the tool, unless you have strong fore arms. Also, fitting a torque wrench for midpipe to muffler will be difficult due to poor design. Good luck. Pretty straight forward bolt on/off. I reused both my OEM gaskets, but I only had 1500 miles before I swapped. No leaks so far.
