#15 | |
Add lightness!
Drives: 17' WRX
That's worth repeating. Good ol' foot control! A whole generation of evo/wrx/sti drivers have been ruined by awd driving dynamics. |
| The Following User Says Thank You to industrial For This Useful Post: | EN2_Squirrel (08-29-2015) |
#16 |
Drives: 2014 BRZ
To be clear, I'm talking about lap times on a track.
Yes, I agree about the right foot control, but when one adds a considerable amount of power to a particular chassis, you potentially run into the issue of no being able to put the power down in a way that actually gets the car out of the turn any faster than with the lower power variant. Usually what I see happen is that one cannot fit a wide enough tire in the back to take full advantage of the power. I should have been more clear. My question is whether or not you can fully take advantage of the added power. My gut says that one needs wider than 255 rear tires and that's what I'm trying to understand. While I understand that skinny tires (225s) are best for fastest lap with an NA car, but it is not intuitively obvious how that would be true even for a "regular" 300HP JRSC car. Surely, with 300HP, you'd see faster times on wider tires and even wider, at least in the rear, for the high power version. So, yeah, color me confused. PS - My "standard" JRSC is being installed in a month so will get a chance to see how I am able to put the power down out of corners shortly... Thx @CSG Mike for all the JRSC info in the past; pushed me in that direction
#17 | |
Drives: GT86-ACE-JRZ-RPF1-Essex
If the street car is fast on a racetrack, the tire size should not be too far off. Like civic type R at 235mm for 320hp FWD. You could look at Cayman gt4 and Exige V6 tire size.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
| The Following User Says Thank You to MaximeT For This Useful Post: | EN2_Squirrel (08-29-2015) |
#18 | |
Drives: 2014 BRZ
#19 | |
That Guy
Drives: 2013 asphalt FRS MT
#20 | |
At Buttonwillow, which is the track we use as our benchmark, only approximately half of the corners are grip limited, and changing to a HB pulley only changes one power limited corner to a grip limited corner, so the skinnier tire still remains faster. Adding additional rotational mass to change that one grip limited corner to a power limited corner, at the cost of slowing the car down at every other power limited corner, still yields a slower net lap time. |
#21 |
Drives: FRS
All this is awesome news. I think going to buy my flex fuel kit and then supercharger to install same time. Hopeful this December or January can buy these.
| The Following User Says Thank You to Evil Rocky For This Useful Post: | CSG Mike (08-29-2015) |
#22 |
Drives: 13 WRB BRZ
If I already have a JRSC and I want to add this on with a 93oct tune are there any more supporting mods I need to get other than the fuel pump, injectors? How bad of a drop can I expect in mpg?
#23 | |
You'll need a custom tune as well. |
#24 |
Drives: 13 WRB BRZ
interesting, what about with e85? Can the stock engine handle that much power? Can I run this set up with stock exhaust? I dont care about being loud, all I have is a catback.
edit- I would get the flex fuel kit for e85 |
#25 | |
We can package all that together for you. |
#26 |
Drives: Will see
Hey Mike, i only have 91 octane in my area, would be posible to run safety the high boost polley on stock engine using Water and Methanol Ijection? do you know if someone does and which numbers did he get?
Thanks! |
| Jackson Racing SC Kit - C30-94 Rotrex Supercharger High Boost Pulley Release | CounterSpace Garage | Forced Induction | 313 | 03-08-2021 08:39 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Why no high rpm boost for Phantom ESC? | stevo585 | Forced Induction | 11 | 02-11-2014 08:51 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
