Old 08-27-2015, 07:16 PM   #15
SteveIsBored
Drives: 2013 subaru brz
What are your IATs when all of this is happening? You could have knock correction plus high IAT correction, this could all be causing high egts. My knowledge is limited but I was logging similar performance issues when running crap 91 with high IATs
SteveIsBored is offline   Reply With Quote
Old 08-27-2015, 08:14 PM   #16
ztan
Drives: Toyota 86
Originally Posted by yomny View Post
I noticed the yoyo timing.. I have a log I did today and I get correction up to -3 and then addition, not back to back but fairly close in the event. I'll see if I could post some logs or something to show what im trying to explain as my tuning vocabulary is very limited. I didn't understand the part about load limits.
What puzzles me is that is not constant or always, just at times. That's why I initially thought it was a temperature thing.
Your help is very appreciated.
Timing map is suspect if you're pulling 3 degrees under load.
Also, what port injectors are you running and how have they been balanced with the DI system? When I switched injectors, it took me a while to sort out the areas where the PI system turned on, but operated in a non-linear range - have you logged PI and DI pulses and to see if the hesitation occurs with switchover?
ztan is offline   Reply With Quote
Old 08-27-2015, 08:20 PM   #17
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Im running stock fuel system for now, seems to be ok for 10psi of 93 oct. Never really logged the PI and DI pulses.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 08-27-2015, 08:25 PM   #18
yomny
yomny's Avatar
My IAT were 98F max, low 93F it must have been around 90F outside and i dont have any source of cold intake.
Old 08-27-2015, 08:28 PM   #19
yomny
yomny's Avatar
Trying to attach a few logs I've taken.. see if anyone could check out. These are all city drives with the "morning" one having a lot of idle time as i sat in traffic and the rest have some mild throttle applied.
Old 08-27-2015, 08:30 PM   #20
steve99
Drives: FT86
load limit tables look like this
yomny (08-28-2015)
Old 08-27-2015, 08:50 PM   #21
cjd
cjd's Avatar
Drives: 2017 BRZ
Just to be sure, this happens with A/C off? Maybe you said and I missed it...
Stock, A/C definitely sucks away power.
Old 08-27-2015, 09:05 PM   #22
ztan
Drives: Toyota 86
You've got DI and PI pulses on the log - if you're stock, you shouldn't have too many transitional issues.
Your logged IAM = 0.2!! and still has (-ve) corrections. You'll need a better tune or fuel. With that IAM value, you'll be running much more of the Base timing table A (as defined in RomRaider) than Base Timing B (which is what most of the tuners adjust as it affects timing when IAM = 1.0).
The Following User Says Thank You to ztan For This Useful Post:
yomny (08-28-2015)
Old 08-27-2015, 09:43 PM   #23
steve99
Drives: FT86
yep just saw that iam looks pretty ordinary if he is running correct fuel for tune.
side issue do you know the parameters the ecu uses to determine the base timing b to a switching or transition.
i know it runs base b plus knock correction max a when iam is 1
so at what point does the transition occurr to base a plus i assume knock correction max a to determine overall base timing plus offsets due temp iat ect ?
Old 08-27-2015, 09:58 PM   #24
ztan
Drives: Toyota 86
Grossly, what I recall from looking at the disassembly, the IAM acts as an interpolation value between tables B and A:
Base timing = IAM*(Base timing B) + (1-IAM)*(Base Timing A)
IAM*KCA is added to this and then corrections are made to get a final timing value
Ignore above...
I was thinking of Primary OL fuel table which progressively adds in fuel from the OL additive table based on IAM.
Just had a look at the dissassembly again and Base Timing tables do not have an obvious IAM modification. The Base Timing A and B tables in A01G are interpolated based on a value stored at FFF8ADB8 - this logs at 1.0 during normal operation (full Base_Timing_B map), and 0.0 (full Base_Timing_A) at startup and shutdown.
The Following 2 Users Say Thank You to ztan For This Useful Post:
s2d4 (08-28-2015), steve99 (08-27-2015)
Old 08-27-2015, 10:29 PM   #25
VitViper
Drives: '15 FRS
Was this done on a dyno? From those logs and how super low the timing is, one can make the assumption you're either running 87 octane fuel or there's something in your engine bay making a ton of racket and making the knock sensor go crazy. The timing map is in various spots makes one wonder. The IAM being super low is a result of the knock sensor feedback -- although it may not mean much as you can tune the timing maps to shift very little if none at all due to the IAM.
You're also seeing stoich AFR's while making boost, and you really should be seeing some enrichment when boost comes in -- the leaner AFR in boost will cause cylinder temps to shoot up which can cause some detonation.
VitViper is offline   Reply With Quote
Old 08-28-2015, 05:21 AM   #26
s2d4
s2d4's Avatar
Considering you have wideband, why aren't you running full closed loop?
Enrichment on throttle as well as boost should be there as mentioned.
I will not be loading your car at all with IAM that low, putt around and make sure you have fuel side sorted by getting better fuel to eliminate it from the equation. If it's still happening, you need to get your tuner to do something.
Old 08-28-2015, 06:42 AM   #27
Kodename47
Kodename47's Avatar
Drives: UK GT86
at what point does the transition occur to base a
Base A is when the AVCS isn't operational, so when the car is in it's warmup phase
If it's ECUtek, could there be an issue with the hybrid SD? This would be impossible to determine by logs alone though as you would need to see how it's setup.
FWIW, I haven't looked at the logs as it seems you have that covered above.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-28-2015, 06:51 AM   #28
steve99
Drives: FT86
here is an easier to read log from yommy
http://datazap.me/u/steve99/log-1440...-35-39&solo=33
side issue :-)
so your saying base timing A only get used at startup or limp mode and never used after that, ie their is no interpolation from B to A when IAM drops
CDC Autocross - Behavior echan Mid-Atlantic 14 06-19-2014 05:48 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Alarming nanny behavior mid_life_crisis Engine, Exhaust, Transmission 52 03-03-2014 11:56 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Visconti Tuning - Latest Forced Induction Tuning Info Visconti Forced Induction 340 04-30-2013 07:33 PM
