Old 08-24-2015, 01:33 AM   #1
soundman414
Drives: 2014 Silver BRZ Limited
Thoughts - JL Audio MicroSub in rear speaker spots
I have been thinking about how hard/easy it would be to incorporate one of JL Audio's MicroSub's into the rear speaker areas and having the sub speaker meet up to the existing speaker grill in the car panel.
If it would fit and I could fab a way of attaching it to existing points, it could be great for getting bass and keeping ALL the trunk space.
Thoughts on viability or is it more headache than it's worth and should just give up some trunk space?
http://www.jlaudio.com/car-audio-sale-subwoofer-systems
P.S. I'm at the planning phase and will be replacing the head unit, stand alone multichannel amp, component speaker system upfront. Just wondering if I should be deleting the back channels for microsubs, or go bigger sub in trunk and keep back two channels...
soundman414 is offline   Reply With Quote
Old 08-24-2015, 01:50 AM   #2
Chimera
Drives: FRS
You can fit some 8" back there.. The enclosure will be a challenge for certain
Old 08-25-2015, 12:07 PM   #3
mid_life_crisis
Drives: FR-S 10 #103 AT
This car really makes me wish I had fiberglassing skills.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-28-2015, 01:48 PM   #4
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
After looking at the giant cavity around the rear speakers when I did my car stereo, I wondered why a vendor didn't design a box to go there. There is a lot of room, it's just an oddly shaped space.
industrial is offline   Reply With Quote
Old 08-28-2015, 02:48 PM   #5
TOOSTUBBORN2FAIL
Drives: Specialized Hardrock
Delete the two rear speakers no matter what, they are pretty much useless.
If you want the most output, you'll likely get it from a wheel well mounted box in the trunk, not inside the cabin. This seems counter intuitive, but I've seen it happen over and over in all kinds of different cars.
That said, the rear side panel would like have a smoother response curve.
TOOSTUBBORN2FAIL is offline   Reply With Quote
Old 08-30-2015, 11:22 PM   #6
soundman414
My biggest goal is to retain all the trunk space. I use it on a weekly basis and almost every inch, for stuff when washing the car, going to the store, etc.
This is why I would like to utilize the back seat area for bass.
Old 08-31-2015, 01:25 AM   #7
TOOSTUBBORN2FAIL
It could be done with a fiberglass enclosure, and have pretty good response. Unlikely the microsub enclosure would fit behind the panel.
Old 08-31-2015, 10:30 AM   #8
soundman414
So find a custom faber and ask them for a quote.
Any idea on how much things like that cost?
Old 08-31-2015, 03:50 PM   #9
TOOSTUBBORN2FAIL
Honestly, not cheap. If it's hidden behind the panel, it might not be as bad as it doesn't have to be finished. But for example, a pair of sealed mid enclosures for a door generally cost over $2000 a pair for a nice looking finished product.
Old 08-31-2015, 06:45 PM   #10
soundman414
2-3 square feet of saved trunk space isn't worth that much to me.
Maybe I can look into getting the cavity 3D scanned and 3D printed.
Old 08-31-2015, 11:37 PM   #11
TOOSTUBBORN2FAIL
There's actually a car audio guy that's been building small bandpass boxes using a 3d printer, but his printers not big enough for that area. I had him 3d print the fluid tonearm damper for my turntable.
Old 09-04-2015, 04:41 PM   #12
mid_life_crisis
I've got a couple of JL Audio 6" subs new in box that I bought years ago for a project and never used. I wish to hell I could fiberglass worth a damn because they would be perfect back there.
I currently have a 10" in a box that just takes up way too much space. Sounds great, but I really miss my trunk.
Old 09-04-2015, 05:07 PM   #13
DAEMANO
Time Traveller
A couple/three owners pulled this off in this thread with subs up to 10" IIRC.
http://www.ft86club.com/forums/showthread.php?t=66561
It was a lot of work.
Old 09-05-2015, 03:59 PM   #14
toast
Drives: 14 BSP Edelbrock BRZ
That is my pic, and yeah, it was a lot of work. In the end it sounded fine, nice even, but then I made the mistake of putting my fiberglass enclosure for the spare tire well from my STI in there. Just SO much more when placed in the trunk. Some of it is the proximity to the driver and the frequencies involved - you just aren't far enough away and that location doesn't couple to the interior very well.
If you insist on doing it I will give you my enclosure for the price of shipping. It would be good if someone got something out of it.
toast is offline   Reply With Quote
The Following User Says Thank You to toast For This Useful Post:
DAEMANO (09-10-2015)
Dash and rear speaker recommendations B-R-Z Electronics | Audio | NAV | Infotainment 64 06-05-2016 08:08 PM
sub in the rear speaker location aznatama Electronics | Audio | NAV | Infotainment 4 11-07-2014 06:18 PM
Subaru Audio door speaker adapters JoeBoxer Audio/Visual, Electronics, Infotainment, NAV 0 12-17-2012 12:13 AM
Bespoke Audio Thoughts Dang Lad Electronics | Audio | NAV | Infotainment 19 07-17-2012 04:23 AM
Thoughts on ease of speaker replacement? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 36 11-29-2011 12:16 PM
