#29 |
Drives: 2013 FRS Whiteout
Yeah I never did think it was supposed to be that way but a couple of other locals told me their 6 puck behaves similarly. Then again I don't have a six puck. I got the first gear to misbehave yesterday and when trying to shift into the others straight out from 1st, the rest went it smoother and improved as I kept going through them, weird. I'll pull this out eventually and will see what's going on. I know for sure a mild clutch shouldn't be behaving like this. It certainly isn't as hot as after completing a few hot laps or drag racing, it's just city traffic and no longer than 1 hr drive.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#30 |
Wouldn't a warping cause the behavior to be constant as with a brake rotor?
#31 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Just installed this clutch too...should I adjudt my pedal before driving it?
797Performance.com
#32 | |
A hot spot on the flywheel is more analogous to a warped rotor. That's permanent.
#33 | |
If that distance changes between hot and cold conditions, something is warping.
#34 |
I think then something's warped because without doing this I know my engagement point is very different when cold vs hot. I'd say about 1/2 to 3/4". So basically the clutch is crap lol, I wouldn't mind changing it if I knew that's the problem. I guess I have to find a decent shop and just check for stuff. Really appreciate your help man.
#35 |
I need your help, more than before, now lol. Something's definitely not right, wanted see what my options were in case I need to replace the clutch disk, pressure plate or flywheel. I was looking at the South bend clutch but not sure if my ACT streelite FW would work with it, don't know anything preventing it but, they may work better with steel flywheels. Exedy, im a little confused, everyone says Stg 1, is that the OEM replacement clutch, as I can't find anything but the OEM, and is that good for low boost? Don't really want to spend over 700 but then I guess if I have to I'll push myself, maybe the price point of my ACT is what is giving me these issues now. I'll be taking it in to see what could be my problem and possibly replacing the parts but I didn't want to stick to ACT giving my current experience. Any input would really save this guy a lot sleep deprivation and headaches
@Ultramaroon @cividrivr
#36 | |
I'd go for a drive and see where the engagement point is.. I think the pedal coming from the floor up, it should be about 3" from it or so but this is subjective and you may like it to engage closer to the floor.
#37 | |
Someone else will chime in and tell me I'm full of shit, tho. @civicdrivr?
#38 |
Drives: Late 2014 Subaru BRZ
Hey this sounds really dumb. Jack the rear end of your car up. Check all your transmission mounts, and your drive shaft mount. Make sure they're tight. That's free
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#39 |
Junior
Drives: a car
Youre full of shit.
#40 |
#41 |
Lol well my stock clutch held up but not really much, started to slip at 9psi.
#42 | |
| Clutch engagement issue. Possible clutch cylinders upgrade? | wu_dot_com | Engine, Exhaust, Transmission | 42 | 04-05-2016 12:11 PM |
| Windows, Tranny, Clutch, Rattles | Chalk | Issues | Warranty | Recalls / TSB | 7 | 06-30-2015 02:48 AM |
| Windows, Tranny/clutch, dealer issues. Help! | Chalk | Issues | Warranty | Recalls / TSB | 9 | 02-15-2015 03:11 PM |
| Need your expertise(clutch and tranny) | WatchmaN | Issues | Warranty | Recalls / TSB | 18 | 12-31-2014 08:32 AM |
| clutch issue | yurgirlishot | Issues | Warranty | Recalls / TSB | 14 | 11-15-2013 04:20 PM |
