Old 08-07-2015, 07:28 PM   #1
ztan
Drives: Toyota 86
Open source Over Boost Fuel Cut
***Use at your own risk.***
This implementation hijacks the speed limiting fuel cut routine and assesses MAP instead of vehicle speed.
Defined for A00G/A01G ROM: a single value in the speed limiting fuel cut routine is changed (from 0x58 to 0x5A) to get MAP loaded instead of speed and MAP limits are entered in place of speed limits. To clarify, no additional patch is needed for this modification besides the single value switch in the code - thanks to Subaru engineers who just lifted the speed limit rather than write new code.
Defs and test log with 1.35 Bar cut limit and 4400 RPM active.
First ramp showing MAP > 1.35, RPM < 4400: No fuel cut.
Second ramp showing MAP > 1.35, fuel cut when RPM hits 4400.
Third ramp showing RPM > 4400, fuel cut when MAP hits 1.35.
This is a neck-snapping hard fuel cut, but probably better than a blown engine due to major overboost. Haven't done extensive testing and you'll lose your speed limiter fuel cut if you apply this (default set to fuel cut over 500 km/h).
Def for A00G/A01G:
Code:
    <table name="Boost Limit (Fuel Cut) enable" storageaddress="66831" />
    <table name="Boost Limit (Fuel Cut)" storageaddress="10C540" />
    <table name="Boost Limit (Fuel Cut) Resume" storageaddress="10C550" />
    <table name="Boost Limit (RPM) Active" storageaddress="10C554" />
<!--<table name="Speed Limiting Enable (Fuel Cut)" storageaddress="10C540" />
    <table name="Speed Limiting Disable (Fuel Cut)" storageaddress="10C548" />
<table type="Switch" name="Boost Limit (Fuel Cut) enable" category="Miscellaneous - Limits" sizey="1">
      <description>Enable Boost Limit (Fuel Cut)</description>
      <state name="Enabled" data="5A" />
      <state name="Stock ROM" data="58" />
</table>
<table type="2D" name="Boost Limit (Fuel Cut)" category="Miscellaneous - Limits" storagetype="float" endian="little" sizey="4" userlevel="4">
      <scaling units="Manifold Abs Pressure Bar" expression="x*.001333224" to_byte="x/.001333224" format="#0.000" fineincrement=".001" coarseincrement="0.01" />
      <table type="Static Y Axis" name="Boost Limit Fuel Cut" sizey="4">
        <data>On Above</data>
        <data>Off Below</data>
    </table>
          <description>These are the MAP values at which the boost limiter is engaged and disengaged. When engine speed is equal to or exceeds the 'On' value, fuel cut is active, after which, if engine speed drops below the 'Off' value, fueling is resumed.</description>
    </table>
<table type="2D" name="Boost Limit (Fuel Cut) Resume" category="Miscellaneous - Limits" storagetype="float" endian="little" sizey="1" userlevel="4">
      <table type="Static Y Axis" name="Boost Limit Fuel Resume (MAP)" sizey="1">
        <data>Below</data>
      </table>
      <description>After the boost limiter is engaged and engine speed drops below the 'Off' RPM, fueling will not resume until manifold pressure drops below this table's value.</description>
      </table>
<table type="2D" name="Boost Limit (RPM) Active" category="Miscellaneous - Limits" storagetype="float" endian="little" sizey="1" userlevel="4">
      <scaling units="Engine Speed (RPM)" expression="x" to_byte="x" format="#" fineincrement="50" coarseincrement="100" />
      <table type="Static Y Axis" name="Boost Limit Active over" sizey="1">
        <data>Over</data>
      </table>
      <description>The boost limiter is active over this RPM</description>
      </table>
ztan is offline   Reply With Quote
The Following 15 Users Say Thank You to ztan For This Useful Post:
504 (08-09-2015), 86drift (08-10-2015), aagun (08-08-2015), BRZ Fanboi (09-10-2015), callisto (02-15-2026), carlitosway6891 (08-13-2015), FrX (08-13-2015), makinen (01-06-2018), qoncept (04-27-2016), Shiv@Openflash (08-08-2015), Sportsguy83 (04-27-2016), steve99 (08-08-2015), Td-d (10-04-2015), Wayno (08-08-2015), Yobiwan (09-29-2018)
Old 08-07-2015, 08:15 PM   #2
ztan
Drives: Toyota 86
Just realized that I set my cut and resume values the wrong way around during that test and in the above example, cut would be > 1.3 Bar with resume < 1.35 Bar (no hysteresis with values set as above).
Old 08-08-2015, 02:33 AM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Defined for A01G ROM: a single value in the speed limiting fuel cut routine is changed (from 0x58 to 0x5A) to get MAP loaded instead of speed and MAP limits are entered in place of speed limits.
Def for A01G:
Code:
</table>
    </table>
    </table>
        <data>Below</data>
      </table>
      </table>
        <data>Over</data>
      </table>
      </table>
Fantastic work!
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
raven1231 (08-09-2015)
Old 08-08-2015, 10:17 PM   #4
Shiv@Openflash
Drives: 2013 FRS
You have email
Old 08-09-2015, 05:32 AM   #5
ztan
Drives: Toyota 86
I've sent Shiv addresses for OFT_B01C ROM to test (only for OFT 2.xx ROMs). If anyone else with FI running A00C or A01C ROM wants some addresses to test before general release, get in touch with me.
Also note above that I have defined MAP pressure for fuel cut rather than boost (MRP) pressure. Just so no-one gets ideas of running at 1.3 Bar Boost = 19psi Boost, I did my testing on low boost: 1.3 Bar MAP = 0.3 Bar Boost = 4.35 psi Boost.
The Following User Says Thank You to ztan For This Useful Post:
Shiv@Openflash (08-09-2015)
Old 08-09-2015, 01:41 PM   #6
Shiv@Openflash
Drives: 2013 FRS
Thank ztan, I'll be testing in our turbo car on Monday. Once again, fantastic work and big kudos on your desire to contribute to the open source community
Old 08-13-2015, 09:30 AM   #7
ztan
Drives: Toyota 86
Shiv: thanks for the recommendation.
Old 08-13-2015, 12:32 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Nice! That's all my wife's doing. I haven't been to India in 10+ years! Have a great time
Old 08-20-2015, 08:44 PM   #9
Shiv@Openflash
Drives: 2013 FRS
ztan knocked it out of the park. I just tested his update in our turbo FRS and it works beautifully. So beautifully, that I'll be adding it to all OFT350 customer tunes. In the datalog below, I have the boost cut to set to 9psi:
http://datazap.me/u/shivvishnu/oft-z...=0&data=2-9-13
Great work ztan. The community appreciates it!
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
BRZ Fanboi (09-11-2015), DustinS (08-24-2015), Hagbard (08-24-2015), rickjames (08-22-2015), ztan (08-21-2015)
Old 08-24-2015, 04:19 AM   #10
ztan
Drives: Toyota 86
For those of you on B01C, this is what I sent to Shiv:
Note that I have set this .xml description to "boost" pressure in psi over atmospheric. Use the descriptor at the top of the post if you work in absolute Bar.
B01C:
Code:
    <table name="Boost Limit (Fuel Cut) enable" storageaddress="69171" />
    <table name="Boost Limit (Fuel Cut)" storageaddress="10E5EC" />
    <table name="Boost Limit (Fuel Cut) Resume" storageaddress="10E5FC" />
    <table name="Boost Limit (RPM) Active" storageaddress="10E600" />
    </table>
      <scaling units="Manifold Pressure (psi relative sea level)" expression="(x-760)*.01933677" to_byte="(x/.01933677)+760" format="#0.00" fineincrement=".01" coarseincrement=".5" />
    </table>
    </table>
        <data>Below</data>
      </table>
      </table>
        <data>Over</data>
      </table>
      </table>
Old 09-04-2015, 09:19 PM   #11
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
this is great im going to need to add this to the sbd tune. would the same codes work on a A00c rom?
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 09-05-2015, 04:38 AM   #12
ztan
Drives: Toyota 86
I don't think so, but I haven't checked A00C.
Send me a PM and we can work on pulling them for A00C.
Old 09-09-2015, 07:44 PM   #13
ztan
Drives: Toyota 86
Pulled on Grip Ronin's request for A00C/A01C, no feedback yet.
Can someone test and report on the following if you have FI and A00C or A01C (use one of the two .xml descriptors above):
Code:
<table name="Boost Limit (Fuel Cut) enable" storageaddress="68F71" />
<table name="Boost Limit (Fuel Cut)" storageaddress="10E600" />
<table name="Boost Limit (Fuel Cut) Resume" storageaddress="10E610" />
<table name="Boost Limit (RPM) Active" storageaddress="10E614" />
Old 10-04-2015, 01:54 PM   #14
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Code:
ya turbos still in my living room. just finished porting the turbine housing and wg. still weeks away from install lol.
IG-Joey_Soul
Open source Hybrid Speed Density ztan Software Tuning 57 07-05-2023 08:33 AM
Open Source Electric Supercharger neutron256 Forced Induction 913 08-22-2021 05:16 PM
open source software question GeeTee86 AFRICA 15 02-15-2015 06:52 PM
The Retrofit Source summer open house! soundman98 Southeast 0 06-23-2014 08:41 PM
FA20 Fuel lean at high boost fix cf6mech Forced Induction 15 05-20-2013 03:33 PM
