Old 08-21-2015, 01:56 PM   #29
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
A CARB JRSC will walk:
- Stock EVO
- Stock 350Z/370z
- Stock WRX/STI
- Stock Focus ST
It is about even with:
- bolted EVO on pump
- Flashed/bolted 370z
- fully bolted STI on pump
- Fully bolted ST
- E9x M3
It will lose to:
- Any factory FI car on E85
- F80
it's partially true Mike, I've driven/owned almost all the cars you mentioned above (except Focus ST ,or the E9X M3s).. roll from 30-40 mph you have some window to keep up with those cars but as soon as you shift the cars you mentioned will start walking away for multiple reasons:
  • advantage of the power/weight ratio will diminish (talking about highway pulls of course) after certain speed say about after 70-80mph since after that HP will start make up for the difference and after 100mph more powerful car will almost always walk away (opposite can be said for the lighter cars at the tracks with tight corners, if we think about it; Lotus Elise doesn't really have a good Power/weight ratio compared to big dogs.. say for instance than a Challenger Hellcat, but it will possibly kill many of them on a tight/medium track since weight advantage overcomes the other disadvantages regardless of the power/weight ratio)
  • gearing advantage in stock form slightly becomes a disadvantage with the added power, if the boosted BRZ/FRS makes more than 300whp having a slightly taller tires might be good way of cheating if taller gears is not an option
  • OEM power (especially in NA form) is a lot healthier and more repeatable so after a couple of pulls car with an aftermarket FI kit will start losing power due to overheating (even with the best cooling methods), of course Rotrex kits still has the upper hand compared to turbo (since heat soak is not an issue like a turbo) on that department but still subject to the shortcomings I mentioned above
with all that said, with a proper cooling and supporting mods, Rotrex SC'd FRS/BRZ still has a huge advantage on a track but not proportionally with the power it makes on a dyno since real world power will suffer from..this is just another example of the power on paper and power on real world conditions
glamcem is offline   Reply With Quote
Old 08-21-2015, 02:21 PM   #30
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Damnit....so what do I do now? Edelbrock, JRSC, or sell for an E92 M3 like was about to?
lol, thanks.
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
Old 08-21-2015, 02:33 PM   #31
glamcem
glamcem's Avatar
lol, thanks.
depends on your goals:
  • if you're like me; appreciate almost every aspects of the the car (lighweight, lower center gravity, handling, practicality, mpg etc.. ) especially for having fun at track days but find it very boring due to lack of power, you're options are limited IMO, Rotrex based kits (JR or KW)
  • if you like everything above but prefer more low end torque and not planning to attend track days as much (it would be a shame with this car IMHO) Cosworth Supercharger may be good option..then again it will generate a lot more heat at the track (thanks to a water intercooled system) and only handle mild track use and also not sure if it's worth the added cost
  • if you like really fast car on highway, pulls, 1/4 mile ..etc (I am not saying quick car) you probably got the wrong car and your best bet is to consider other alternatives..
The Following User Says Thank You to glamcem For This Useful Post:
ck-GT86 (08-21-2015)
Old 08-21-2015, 02:37 PM   #32
glamcem
glamcem's Avatar
@ck-GT86 keep in mind this general rule doesn't really change much:
"FAST - RELIABLE - CHEAP
pick two"
Old 08-21-2015, 02:38 PM   #33
CSG Mike
CSG Mike's Avatar
Any preferred MAP sensor you recommend?
Thanks
Anything 2.3BAR or higher will work.
Old 08-21-2015, 02:45 PM   #34
CSG Mike
CSG Mike's Avatar
- The FRS/BRZ has a smaller CdA than every car listed. The higher the speed, the larger the CdA advantage. The STI and Evo is a flying brick.
- Gearing is moot; tight gearing is better for the JRSC powerband anyways. It's not ilke you deal with turbo lag.
- Repeatability... is debateable, but none of the setups listed above will have issues repeating performance from a roll.
shu5892001 (08-21-2015)
Old 08-21-2015, 02:51 PM   #35
ck-GT86
ck-GT86's Avatar
I fall into the first two, with the exception to occasional track days. I hardly drive my car now as it is thanks to free public transportation, but I do find the power boring when I do.
.ck
|| My Build Thread ||
The Following User Says Thank You to ck-GT86 For This Useful Post:
glamcem (08-21-2015)
Old 08-21-2015, 02:56 PM   #36
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
@autograph -
Great to hear you like your Jackson Racing supercharger system! Yeah, open exhaust TIY kits are pretty loud. I still run a completely factory exhaust on my street FR-S.
There should be a good bump in power throughout, with it getting stronger as it heads towards redline. Think of it like a bigger engine being in the engine bay.
We have had quite a few customers order TIY kits then call and order the CARB calibration to improve their overall drivability. They drive a friends Factory Tuned system and notice it drives completely different. A proper ECU calibration is important to overall performance and drivability.
-Oscar Jr.
Jackson Racing is offline   Reply With Quote
The Following 2 Users Say Thank You to Jackson Racing For This Useful Post:
SuperDave (09-01-2015), why? (08-21-2015)
Old 08-21-2015, 03:07 PM   #37
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
lol, thanks.
beware of rod bearing issues if you plan to go that way lol
2016 Lexus GS-F PPE EL Headers, Joe Z X Pipe, Tom’s Racing Drop in, RR Racing Tune, RR Racing Motor Mount, RR Racing USRS. 430WHP.
2024 Volvo XC60 T8 Recharge
shu5892001 is offline   Reply With Quote
The Following 3 Users Say Thank You to shu5892001 For This Useful Post:
ck-GT86 (08-21-2015), drewbot (08-21-2015), glamcem (08-21-2015)
Old 08-21-2015, 03:11 PM   #38
ck-GT86
ck-GT86's Avatar
Oh crud, I wasn't aware of those. I see you previously owned one!
.ck
|| My Build Thread ||
Old 08-21-2015, 03:11 PM   #39
glamcem
glamcem's Avatar
yes Evo and STI has a slight disadvantage on drag coefficient figures (.27 vs .30X something) but that disadvantage becomes negligible especially when the speed increases ..see below formula:
A car cruising on a highway at 50 mph (80 km/h) may require only 10 horsepower (7.5 kW) to overcome air drag, but that same car at 100 mph (160 km/h) requires 80 hp (60 kW). With a doubling of speed the drag (force) quadruples per the formula
I was referring to the highway pulls not the transient lag that is inherited in turbos, I should've said "better matched gears" because taller gears only have advantage for that specific power levels ..M3 with it's longer gears will almost always walk away from the SC'd FRS/BRZ with less than ~300whp
compared to other FI choices yes but compared to NA? well we know the answer
Old 08-21-2015, 03:36 PM   #40
CSG Mike
CSG Mike's Avatar
I love wikipedia.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
ATL BRZ (08-21-2015), drewbot (08-21-2015), Teseo (08-21-2015), why? (08-21-2015)
Old 08-21-2015, 03:37 PM   #41
glamcem
glamcem's Avatar
I love wikipedia.
I do too
Old 08-21-2015, 03:57 PM   #42
bfrank1972
Drives: 2013 FR-S Argento
Hi, unless I'm misunderstanding your post, there are some things that might need clarification:
1) As speed increases, drag coefficient becomes exponentially more important, not less important.
2) We're making broad assumptions based on power/weight ratios, but ignoring engine flexibility/area under the torque curve/gearing when comparing 2 cars.
Assuming we have two cars, exact same shape power curves, exact same power to weight ratio, exact same drag coefficient, same drive layout, we can say the following:
- The heavier car will be at a disadvantage compared to the lighter car because the heavier car will have to overcome greater inertia, which at some power point will create traction issues. High powered heavy car can't put the power down.
- The heavier car will have an advantage at higher speeds because force required to overcome the inertia and the associated traction problems will become less of an issue, and drag will become more of an issue. Given equivalent drag coefficients, the heavier/higher powered car will pull away.
That said, the FR-S is ligther AND has a lower Cd than most cars with equivalent power to weight ratios. Where the Jackson SC (and all other gear/bet driven centrifugal compressors) fall down is the power curve. They build boost on a slightly exponential curve relative to engine speed. The power is all on the top end, unless you have some fancy variable ratio drive to spin up the compressor at lower RPM's.
This is why you see positive displacement supercharger kits making around 240-250rwhp easily matching & possibly outpacing centrifugal kits making 270-280rwhp. More area under the curve - especially important on street driven cars.
The Following 3 Users Say Thank You to bfrank1972 For This Useful Post:
autograph (08-21-2015), DAEMANO (08-21-2015), Yoda (08-21-2015)
Best exhaust mod path for a daily driver FR-Slide Engine, Exhaust, Transmission 48 02-25-2014 02:51 PM
Nameless Full 3" Exhaust Review FR-S Matt Engine, Exhaust, Transmission 45 11-03-2013 09:40 PM
Daily driver dyno and modifications review (Raceseng pulley update) Fofofawcett Engine, Exhaust, Transmission 12 08-29-2013 11:57 AM
The $25k daily driver challenge - multi car review inside Re_Invention FR-S / BRZ vs.... 61 06-21-2013 01:57 PM
OhDamn.co Review of the FRS as a daily driver Oh Damn Andrew Scion FR-S / Toyota 86 GT86 General Forum 11 10-22-2012 12:18 AM
