#29 |
Drives: 2013 FRS
i have to second the fitment issue of cf components. as awesome as my seibon carbon rear delete was, there were some modifications with files in order to make the holes wider since they were ...off..pretty off..haha but you can't tell because the bottom portion covers that part up well. in terms of hoods, i'm pretty damn sure our hood is just as light and i also second the vented deal. ok i'm done haha.
| The Following User Says Thank You to ft86me For This Useful Post: | IBill4You (08-20-2015) |
#30 | |
Drives: GTS 86
Any resin whether epoxy PE or VE will yellow at some point in time if it is exposed to the elements. Now, there are few good ones with very good UV additives added, so that coupled with a really good clearcoat should protect the CF very well. The clearcoat used by top car manufacturers is really, really up there! None of the things you and I have mentioned, is used by the CF aftermarket manufacturers mainly because of the costs. The market is quite competitive so they need to keep the costs down to compete with lower quality products in the market, therefore they need to cut certain corners. There are some good quality stuff out there but it costs quite a lot and sometimes not even worth the effort. |
#31 |
Drives: 2013 MT Asphalt FRS
Does anyone know if dry carbon also eventually turns yellow as well?
#32 | |
Drives: 2013 FR-S Ultramarine
So short answer, yes. If they use a resin system that can fail due to UV and a cheap clear, it will yellow. Cheers Nathan |
| The Following User Says Thank You to SubieNate For This Useful Post: | Carlitoz3 (06-20-2013) |
#33 | |
Lowered Lifestyle
Drives: Scion Fr-S
Sent from my HTC One |
#34 | |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
#35 |
Drives: 2015 Subaru BRZ
Seibon Carbon Fiber Hood
Random question that I cant seem to find. Is that center piece functional or just for looks? I can see from other pics the side ones are obviously.
| Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! | F-T | Exterior Parts - The Rest | 285 | 08-24-2015 05:42 PM |
| Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser | Mr.Frs | Cosmetic Modification (Interior/Exterior/Lighting) | 36 | 04-08-2015 11:51 AM |
| Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) | master345 | Cosmetic Modification (Interior/Exterior/Lighting) | 56 | 05-04-2014 12:10 PM |
| VIS Carbon Fiber | Tansey86 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 04-12-2013 11:54 PM |
| APR Carbon Fiber Lip Kit now available! | ShowstoppersUSA | Exterior Parts - The Rest | 22 | 04-09-2013 07:42 PM |
