#99 |
Drives: 2014 Pearl White BRZ
Yeah - just tried again. No luck...
#100 |
Drives: 2013 Scion FR-S Raven
tick tick tick 6 days down
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#101 |
Just received this email, things just keep getting ...... I don't know, they've had my money since July 2nd. LOL, Burn Motorsport "burned me for 22 days"
From Rigid collar (Burn Motorsport Ltd) in Europe I wish to update you on your order. After a discussion with the territory Dealer Go Tuning USA it has become apparent that we cannot fulfill your order= . It was in error that the website allowed it to be processed - this has since been corrected. We will issue you with a refund and with your permission pass your details = to Go Tuning for them to contact you and complete the order. I'm sorry for this confusion. Kind regards, Anthony
#102 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | tonystewart (07-24-2015) |
#103 |
PM Sent
#104 |
Installed Rigid Collars F & R
SP 50261 & ZP 50300 Installed 4 new Front Sub Frame Bolts SU003-05212 Installed 2 new Rear Suspension Bolts & Nuts SU003-05213 SU003-05235 Firmer, quieter over bumps
| The Following 2 Users Say Thank You to tonystewart For This Useful Post: | Createddeleted (08-12-2015), juliog (08-10-2015) |
#105 |
Drives: 2013 BRZ limited
I'm looking forward to doing the front install which has been sitting in my room. I hope only the front will add some comfort.
#106 |
Drives: 86
How many hours of labor approximately? I still need to install mine but I think I wanna rent a lift to make it easier.
#107 |
Use a lift, it's worth the money.
4 hours, unless you have a JDM Under Body Panel Kit, then add an hour. I'm slow and methodical, I clean parts (under body panels, tires etc) as they are removed, makes reassembly easier.
| The Following User Says Thank You to tonystewart For This Useful Post: | juliog (08-10-2015) |
#108 |
Drives: 2016 FR-S
So far, I've not noticed any appreciable changes with the colars in conjunction with the Ohlin's RT coilovers.
| The Following 6 Users Say Thank You to Sleepless For This Useful Post: | akyp (08-12-2015), Hyper4mance2k (08-14-2015), rice_classic (08-12-2015), solidONE (08-12-2015), tonystewart (08-12-2015), Tristor (02-26-2019) |
#109 |
Drives: FR-S Whiteout
Did you at least find that the having the mounting points centered, the alignment is less lop sided than without collars?
Intent > Content
cowardice is the mother of cruelty. |
#110 |
Drives: Nevermorange FRS
This is a very expensive placebo and I'm in the wrong business.
<---starts putting piston-return-springs in a Spoon box to sell... daddy's gonna be rich!
PRO86 | WTCC | STL
#111 | |
I felt the same as these guys after having installed the TRD door jammer thinger. I felt no difference at all. I'm sure it does something positive in terms of chassis rigidity albeit very very minor. Probably not worth the $150+ pricetag. At least theres now a cool TRD logo in my doorjambs.
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 08-12-2015 at 10:44 PM. |
#112 |
Drives: 2016 FR-S
Mine was even beforehand, so, no.
| The Following User Says Thank You to Sleepless For This Useful Post: | solidONE (08-13-2015) |
| Spoon GT86? | c147258 | Scion FR-S / Toyota 86 GT86 General Forum | 67 | 04-27-2016 12:31 AM |
| No Spoon parts for the 86... | twincamRob | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 81 | 06-02-2015 10:37 AM |
| Fs: brand new pbm subframe collars | Guildjs | Brakes, Suspension, Chassis | 3 | 10-16-2014 08:54 AM |
| T1R Differential Collars | Mikepage | Engine, Exhaust, Transmission | 0 | 05-01-2014 09:18 PM |
