Old 07-16-2015, 09:55 PM   #57
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
@Draco-REX
Here's were element tuning first encountered the problem:
http://www.ft86club.com/forums/showthread.php?t=73858
And if you scroll down a little on this page it talks about it briefly:
http://elementtuning.com/competition...r-wrx-fa20dit/
Again hopefully that's all your problem is.
Edit:
There was also a more recent occurance and I believe all that was needed was a new cam and rocker.
WHITE is offline   Reply With Quote
The Following 3 Users Say Thank You to WHITE For This Useful Post:
Draco-REX (07-16-2015), Ganthrithor (07-17-2015), whataboutbob (10-21-2015)
Old 07-16-2015, 10:06 PM   #58
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by WHITE View Post
@Draco-REX
Edit:
I don't want to get my hopes up, but I'm starting to think I dodged a bullet here. A week can't go by fast enough.
Old 07-17-2015, 11:13 AM   #59
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Rockers fail. It happens without oil starvation. Common causes are extra revs and especially hitting the rev limiter.
Old 07-17-2015, 11:59 AM   #60
Draco-REX
Corner Junkie
Draco-REX's Avatar
I did bounce off the Rev limiter a couple times. But I believe Delicious uses a soft limiter.
Old 07-17-2015, 01:46 PM   #61
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Valve springs help big time. Seems like they float a little with stock springs at the limiter and the rocker looses the direct pressure/contact and the smacking lets the pin walk out. We had a built motor a year and a half ago shoot out a rocker. Pulled it back out and replaced everything that broke and installed springs/retainers per full blown and it's been good since. Have 3 built motors revving to 8300rpm with ferrea springs and retainers and all have been good since that first one let go
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
BRZGM3 (08-24-2015), GotBRZ1691 (10-13-2015)
Old 07-19-2015, 11:12 AM   #62
kayoh
kayoh's Avatar
Drives: 2014 SWP Limited BRZ
Newb Question, what does eating a rocker mean?
kayoh is offline   Reply With Quote
Old 07-19-2015, 01:48 PM   #63
WHITE
Thats pretty neat
WHITE's Avatar
It just means one of the rocker arms in the head broke.
The Following User Says Thank You to WHITE For This Useful Post:
kayoh (07-19-2015)
Old 07-19-2015, 09:12 PM   #64
Draco-REX
Corner Junkie
Draco-REX's Avatar
In this case, the pin that helps keep the rocker in place had a manufacturing defect, causing it to come out and let the rocker loose. The rocker is between the rotating cam and spring-loaded valve. So it get spat out with enough force to crack or even go through the valve cover.
Old 07-19-2015, 09:18 PM   #65
Lonewolf
Lonewolf's Avatar
Drives: Moped
In b4 @Tcoat somehow finds a relevant picture
The Following 2 Users Say Thank You to Lonewolf For This Useful Post:
cdrazic93 (07-28-2015), GotBRZ1691 (10-13-2015)
Old 07-19-2015, 09:27 PM   #66
Generally don't play in the tech threads but that sounds like a challenge.
The Following 7 Users Say Thank You to Tcoat For This Useful Post:
cdrazic93 (07-28-2015), DustinS (08-11-2015), EAGLE5 (10-24-2015), JS + BRZ (08-11-2015), Lonewolf (07-19-2015), Phantobe (07-20-2015), SkAsphalt (08-11-2015)
Old 07-23-2015, 02:47 AM   #67
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by TurboBRZ View Post
Two people with Delicious tunes on here who both seem to have had the same problem with the same supercharger kit at a reasonable boost level. For the kind of damage to have been done that you both describe, it leads me to believe there was something off on the tune - or that without an upgraded fuel pump (don't know if you have one or not) the engine wasn't getting enough.
Sorry, not buying this. @Draco-REX's failure happened as he was approaching a red light. Not exactly the type of situation you'd expect to see fuel starvation.
Old 08-11-2015, 11:51 AM   #68
Draco-REX
Corner Junkie
Draco-REX's Avatar
ZB got the valve cover off and was able to get a good look at the damage. He confirmed rocker failure as the cause. Unfortunately when the rocker came loose it damaged the head. So the engine is getting pulled and the head removed. We'll give the cylinders a good look and see if forged internals is warranted. I really wish there were aftermarket rockers available.
No pictures yet.
Old 08-11-2015, 01:52 PM   #69
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Did you ever extend your rpm over factory at any point?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-11-2015, 02:20 PM   #70
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
@Element Tuning offers rockers with secured axles to prevent them from sliding out.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
raven1231 (08-11-2015), smudge (12-04-2015), ybotspawn (08-11-2015)
I Need Advice About An Fr-s! DViper0020 Issues | Warranty | Recalls / TSB 13 05-09-2014 11:15 AM
Some advice zoomzoomers Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-22-2013 06:16 PM
Advice EDCOVEY FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-10-2012 09:16 AM
Need advice Ikmv Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 01:17 AM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 06:39 PM
