Old 08-06-2015, 06:55 PM   #1
OkieSnuffBox
Drives: '23 BRZ Limited
Finally looks like there is a proper bolt-in roll bar solution!
http://www.ft86speedfactory.com/auto...l#.VcPVtvlVhBc
Four points, harness bar, priced reasonably.
WIN!
Old 08-06-2015, 07:40 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
Pretty sure that's been out awhile. Mounting plates look really small, I'd like to see where they land.
redlined600 is offline   Reply With Quote
Old 08-06-2015, 07:43 PM   #3
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Been around a while. Requires welding for front mounting.
Sleepless is offline   Reply With Quote
Old 08-06-2015, 07:59 PM   #4
OkieSnuffBox
Hmmm, I hadn't run across it before.
Could have swore the only thing I saw was whatever shop is making that $1500+ roll bar.
Old 08-06-2015, 09:11 PM   #5
phastafrican
phastafrican's Avatar
Drives: 2013 Raven Scion FR-S
Was around back in '13 before my car was caged. Great option.
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T
phastafrican is offline   Reply With Quote
Old 08-07-2015, 12:41 AM   #6
mrk1
Drives: Sterling BRZ Ltd
Proper and bolt in are not words that should go together when talking about a safety device like a roll bar.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
juliog (08-07-2015), Kotu100 (08-07-2015)
Old 08-07-2015, 12:11 PM   #7
redlined600
Drives: Fr-s
I'd argue that a bolted in design could be just as strong, but it would have to be designed properly. The problem I see with most roll bars is lack of any landing pad other than the 3x5 (if that) plate at the end of the hoop.
Does anyone have an install picture of the auto power bar?
Old 08-07-2015, 03:25 PM   #8
OkieSnuffBox
[ame="https://www.youtube.com/watch?v=qMmjaaSQP08"]Roll/Flip - YouTube[/ame]
Yep, properly designed bolt-in roll bars don't work AT ALL. This is the exact same bar I used to run in my Miata track rat. Based on the tach and being in 4th gear means he left the track at ~95mph. (Note to everyone, when you go off like that, LET GO OF THE DAMN WHEEL!)
There are multiple, multiple incidents showing Boss Frog and Hard Dog roll bars saving the occupants in Miatas from injury.
What do you mean by landing pad? Are you talking about a plinth box like is designed to mount welded in roll cages? Or are you talking about a plate on the outside of the car that places the mounting plate in double shear?
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Hyper4mance2k (02-10-2016)
Old 08-07-2015, 03:27 PM   #9
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Exactly. How you bolt it in is a major part of the equation but the one in the link has one solid bar for the main hoop, a cross bar and two rear bars for rear bracing. If it's "bolted" to properly reinforced and wide landing pads then it would be fine. Landing pad is the KEY.
pic from link:
SCCA T4 - FRS
Old 08-07-2015, 03:34 PM   #10
rice_classic
BTW: GODDAMN. I hope you have considering using a head/neck restraint system going forward.. that looked ROUGH. Glad you're OK. Just went through something similar so I can relate.
Reference the 4 landing points of the cage in the picture, if just bolted down with that little surface area they can punch through the floor pan or body in a significant impact like yours, this I have seen. So a plate or "metal pad" that covers more surface area, often used on the underside of the body in which the cage bolts to spreads the load. I think a wider pad should be on both sides of the body the bars are bolted to.
My welded in cage has thick pads (IT Spec) that cover a large surface area. In the past I used a bolted bar like this one but used larger plates above and below the body for a greater spread.
SCCA T4 - FRS
Old 08-07-2015, 03:43 PM   #11
OkieSnuffBox
No, that wasn't me. I've only wrecked on track on 2 wheels. I was just using it as an example for those who like to spout off without experience on that which they are spouting off.
Yes, like I mentioned, a properly designed bolt-in bar will have larger backing plates that place the "landing pads" in double shear. Although a weld-in cage should be mounted using plinth boxes, not just landing pads, a la:
This is what happens with small "landing pads" without backing plates placing things in double shear (at my local track, car prepped by CarFx, essentially a bunch of jack holes who barely know how to turn a wrench)
You can see them punched through the floorboard.
The Following 2 Users Say Thank You to OkieSnuffBox For This Useful Post:
MaximeT (09-06-2016), ultra (08-14-2015)
Old 08-07-2015, 04:01 PM   #12
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
Did he dieded ?
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
Old 08-07-2015, 04:11 PM   #13
OkieSnuffBox
Nope, somehow walked away.
I think it was something to do with using stock seats and belts allowing him to "fold" out of the way. That place builds terrible, terrible cars.
However, Hallett is of the opinion (and make you sign the waiver) that if you're willing to put it on track, then go for it.
I have wrecked on 2 wheels on the street (4 of us went down, 1 died) and once on 2 wheels at Hallett where a Shoei helmet saved my life after coming off the bike north of 70mph and landing head first (was knocked out long enough they red flagged the session).........I just don't understand how guys will skimp on safety.
I guess it's the whole "It will happen to them, but never me."
JoeC (08-23-2015), Ultramaroon (08-09-2015)
Old 08-07-2015, 08:10 PM   #14
FRS Justin
Drives: 2013 Asphalt FRS
Spencer Fab make a excellent cage
I went with a Spencer Fab cage out of Seabrook New Hampshire,
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
ultra (08-14-2015)
PTUNING GoPro and POV Camera Mount (tow-bolt mounted solution)...Now Available Mrc@ptuning Audio/Visual, Electronics, Infotainment, NAV 23 04-18-2015 09:43 PM
Proper camber bolt installation brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 10-04-2014 10:09 AM
Bolt in Roll cages. Ludacrits Cosmetic Modification (Interior/Exterior/Lighting) 8 01-26-2014 07:19 PM
Finally proper pictures of my car. trueno86power FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 10-13-2012 09:01 PM
Proper Roll Cage CyberFormula Scion FR-S / Toyota 86 GT86 General Forum 1 04-12-2010 04:51 PM
