Old 05-31-2012, 04:21 AM   #29
earthsscum
earthsscum's Avatar
Drives: 2013 BRZ premium dgm
very intresting thread! Thanks for the info, this car has the potential to be more fuel efficient with a few tweaks especially considering how light it is.
earthsscum is offline   Reply With Quote
Old 05-31-2012, 01:48 PM   #30
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Originally Posted by Jeff Lange View Post
I wonder if that is for the guts or the whole casing as well?
smbrm is offline   Reply With Quote
Old 05-31-2012, 01:49 PM   #31
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Ring & pinion set only.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 06-01-2012, 03:15 AM   #32
smbrm
smbrm's Avatar
So a rebuild of the guts required then. How would one recalibrate the speedometer, or do you even have to if speed is taken from wheel sensors?
I figure the following:
4.1 approximate Ratio relationship MT/AT: 1~=1,2<2,3<3,4>3,5=4,6<5,6<6
3.727 approximate Ratio relationship MT/AT: 1>1,2>2,3=3,4<4,5<5,6>5,6<6
Old 06-01-2012, 09:21 AM   #33
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
Here's the difference in speed while cruising at 75 mph between the 3.727 (shown as BRZ P-MT FD1) and 4.1 final drive gears (shown as BRZ P-MT FD2) between the manual transmissions. The canadian version is here.
depending how much time you spend cruising on the freeway, the 300 rpm difference between the FD gears may not be worth it for the fuel economy difference and the payback period of buying and installing the FD.
but if the transmission gear shafts between the AT & MT are swappable, then you're looking at a much better difference.
azian_advanced is offline   Reply With Quote
The Following 3 Users Say Thank You to azian_advanced For This Useful Post:
37 (07-22-2013), cobrabyte (01-29-2013), Ryephile (01-29-2013)
Old 06-01-2012, 09:50 AM   #34
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
No, those are not what you are looking for, that is the differential internal gear set for a non-LSD open differential. Both of those are the wrong part number. Not sure why they would have looked those up for you.
41201-80050 - Ring & Pinion Gear Set, 3.727:1
41201-80052 - Ring & Pinion Gear Set, 3.909:1
41201-19605 - Ring & Pinion Gear Set, 4.100:1
41201-29606 - Ring & Pinion Gear Set, 4.300:1
Pricing is probably going to be quite a bit higher than what you were quoted for those wrong parts.
Jeff
A 4.3... Now I'm interested a lot more in this thread!!
Compared to my other cars this thing is quiet and has low revs on the highway
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
SkAsphalt (01-29-2013)
Old 06-01-2012, 11:23 AM   #35
HotLavaMann
First 86 member
Drives: FRS, Tacoma, Honda CB1100
It is not taken from wheel sensors. I spoke to a guy who had replaced his wheels and did not have the flat sensors in the wheels and the car worked fine so these are not required for speedometer. I'm hoping it's just a firmware setting but don't know.
HotLavaMann is offline   Reply With Quote
Old 06-01-2012, 11:24 AM   #36
HotLavaMann
First 86 member
<chart>
Thanks! that is a really useful chart.
Old 06-01-2012, 11:48 AM   #37
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
A wheel speed sensor isn't in the wheels, that's the TPMS sensor. This car could read off on of the ABS rings, or off the trans output (which would cause a bad reading with a replaced FD), or the diff I guess..
The FSM should have that info but I don't have the FSM yet. I should buy techinfo access to get it though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-01-2012, 01:20 PM   #38
smbrm
smbrm's Avatar
Good stuff. I just finished my own chart so you beat me to it. Do we assume that L-AT is for the Lexus?
"....If you like to row gears, this car is for you!....." from http://www.ft86club.com/forums/showthread.php?t=7459 in addition to other comments
seems to sum it up for me.
Having driven the AT, 3rd gear is a very flexible sweet spot in terms of city driveability from 40-70 km. In MT it should be 4th! These will keep you on the lower torque peak.
The MT will be a city shifter(more shifting in city driving). Not sure the 3.727 will change that.
The AT will be a highway cruising shifter(for passing and steep grades)!
In restrospect they probably should have put the 3.727 in the MT and the 4.3 in the AT. They are in the parts bin after all.
Old 06-01-2012, 01:56 PM   #39
Jeff Lange
Jeff Lange's Avatar
Speed signal is supplied by the ABS sensors. Changing gearing will not affect the speedometer accuracy.
Jeff
The Following 4 Users Say Thank You to Jeff Lange For This Useful Post:
Fly Guy (04-21-2014), ill86 (06-22-2012), jcw99 (01-20-2017), SkAsphalt (01-29-2013)
Old 06-01-2012, 02:00 PM   #40
smbrm
smbrm's Avatar
Jeff
Thanks, I would have thought that would be the easier way to do it. But it would still be affected by tire size. There is probably a tire size constant in the programming somewhere?
Old 06-01-2012, 02:02 PM   #41
Jeff Lange
Jeff Lange's Avatar
Probably, but generally it is not something that can be changed/calibrated.
Jeff
Old 06-01-2012, 11:01 PM   #42
azian_advanced
*****istrator
Jeff
wow.. the speed sensor for the speedometer was always on the transmission for most cars. never knew speed sensors are now based from the abs sensors.
what happens when the car is turning and one wheel is turning faster/slower than the other? i'm curious to know how the speedometer compensates for this.
GT86 GEAR BOX FIRECAR Engine, Exhaust, Transmission 10 11-24-2013 02:25 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
86,BRZ MT gear ratio Yobiwan Engine, Exhaust, Transmission 1 01-26-2012 03:40 AM
Top gear USA 4agze Off-Topic Lounge [WARNING: NO POLITICS] 25 12-09-2010 12:01 AM
