Old 08-04-2015, 02:09 PM   #379
faltyda
Drives: 2014 BRZ Limited
Originally Posted by JB86'd View Post
You might have issues if you try to monitor things or datalog, the readings may be incorrect. How many miles have you driven on the new tune?
Not very far at all. I'll have an update after work. Thinking that I may not have let it set in as I didn't drive or warm it up after the flash
faltyda is offline   Reply With Quote
Old 08-04-2015, 06:54 PM   #380
JB86'd
JB86'd's Avatar
Drives: JAWS
When you first start the car after a flash, you let it idle for at least a minute before touching the throttle. Also, it needs time to learn fuel trims, and the pedal to learn throttle input again. Give it 50-100 miles, you'll be set.
JB86'd is offline   Reply With Quote
Old 08-04-2015, 07:01 PM   #381
steve99
Drives: FT86
Originally Posted by wparsons View Post
Yep, and yep.
The OTS 91 map and OTS 93 map are identical at lower revs, and the knock issue I have is in the low rev high load area (too much gas in the ~2500-3500rpm range). Oddly enough I get no knock on a track with 91 octane on the OTS 91 map, but I get a bunch driving in traffic.
I'm currently running an unmodified OTS 93 map on 94 octane.
yep at low loads you run more ignition timing and aso in taraffic intake air temps higher tweak the iat ignition retard values will probably sort it .
also try reducing the amout of port injetion in the problem area
Old 08-04-2015, 07:04 PM   #382
steve99
Drives: FT86
Originally Posted by Myv View Post
Thanks, I'll start logging and check out what can be done with it
ESSO 91 this time, I switch back and forth between ESSO and Shell.
a guy hasalready done most of the work for you see here
http://www.ft86club.com/forums/showt...47#post2216047
The Following 2 Users Say Thank You to steve99 For This Useful Post:
JB86'd (08-05-2015), Myv (08-05-2015)
Old 08-06-2015, 03:41 AM   #383
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Guys, will Romraider and OFT Manager work correctly with Windows 10?
Ondreiko is offline   Reply With Quote
Old 08-06-2015, 03:48 AM   #384
Kodename47
Kodename47's Avatar
Drives: UK GT86
I can confirm Romraider does.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-06-2015, 04:35 AM   #385
steve99
Drives: FT86
not sure about windows 10 , buy the other issue is oft doesnt like usb 3 ports not sure if its software or hardware related ie you might be able to plig oft into a usb 2 hub then hub to usb3 port.
Old 08-06-2015, 10:43 AM   #386
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Thumbs up
All the above does with windows 10 + virtual dyno. To be honest, windows 10 is largely just a streamlined and different User Interface version of windows 8. Pretty much any win 8 driver or program works with win 10. I have all the above programs working well on win 10 on a laptop and desktop setup.
- your friendly forum IT guy.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
The Following User Says Thank You to ShadowSeraph For This Useful Post:
DAEMANO (09-10-2015)
Old 08-06-2015, 02:14 PM   #387
AppleSauce
Drives: FR-S black. Buell XB12s 25th anniv.
I tried to marry my oft but didnt have frs/brz option only a bmw... What do i do about this? I bought this used. Does that mean the ahole i bought it from didnt unmarry it from his car? How do i fix this?
AppleSauce is offline   Reply With Quote
Old 08-06-2015, 02:43 PM   #388
steve99
Drives: FT86
you should be able to select the car type from list mazda/toyota/bmw
you need to select toyota then model zn6
[ame="https://www.youtube.com/watch?feature=player_embedded&v=5tYRpJqTECk"]OFT Multi-vehicle support - YouTube[/ame]
if not you may need to update oft using the openflash manager software from the openflash website
http://openflashtablet.com/Automotiv...ads/index.html
download and install openflash manager on your windows pc connect oft and let it update then install TEMPLATE file 8.2 as per instructions on page
Old 08-06-2015, 03:37 PM   #389
AppleSauce
yeah when i first plugged my tablet into the car it already had a bmw background. there was no option for mazda or toyota or anything just bmw. i tried downloading that file FRS/BRZ/GT86 Template File. i downloaded the windows 8 patch as well and extracted the files and ran them. not sure if there was anything else to do for that. the template file isnt doing anything... maybe im not opening it with the right software? idk i opened it with the open flash manager...
Old 08-06-2015, 03:39 PM   #390
AppleSauce
ok i think i figured it out finally.
Old 08-08-2015, 01:10 PM   #391
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
Question about the data logging, one of my files that I logged was probably quite big (40min drive to work). Every time I click on it through OFM, it just freezes (I've waited for about an hour+ before closing the process), it's probably trying to load the file into the table. Know how I can go about removing it? Or will logging more eventually overwrite this log?
Myv is offline   Reply With Quote
Old 08-08-2015, 01:25 PM   #392
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Did you update your template file? I had the same exact issue when I logged with an old template file and tried to import into a new OF manager software
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Myv (08-08-2015)
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
