08-03-2015, 06:57 PM | #1457 |
@JellyForSale Why did you go for such a big sidewall and a staggered setup? Do you know your speedo is being thrown off by a lot? It seems so wrong in so many ways.
08-03-2015, 07:13 PM | #1458 | |
A Demon
Drives: Raven GT86
Agreed it looks odd. Compared to the jeep in the back the car looks pretty high up. Sent from my iPhone using Tapatalk |
08-03-2015, 07:33 PM | #1459 | |
That Striped FRS
Drives: 2013 Ultramarine FR-S 6MT
08-03-2015, 08:03 PM | #1460 | |
Width and height are two different things. You could have put a 255/35 or even a 245/40 and it would have fit much better. If you wan't pot hole protection, you would get 17's or 16's. Your setup is wrong in so many ways, I don't know what to think so I will leave this here. |
08-03-2015, 08:33 PM | #1461 |
That Striped FRS
Im building to to own standards, not yours. As a build in progress nothing is wrong with that I have going on. Is it tall? Yes. Is the speedo now wrong? Yes. I dont know why you once again stated that. I own the jeep in the back ground that is lifted and larger tires. I understand how a speedometer works. Yes I did probably mix up the words height/width in my post but I understand the difference. And if i want pot hole protection WHILE keeping my 18s I will get taller side wall to cushion. I don't understand why you're talking down over the fact that my tires are x/45/18 opposed to x/35/18.
08-03-2015, 09:16 PM | #1462 | |
You mixed up height/width, not me. Im talking you "down" because you stated width not height. You made the mistake, stop trying to be defensive about it. Go ahead and build it to your own standards. But when you post it on a forum, expect responses. Nothing is wrong? Good one! Do you have a profile pic? |
08-03-2015, 09:30 PM | #1463 |
That Striped FRS
@swarb
I did say I knew the speedo was now off in my second reply to you. So your first line is wrong. I also admitted that I used the wrong words. So your second line is wrong. I never said you did. Same as above. Not being defensive, just wondering if you read where I admitted that I used the wrong word. I expected responses. See how @ZOMFGAARON stated his opinion but didn't act like a know it all? Hence why I didn't reply, I am genuinely happy he gave his opinion. Im fairly certain you can see my profile picture on here. I am really not sure what your last question is getting at. Last edited by JellyForSale; 08-03-2015 at 09:32 PM. Reason: typo |
08-03-2015, 09:32 PM | #1464 | |
A Demon
Drives: Raven GT86
I'm interested in seeing when you lower it. Are you worried about rubbing? Any fender work in the future? Different strokes for different folks, one thing that seems to be forgotten on this forum quite often. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to ZOMFGAARON For This Useful Post: | JellyForSale (08-03-2015) |
08-03-2015, 09:33 PM | #1465 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Both of you shut the hell up and post pics of meaty tires.
- The Ancient BRZ Sacrament by Zaku |
The Following 5 Users Say Thank You to Guff For This Useful Post: | civicdrivr (08-04-2015), drewbot (08-13-2015), kch (08-04-2015), Porcupint (08-11-2015), WHITE (08-09-2015) |
08-03-2015, 09:51 PM | #1466 |
That Striped FRS
Rear has 255/45/18. @swarb Best shot I have but you can see ever so slight rake. Coilovers will be used to fix it. Im definitely concerned with the rear. If I had to guess, I'll be worried about that spot where the fender meets the bumper in the rear, and I'll be lowering the front to match the height of the rear Not going to the slammed look. Just lower to I lose my monster truck status Last edited by JellyForSale; 08-03-2015 at 09:57 PM. Reason: clarity |
The Following User Says Thank You to JellyForSale For This Useful Post: | Hicklinc (02-25-2018) |
08-03-2015, 10:00 PM | #1467 |
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I personally think it looks good, and it'll look better once dropped a little bit.
The only thing I want to know is if your traction control kicks in because of the front/rear difference in height. Sent from my iPhone using Tapatalk
08-09-2015, 03:12 AM | #1468 |
Drives: '14 BRZ Todoroki/OriginLabo
08-10-2015, 02:04 PM | #1469 |
Drives: Honda Civic Type-R FK2
Finally got the new wheels on the car!
Rays TE37SL 18x9.5 Michelin Pilot sport cup 2 265/35 R18 Dropped about an inch all around on KW V3 coilovers Last edited by Mindsucker; 08-16-2015 at 06:46 AM. |
08-11-2015, 12:17 AM | #1470 |
Drives: Toyobaruion
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
