#15 |
#16 | |
Drives: 2013 FR-S 6MT
#17 |
Drives: '13 10 Series FRS #1203
#18 |
Drives: Silver FRS
Do you feel these have enough travel for DD over crap roads? Judging from pictures showing stock vs flex z, they appear to be 2-3" shorter than stock which probably translates to less travel than stock. My FRS goes on 3 wheels entering/leaving my semi-steep driveway, my 02 stock WRX, does not, so not much travel stock.
#19 | |
#20 | |
Drives: Whiteout FRS
#21 |
Drives: GT86 Cosworth
#22 |
So I did my first drift event with these on, and i figured in case any drifters get these and wondering what a good starting point would be heres what I did after playing with these a few times.
I set the camber plates at max negative without moving the securing screws to the closer holes, if I had to take a wild guess its probably around -2 degrees, I'm not sure I just played with them a little bit and ended up maxing them out (not scientific I know, and will vary depending on your ride height) I set the front dampers to full stiff and dropped my front tires down to around 38 PSI hot. The rear I set to 4 clicks from full stiff and ran about 35 psi hot This seemed to do a pretty good job of keeping the chassis from shifting to much and digging in during drift while allowing the rear tires to have some grip. For the first tiem I had nice even tire wear on both sides. Give then layout of the local drift event, generally my right side rear would be cooked because the first entry and last exit are really long/fast left handers. I imagined because both with stock suspension and stock dampers with springs, the car would dig in causing more wear on one side. Needless to say my performance was much better, this was only my 5th event and the improvement overall after having coils in how my car responded to input made me much more confident in predicting what my car was going to do |
#23 |
Not to thread jack or anything, but after 5k miles on these coil overs it seems to have gotten even smoother on the roads but the big bumps still throw me around a bit.
#24 |
Drives: Silver FRS
Does it feel like you are hitting the bump stop? What settings?
#25 |
#26 |
Just an update and some advice:
So I noticed my springs were "loose" in their perches up front (rears were still fine). I decided to look at the tein specs again for initial setup and preload. Given some searches and talking with people it was advised to just "snug" them in the perches and leave it be unless/until you get a corner balance. Well what i thought was "snug" apparently was not snug enough as their was not enough tension from the spring on the locking collars to keep them from backing off. I figured id try and do tein's specs and see what that does. SO i started snugging up the preload to teins specs. This takes a bit of muscle with the spanner wrenches, and now i understand what "snug" means. Adjusted the front preload to teins specs, and now the collars are tight from the tension pushing back and it does not look like they will back off. I checked the rears, and they did not loosen up at all, I only had to adjust those a few turns to get them to teins specs for the rear. The only other thing I did after someone else with the Street flex series complained about the coilovers "lowering" themselves (which I have not had this issue after a few thousand miles on these already) is I torqued them with a torque wrench using the 1/4" port on the spanner wrenches and my torque wrench. Tightened them up good just to be safe.. |
#27 |
Drives: Silver FRS
These are now showing as in stock at Tein USA, released yesterday August 1st, msrp $870.
#28 | |
Drives: ft86
| Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 04:44 PM |
| Tein Street Flex Review! | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 04-20-2016 07:56 PM |
| Tein Street Flex Review and Short Video! | RallySport Direct | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 66 | 04-13-2016 03:17 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 02:10 PM |
| New Tein Street Flex Coilovers - Review and Initial Impressions | RallySport Direct | Announcements, Contests, Giveaways | 6 | 02-18-2013 01:06 PM |
