Drives: 2014 FR-S Silver
A/C completely shut off...
Here's what happened... In 92 degree heat I drove to work (Hour and a half) with the A/C on full blast the whole way. My drive back home at 11pm I did not use the A/C at all. Today I get in the car and start my drive to work but only hot air comes out of the vent when I turn on the A/C. Both the A/C and recerc lights are on for full blast cool air, but not even the sniff of cold coming from the vent. So my hour and a half drive to work was full of hot air. I tried turning it on multiple times during the trip but still only hot air.
I am guessing a fuse or relay went out, but after spending a hour at work on google, I could not find where that fuse or relay is located on the car. Hopefully I am just blind and someone can just laugh at me. Otherwise I hope my compressor didn't kick the bucket when my car is barely a year old. Anyone else have this issue happen? or know how to fix it? |
#2 |
Drives: 2014 BRZ
Does the air conditioning compressor come on when you press the A/C button?
(Do you hear a "clunk" and see the idle drop a few hundred RPM?) |
#3 |
I am still at work right now, but I will check in about 45 minutes when I am off work and on my way home. What if there is a clunk? I am guessing that no clunk means the system isnt working at all
#4 | |
At idle, when the compressor engages, you should feel/hear the engine pull down a bit. Also, I suggest you check the fuse. It's a 50 amp fuse in the #5 slot (top right) in the fuse box under the hood. It's location is shown on page #256 (at least in my FR-S manual) of the driver's manual. DANG, we got more 90+ degree stuff coming our way ..... I hope you get er to cool you down! humfrz Last edited by humfrz; 08-01-2015 at 04:48 AM. |
#5 |
Legend
Drives: BRZ Limited
I had that happened to me when Torque decided to be an asshole and made my car throw a OBD malfunction code. I cleared the code, turned off the car, started the car and the AC was cold again.
#6 |
Well I got back in the car to leave work last night and it was operating perfectly normal..... I am dumbfounded, but at least its working now.
#7 |
Maybe the fuse blow ...... and ......then ...... it got sooo hot in the car, that it melted back together ........
![]() humfrz - is off his meds ......
| Engine shut off by itself! | Astroboy | Issues | Warranty | Recalls / TSB | 34 | 08-13-2018 01:57 PM |
| Rattling from front of car when you shut the engine off | djdrugga24 | Issues | Warranty | Recalls / TSB | 8 | 04-01-2014 01:03 AM |
| Car Shut Down | ScionFR-S | Issues | Warranty | Recalls / TSB | 10 | 11-22-2013 01:07 PM |
| Automatic shut-off | whitefrs | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 10-01-2012 05:47 PM |
| This is the coolest way to shut your truck’s tailgate | ichitaka05 | Other Vehicles & General Automotive Discussions | 8 | 11-11-2011 11:46 AM |
