Old 07-28-2015, 09:24 PM   #1
jazmyn
Drives: 2013 Scion FRS
Problems while changing hvac LEDs
I properly disassembled the hvac and switched the LEDs. I didn't like the white LED in the temp control so I redid it about 4 times. Now when changing the red LED in the first control to a brighter one, it absolutely doesn't light up. I've checked polarities and tried the original LED and nothing works. I suspect the circuit board may have blown or something (Im quite a n00b here).
Any ideas on what could have gone wrong?
For the first and last controls, I used the corvette leds from oznium and for the middle, I successfully soldered leds from digikey.
http://www.digikey.com/product-detai...7-1-ND/2440543
http://www.oznium.com/corvette-c5-led
jazmyn is offline   Reply With Quote
Old 07-28-2015, 10:37 PM   #2
dnieves
Drives: FR-S 10 Series
Did you ground yourself every time you were about to touch the circuit board?
dnieves is offline   Reply With Quote
Old 07-29-2015, 01:33 AM   #3
jazmyn
I believe so, although I did have someone get in and start grabbing circuit boards. If they weren't grounded what would happen to the board. If the only things not working is the LED what would you guess?
Old 07-29-2015, 01:40 AM   #4
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Static electricity. Bye bye board.
With the LEDs, maybe something went wrong during the soldering process.
The Twins make me smile
Old 07-29-2015, 01:42 AM   #5
jazmyn
The soldered ones worked out fine. They still currently light up. The two on opposite ends, temp control and "blow" control do not light but still function correctly.
The Following User Says Thank You to jazmyn For This Useful Post:
soulreapersteve (07-29-2015)
Old 07-29-2015, 04:23 AM   #6
Slammedsteve
Drives: 2013 Asphalt Fr-s,91 240sx missle
Post a picture of the circuit board. Maybe soldering and unsoldering the led so much caused damage. Might be repairable by cutting the trace.
Slammedsteve is offline   Reply With Quote
Old 07-29-2015, 09:50 AM   #7
jazmyn
The soldered board is fine. The problems are with both of the circuit boards using the plugNplay LEDs. I'll still attach pictures though.
Old 07-29-2015, 07:51 PM   #8
dnieves
Use a voltmeter at the LED's leads. If there's power and you reversed the LEDs with still with no results then your LEDs are the problem or cold solder joints if you get no power.
Old 07-30-2015, 10:35 PM   #9
jazmyn
Just checked back today to find that several lights are out. In the hvac panel, all three knobs no longer light up (temp, intensity, and direction). Also the trac, sport/snow, and vsc sport lights no longer work. Only working lights are hazard, time, passenger airbag/seatbelt, and the gear indicator. Is it possible that I blew a fuse? If so, which should I try?
brz, frs, hvac, led, red
DIY-Changing Clock/HVAC LEDs on FR-S Lil Abner DIY (Do-It-Yourself) Guides 113 03-11-2022 02:40 PM
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 07:52 PM
changing interior LEDs jthornton1993 Cosmetic Modification (Interior/Exterior/Lighting) 4 06-14-2013 09:27 AM
