Old 07-26-2015, 03:29 AM   #1
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Cleaning DEI Titanium Turbo Blanket
I sprung a leak from my feed line and it got on my turbo blanket. I took off the blanket and now I am wondering the best way to clean the blanket. Brake cleaner?
Its a DEI titanium turbo blanket.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 07-26-2015, 04:51 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I'd give DEI a call. When I had a question about protecting my lower radiator hose from a header primary, I was able to talk to a tech right away to get advice. They're here in the US, so they're easy to contact.
Old 07-27-2015, 12:56 AM   #3
DAEMANO
Time Traveller
So, not to thread jack, but what did DEI tell you to do?
Old 07-27-2015, 03:36 AM   #4
#maverick#
#maverick#'s Avatar
I sent them an email, Ill call tomorrow.
Old 07-27-2015, 04:34 PM   #5
#maverick#
#maverick#'s Avatar
DEI Said This:
Hello,
You can try using brake cleaner to thin out the oil but I do not know if that would present a risk. If you went this route you would need to let it fully dry for a day to ensure that the chemical is not flammable. The recommendation that I pass on is to use a dish soap that will break down oils. You can use a light mixture of soap and water and lightly apply it to the shield with a soft towel. Keep in mind that if you disturb the shields fibers, the product will show wear. You may find that it is just best to replace the shield (depending on the amount of absorbed oil).
If you have any other questions I can help further. Thank you for your support of DEI products.
Dan
The Following User Says Thank You to #maverick# For This Useful Post:
DAEMANO (07-27-2015)
Old 07-27-2015, 04:39 PM   #6
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I would take DEI's advice of replacing it. A turbo blanket that was soaked in oil is a fire waiting to happen.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 2 Users Say Thank You to protpibe For This Useful Post:
DAEMANO (07-27-2015), djdnz (07-27-2015)
Old 07-27-2015, 05:35 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
He recommended a black hose shielding product called Fire Sleeve, I think. It wasn't available in the time I needed it, so I doubled up with a short length of titanium wrap and some of their aluminumized wire sleeve slit open and wrapped around the hose.
https://flic.kr/p/scH2nU
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 07-27-2015, 08:34 PM   #8
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
I wouldn't risk the blanket... secondly I'd use it as an excuse and order a PTP Lava blanket! Mine feels so much better than my DEI black one did FWIW!
The Following User Says Thank You to Kiske For This Useful Post:
#maverick# (07-27-2015)
Old 07-27-2015, 09:17 PM   #9
DJCarbine
Thupercharged
DJCarbine's Avatar
Another vote for the PTP blanket. Have one on my WRX (wrap on and secure with safety wire) and no complaints.
Would not risk cleaning or otherwise trying to get the oil out, I would do something like put it in the BBQ or an oven (junk/powdercoating) to see if I could vaporize/flash the oil out. Not even sure it would work once the material is soaked, or if the oven would get hot enough. Flash point is usually around 500F IIRC....
Yeah, nevermind. I would get a new blanket and not have to worry about the old one catching on fire or not working as well as it did.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 07-27-2015, 09:18 PM   #10
djdnz
1337
Drives: 2013 BRZ WRB S/C
I'd err on the side of caution, nothing worse than watching a car burn to the ground.
djdnz is offline   Reply With Quote
Old 07-28-2015, 02:49 AM   #11
#maverick#
#maverick#'s Avatar
Bought a new blanket from Real Street Performance, good guys check them out theyre really helpful
FS: 550cc Injectors with PNP Adapters and new turbo blanket boostedbrz Engine, Exhaust, Bolt-Ons 4 02-17-2015 09:11 PM
Cleaning titanium tips?? pandora Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 05-01-2014 01:02 AM
(SOLD) DEI Turbo Blanket (fits AVO Kit and similar sized turbos) Sportsguy83 Engine, Exhaust, Bolt-Ons 1 10-24-2013 11:34 AM
