Drives: '23 CWP BRZ
Can't Get Rear Coilovers Off?
Hey guys, so I'm trying to swap out coilovers on my girlfriends FRS.
The front is all done, and now I'm working on the rear. I can't get these damn coilovers out for the life of me. I've gotten the LCA to Swaybar bolt out, the LCA to coilover bolt is out, but I can't get the LCA to knuckle bolt out because it keeps colliding with something on the knuckle. So I can't really sag the LCA to pull it out. Any tips? I've literally been at this for hours.. |
#2 |
That Guy
Drives: 2013 asphalt FRS MT
Take out the lower control arm to body bolt out. I've only had my rears out twice, but I learned on the first time that using the inner bolt to allow the LCA's the swing down made life much easier.
| The Following User Says Thank You to Calum For This Useful Post: | CSG Mike (07-28-2015) |
#3 |
Why are you even dropping the LCA? It was easy to get mine out without doing anything but unbolting the shocks from the LCA (I jacked up the whole rear, so the sway bar wasn't fighting me).
#4 |
Drives: 2013 FRS Whiteout
As mentioned no need to remove the lca. Remove the bolts and nuts from coil to lca and having already removed the swaybar to lca you should be able to push down the hub/lca assembly and the coilover come out. It has spring tension from the bushings so maybe having someone push it down while you wiggle the coil would help.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
| The Following User Says Thank You to yomny For This Useful Post: | CSG Mike (07-28-2015) |
#5 |
Drives: Raven Black FRS
you can also use a jack to move the lca upward like wparson says so it can free the coilover a bit.
#6 | |
What I did was undo the bolts inside the trunk with the car on the ground, then jack it up so both wheels were in the air and suspension at full droop. Undo the bolt holding the shock to the LCA and then just pull the shock out. It took me less than 45 minutes to pull both rear shocks, remove the stock springs, put on the lowering springs, put the shocks back in and set the car back on the ground. You don't even need to take the wheels off to do the rears.
| The Following User Says Thank You to wparsons For This Useful Post: | Calum (07-24-2015) |
#7 | |
That Guy
#8 |
Drives: 2015 BRZ
I just took out the outer LCA mounting bolt. Made it easy enough to get the shock assembly out, it certainly wasn't coming out without the LCA moving in some fashion.
Jake |
#9 | |
#10 |
Drives: '23 CWP BRZ
I got em out in about 20 minutes after taking a nap.
The guys who installed the lowering springs on my girlfriend's car put a bolt in backwards, so it was hitting a knuckle. I had to drop the knuckle then pop the bolt out and it was home free from there. Here's a photo of the new ride height!
#11 | |
#12 | |
Drives: '23 BRZ Limited
I finally just popped the LCA to subframe bolt out. I did the next side in like 8 minutes. |
| protecting the extended top nut/stud on rear coilovers | DuMa | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 05-07-2015 12:21 PM |
| Noise in the Rear with ST Coilovers | DemonRawr | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 05-01-2015 11:21 PM |
| WTB: Fortune Auto 500 coilovers & PBM rear LCAs | manualmotive | Want-To-Buy Requests | 2 | 04-26-2015 10:33 PM |
| BC coilovers - Help w/ removing rear collar(s) | ang31ito | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 06-11-2014 12:57 PM |
| FS: BC COILOVERS Extreme Drop kit and Rear Extenders | whitefrs | Brakes, Suspension, Chassis | 9 | 03-21-2014 01:58 PM |
