Old 07-21-2015, 07:35 PM   #1
IBill4You
Drives: 2015 Subaru BRZ
Turbo BRZ build thread
So I picked up my 2015 BRZ in March of this year and was immediately in love with the feel of driving. At least until around 4k rpms...
Having always wanted to turbo a car and not having the resources to even consider modding for the past 8ish years I had some pent up energy.
Here she is the day I brought her home:
In the past few months, I have made a lot of progress thanks to a couple shops, this forum, a couple tuners, and the SBD Turbo Kit owner's FB group.
As we all know the work is never finished though.
With my current life events this car will essentially be a good weather daily driver, and someday a weekend track warrior. My goals are to confine modifications to the underbody and engine bay to retain a close to stock appearance. It should be known that I have purchased a beater car for down time, bad weather, and hauling.
After struggling through the 1000 mile break in period I chose to adhere to, I decided it was time for some changes...
I picked up a used P&L overpipe and matched that with a motive front pipe and Invidia N1 Ti exhaust and a Speed by Design 20g Turbo kit. I had originally chosen an OTS ecutek tune, which did not work out for me and ended up with a custom tune from John Visconti. I know some of you are probably choking on your popcorn at this point because I purchased an SBD kit and a tune from Visconti, and I want to let you know that I couldn't be happier with the service from either of them.
Let me preface by stating that I am a shitty mechanic, but arrogant enough to push my limits anyway. After lots of cursing, several trips to buy tools, and wishing I had my own garage and workbench I had rushed through install #1 and subsequently blew the PCV solenoid hose on test drive #1 resulting in idle hunting in parking lots with my newly loud exhaust lol.
In total I ended up adding 6 clamps and swapping the PCV valve for an STI PCV valve.
Here is the result of install #1:
I also added the Whiteline trans mount stiffener bushing.
I quickly realized that with the Prodrive electronic boost controller and my catless setup that I needed my wastegate ported. Perfect opportunity to tear everything apart again! I shipped the exhaust housing off to Neal at The Racer's Line in Cali for a job well done with a super fast TA time. Thanks Neal! As a small aside the oil drain line works best without a hole in it from the exhaust manifold...
I later realized that marking how the turbo was clocked would've probably been smart
I took the opportunity to go over the install correctly, with fresh gaskets, new exhaust manifold nuts, anti seize everywhere.
Went ahead and added some cheap silicone radiator hoses for more blue and the Crawford AOS (sans zip ties...):
I also took the opportunity to replace the oil return with something a little nicer:
I used blue pushlock hose as well:
And threw on the Nameless Cam block off plate:
Extra Heat wrap and turbo blanket this time around too:
aaaaand more heat management (There is also some sound deadening rubber material underneath the thermal barrier to prevent damage from the front cross member).
Starting to look better:
And I've got to do something with this air filter...
I did something...not sure if it was good though:
Ready for some Dyno time at Pure Automotive Performance out of Millersville, MD with John Visconti of Visconti Tuning. Thanks for squeezing me in between the Twin Turbo Z car and GTR!
[ame]http://www.youtube.com/watch?v=MABMY7ga6BA[/ame]
So now I should be happy right?
Went to build a cold air intake, install oil cooler, and finally put back all the underbody panels and missing pop clips:
I went with an AFE filter custom sized to be as large as I could get:
Not sure if you can see this, but I ran into a slight QC problem that prevented me from installing oil cooler until new parts come from manufacturer:
I did not end up using the hard plastic tray here (could not get this on with intercooler) or the partition next to the air filter on the right (Although I now get scared driving in heavy rain if I get caught). Also need to fab up and paint a mount for the right side of the oil cooler:
yes the oil cooler looks like ass lol but it is secured for now.
I still need to polish the new intake and finish the vent 2 Atmosphere setup for the Air Oil Separator.
Tough to see, but this is what has me afraid to drive in heavy rain without that previously mentioned gaurd:
Still stealthy enough, but a little too direct for my liking.
I also modified the fake vents to make them functional on this side. Still needs to be sanded and finished. Again, really hard to see, but was running out of time:
While everything was down I also installed some used BC BR coilovers and 20/25mm spacers for that little touch of flushness without attracting too much attention.
Down 1.5" in front 1" in rear stiffness set dead center all around
This poor car is dirty as hell, but I soon discovered a more pressing issue after the cold air intake:
[ame]http://www.youtube.com/watch?v=ozqYJ6dCcwU[/ame]
My poor clutch Apparently when they say you'll need a clutch with a couple thousand miles that means your clutch will slip like hell after 300 miles and give you a heart attack the first time it happens...
Back to Pure Auto!
I went with the ACT SB7-HDG6 with a torque capacity of 345ft/lbs. This has the streetlite flywheel and not the prolite. FYI a full weight flywheel is not offered by ACT, although the effects of the LWFW are bearable.
Now that the clutch is mostly broken in I love it. The noise, the harshness, the increased pedal effort, the shortened pedal travel are all because racecar, and I love it. With the coilovers, clutch, and trans bushing I am really loving these "inconveniences."
Now it was time for a well deserved bath! Waited until the night before the car show...
What turbo?
Time for a dinner break before I wax
The next morning:
At least the wax is beading the water nicely...
At the show:
Up next, alignment, misc bushings, gauges, finishing touches on intake and vent bezel, finish oil cooler, Spencer Fabrications Crash Bar, finish AOS vent 2 atmosphere, more blue, track wheels/tires, and heavy focus on driver mod.
Thanks for reading and yes I did have to rent a storage unit to work on my car. I should probably build a work bench in there, so it doesn't always look like a bomb went off with my tools all over the ground...
IBill4You is offline   Reply With Quote
The Following 2 Users Say Thank You to IBill4You For This Useful Post:
lantsalot (07-22-2015), Lonewolf (11-21-2016)
Old 07-22-2015, 02:03 PM   #2
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would move wheels and tires to the front of that list ASAP.
IBill4You (07-22-2015)
Old 07-22-2015, 02:47 PM   #3
IBill4You
Hey King Tut I really appreciate and value your advice. Even with driver mod, I would never take this on a track with those tires lol.
My track ready list is tires, wheels, brake fluid, brake pads, alignment, driver mod. I also need to wait until I finish installing the oil cooler and log some oil temps/pressure with 5w30 to see how comfortable I am with this viscosity. After boosting this thing I am terrified of mechanical gremlins. I also want a track safe datalogging solution.
I would probably want to add some ARP wheel studs to my tool box just in case I run into any problems swapping wheels. I would really be unhappy to get all of this preparation done and have a hangup like that at the last minute.
I'm pretty excited and motivated to literally realize a childhood dream though lol
Old 08-21-2015, 04:59 PM   #4
IBill4You
New Seibon Carbon Trunk rough install. VIS AMS Carbon hood in the works.
Also finished up vent to atmosphere setup for Crawford AOS. No pics of that yet though.
Before:
After:
Terrible pics I know, but I'll have more after it is sanded and re-cleared when the vented Carbon hood goes on.
Still waiting for Kate Cool to send me a replacement part so I can finish the oil cooler install......
Also waiting on Spencer Fab crash beam, which will probably necessitate modifying my intake plumbing. I plan on cutting the mustache off the BRZ and repainting the crash beam, oil cooler and shroud, and intercooler to be color matched with the car, then I would like to have some woven wire mesh carbon hydrodipped. I would like to have the fake vent bezels where the fogs go hydrodipped in carbon as well. This should hopefully give me a more aggressive front end to make up for the old man silver lol
Some notes on the genuine Seibon trunk:
Fitment on the car is good, but the openings for the license plate lighting are awful, so I'll need to silicone these in place. I also had to open up the holes for the license plate mount with a file, which I can live with.
I would have expected fitment to be better because this is a Seibon trunk. I guess the outside fitment is what is most important though.
Old 08-21-2015, 05:45 PM   #5
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Nice man. I also just installed the SBD V2 Kit..clutch lasted maybe 150 miles..currently up on jack stands gonna put a clutch in asap! Love the simplicity so far.
797Performance.com
nickmerronesucks is offline   Reply With Quote
The Following User Says Thank You to nickmerronesucks For This Useful Post:
IBill4You (08-24-2015)
Old 08-21-2015, 06:00 PM   #6
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
I need to stop being a little bitch and just buy the V2 SBD kit myself...I really wish these headers of mine would sell so I could...great start to your build!
The Following User Says Thank You to BlueDubbinTDI For This Useful Post:
Old 03-13-2017, 06:34 PM   #7
frslee
Just drive it
Drives: 13' FR-S
Wait.. did you just take 280whp car to track with Hankook Ventus all season tires?
frslee is offline   Reply With Quote
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
AVO turbo kit for BRZ - initial build thread AVOturboworld Forced Induction 3109 12-01-2019 04:55 PM
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 05:26 AM
The Exquisite 86's ML24 widebody FA20club turbo build thread chris's fr-s Member's Car Journals 28 02-12-2016 12:16 AM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
