Old 07-20-2015, 01:59 PM   #1
dstrout
dstrout's Avatar
Brake duct backing plates - which ones?
So I managed to get my brakes good and mushy this past weekend. It seems four 20-min track sessions in 95 deg will do that, even with RBF-600 and XP8's. So, brake ducts and an oil cooler are next on the list.
I am going to go with the APR inlets because I like my DRLs. The question is, whose backing plates? There are plates from APR, Project Mu, Touge Factory, Dremel, and probably others.
Does anybody have a recommendation for one over the other? I lean to TF, mostly because they are metal, but I am open to education and the voice of experience.
TIA!
dstrout is offline   Reply With Quote
Old 07-20-2015, 03:54 PM   #2
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
I absolutely love the APR backing plates. Light, incredibly solid and handle heat great.
crazyfrenchbiker is offline   Reply With Quote
Old 07-20-2015, 03:59 PM   #3
Andreas83
Andreas83's Avatar
Drives: 2013 Subaru BRZ
TF for sure.
They lead the air to the center of the disc so it can pass out trough the cooling veins.
English is my 2. language. Typos might occur.
2013 BRZ, kraftwerks supercharged.
Skunk2 Ultra radiator with oilcooler
KW v3 - enkei 17x9 with PSS
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
wparsons (07-21-2015)
Old 07-21-2015, 11:42 AM   #4
wparsons
wparsons's Avatar
^^ What he said. The others just blow air on the back of the disc, not into the center so it spreads through the vanes.
flickr
Old 07-21-2015, 01:55 PM   #5
CSG Mike
CSG Mike's Avatar
TIA!
The easier solution is to upgrade your fluid to Torque RT700.
Old 07-21-2015, 02:35 PM   #6
JDM4E
Drives: Honda Accord Euro
I have the same question. Which ones? Why has TF's that "missing" piece? It seems that a lot of air must "escape" because of that.
I liked the project Mju because they keep the brake shield, but it seems the air is routed to the edge of the disc which seems wrong too.
JDM4E is offline   Reply With Quote
Old 07-21-2015, 03:47 PM   #7
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Definitely try RT700 fluid first and possibly XP12s. I had those and the TF brake cooling setup and it was very good. Now have it with the StopTech kit and still on XP12s.
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
CSG Mike (07-21-2015)
Old 07-21-2015, 04:32 PM   #8
dstrout
dstrout's Avatar
Boo! In looking up the XP12s, I just found this on the web:
READ THIS!
Carbotech brakes require their own, uncontaminated transfer layer made by Carbotech pads. If this is not done, you will not experience the full potential of the ceramic-kevlar compound.
You will need to do one of the following:
Resurface your old rotors
Completely remove the old transfer layer with a steel wire brush/flapper disc on a drill/grinder
New rotors
I completely failed to do that. I just put them on running against the stock rotors (with 20K miles on the stock pads). I did run them for about 2 weeks on the street, where I get plenty of 70-to-20 decelerations. Could not being on fresh rotors be part of the problem I ran into?
And more broadly, does that hold any time you switch compounds? I put my stock pads back on last night, and noticed the brakes felt very weak for the first few miles. They felt almost like there was grease on the rotors. By the end of todays commute they were back to feeling like "normal" brakes.
Old 07-21-2015, 08:28 PM   #9
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
I went from 30k miles on stock pads and rotors to xp10s with no issue.
Mad_Mike is offline   Reply With Quote
Old 07-22-2015, 02:23 AM   #10
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Yeah, I've not had any issues with switching between street/stock pads and Carbotech tack pads.
Old 07-22-2015, 10:26 PM   #11
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
You need to bed them in.
http://www.stoptech.com/technical-su...nd-procedures/
*question everything*learn something*answer nothing*
lamawithonel is offline   Reply With Quote
Old 07-23-2015, 01:27 PM   #12
OkieSnuffBox
Drives: '23 BRZ Limited
With Carbotechs, don't just do a few 70-20 stops. KEEP DOING it until the pedal gets soft and the brakes stink, then try not to use them getting home/pits/whatever, until they cool off.
BAM! Carbotechs are bedded.
Old 07-23-2015, 03:07 PM   #13
dstrout
dstrout's Avatar
Heh - tough to do on a DD. But understood.
Old 07-23-2015, 06:20 PM   #14
OkieSnuffBox
Just go find an old industrial park after hours, or a low traffic piece of road somewhere.
FS: APR Brake Duct Hose and Backing Kit BRZ / FR-S $275 kanundrum Brakes, Suspension, Chassis 4 04-24-2015 12:24 PM
FS: Cusco Front & Rear Strut Bars / APR CF Brake Backing Plates & Hoses zeal86 Brakes, Suspension, Chassis 5 02-16-2015 03:34 PM
Brake backing plates with cooling pipe Lunatic Brakes, Suspension, Chassis 0 12-29-2014 05:52 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 02:45 PM
APR Brake Ducts and Backing Plates digital_assassin Brakes, Suspension, Chassis 21 03-20-2014 04:50 PM
