#15 | |
Drives: Asphalt build in progress
I made the following mods which by themselves are good, but together they transform the car, all of which I learned about on this forum: 1. Heel toe pedal 2. Strut braces 3. B pillar harness bar ( amazing difference, really tightened up body) 4. Kart Boy short shift kit 5. Cusco carbon Fiber /leather steering wheel 6. Carbon Fiber driveshaft 7. Wilwood big break kit 8. Fortune coil over kit 9 18x9.5 wheels and Conti 255/35 18 tires Each of these affect the way the car feels. I'm not a technical guy, but I have a good sense of feel, and all of these items I am touching, either directly or indirectly. Major enhancement of the driving experience. Combined with a 10psi turbo,(325HP at the wheel) every time I get in this car I feel like I'm launching the space shuttle. Haha except when I can't get it into 1st. That may just be the price I pay for modding a car. When you go down this road, you become Dr Frankenstein, putting together parts that were not necessarily meant to be together. Once that happens, you can't complain that the monster is running amok in the village... |
#16 | |
Drives: 2005 Toyota Camry
First rule of DIY mechanics is to troubleshoot by removing variables. -alex |
#17 |
Drives: 2013 Scion FR-S 10 Series
My money is on the clutch, but you need to systematically troubleshoot to confirm it.
#18 |
hey you, yeah you <3
Drives: 2014 37J FR-S
Do you have a clutch smell, ever? Have you tried the amateur testing of clutches and/or taken off the transmission to check it? Could be the little rubber/plastic ball under shifter not engaging well... but these cars too new for this.
#19 | |
As a matter of fact, sometimes I do smell something. I usually wrote it off to a shitty job of shifting. From what I've seen and heard these cars have pretty tight and notchy gearboxes.. we are early adopters and these cars are Version 1... Short of taking the transmission out, I have found success in putting it in 2nd gear then 1st. Going into 2nd seems to open things up ( non techincal term) and it goes into first pretty well most times. On the bright side, it could be an awesome anti theft feature. And my 16 year cannot make it work so that's an upside as well. Sometime soon, I'm going to have the trans pulled and take a hard look |
#20 |
Just remember this car dont like being shifted down to first unless you @ around 5mph. Shifting into 2nd is best at high rpms.
#21 |
Drives: 2023 WRB BRZ (MT)
I have the exact same issue but no driveshaft and im running an ACT Xtreme pressure plate. My trans prolly has about the same milage and this issue is within the last 1000 miles if that with no mods being added. Only difference is the weather is much hotter. I only get the issue during the day and never at night. Makes me wanna sell it
#22 |
The car or ACT??
It is frustrating as hell, and it makes me crazy in traffic. Thanks for this, I'm going to look at a different clutch flywheel set up because this situation has to end. |
#23 |
The car. Im on a regular flywheel. Had exact same issue with my FX350. So im to the conclusion it's heat (so boost is bad idea in Florida) or only the stock clutch is any good for us (still power limiting)
#24 | |
Drives: 2015 FR-S 6MT
Downshifting into 1st is one of the most fun things you can do in this car - sliding the ass out at low, safe speeds with power (as opposed to a handbrake) requires you to do this. I've had plenty of ass-out time in my car and haven't touched the handbrake for anything besides parking and I like my drivetrain so I don't clutch kick. If you can't shift it into first when you are in the powerband and you are sure that you are doing it properly, you should take the car in to be checked out since it should have absolutely no problem doing this. |
#25 |
After careful investigation and comparing notes with other users of the ACT HDSS clutch and flywheel, we all have the same symptoms. I've decided to ditch the ACT clutch and flywheel and go with the clutch masters FX 300 clutch and flywheel. They assert the clutch and flywheel. Will report results after its installed.
#26 |
The Fail Boat
Drives: CWP S.B.
Ever thought about getting the jdm Toyota TRD one or STI one? Pretty sure those will probably give you less headaches...
#27 | |
Drives: '13 FRS
So the clutch wasn't fully disengaging and instead, it caused the disk to drag between the pressure plate and flywheel and reduced the life of your transmission. Good find and good decision! Have you given ACT feedback? You could save dozens of people from this same experience if ACT makes a revision. Ps: I see this crap all the time with my other car and it wrecks expensive synchros. It's nice that clutch options for this car are cheap and plentiful.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135 |
| BRZ shift gear indicator wants you to shift gears too soon? | Jfheisenberg | BRZ First-Gen (2012+) — General Topics | 31 | 03-24-2015 01:50 PM |
| Gear shift 'step'. | -Tom- | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-05-2015 03:13 PM |
| brz series.blue gear shift from 1st - 2nd -3rd? | iarefluffy | Engine, Exhaust, Transmission | 0 | 10-21-2014 04:41 AM |
| How to Smoothly and Quickly Up-shift from 1st to 2nd Gear? | DemonRawr | BRZ First-Gen (2012+) — General Topics | 20 | 10-20-2014 04:51 PM |
| Manual gear shift in Automatic 86 | djmm | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 07-30-2014 07:08 PM |
