Old 05-31-2012, 02:29 AM   #1
ahausheer
Re-member
Drives: Toyota camry
Sound induction tube - can it be modded?
Searched and found nothing, posted in the cosmetic section because sound is essentially cosmetic.
Anywho,
Has anyone investigated the sound induction tube and whether or not there are internal baffles that can be easily removed, similar to the Mustang's tube. Apparently there are foam pieces inside the Mustang's sound tube, near where it meets the firewall, that can be easily removed to increase sound levels.
Additionally, I have seen a chart that shows interior sound levels (in the FR-S) with and without the sound tube. Under approx 4000 rpm there is little to no increase in volume with the sound tube compared to without. This has caused me to wonder if there is a switch that essentially ''turns on'' the sound tube allowing sound to pass through. Any owners out there see any vacuum switching valves that are connected to the sound tube or perhaps some electrical wires going to a switch of some sort on or near the sound induction tube? FYI: There should be a vacuum diagram sticker under the hood that shows a schematic of where the vacuum switching valves are (if any).
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 05-31-2012, 02:33 AM   #2
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Anywho,
i think the baffle is pressure regulated itself, at 4-5k rpms enough of a vacuum is created to open up the baffle to let noise by, i will look into it tomorrow morning and try to remove the baffle and see how it sounds, iw ould like to hear it at all rpms, or maybe install an aftermarket baffle that lets sound by after 2500 rpms
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 05-31-2012, 02:34 AM   #3
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Anywho,
Actuated by some sort of spring and valve combo. I believe Jeff Perrin has seen the tube personally. I haven't inspected it myself.
WingsofWar is offline   Reply With Quote
Old 05-31-2012, 02:38 AM   #4
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Yeah, you can mod it by ripping it out and throwing it in the old parts bin
Seriously though, once you throw some aftermarket intake/exahust parts on her, she should be plenty loud all on her own.
Justin
GrimmSpeed is offline   Reply With Quote
Old 05-31-2012, 02:41 AM   #5
SuperSatinBrz
SuperSatinBrz's Avatar
Drives: 2013 SWP Limited Subaru BRZ
Yeah, no need to worry about the sound tube. Any intake will most likely be taking care of that "issue".
SuperSatinBrz is offline   Reply With Quote
Old 05-31-2012, 02:51 AM   #6
carbonBLUE
Reverse Burnouts
anyone else hearing impreza boxer burble when above 4k rpms? def doesnt sound like an inline 4 at all... either way i love it
(wont forget you)
2011 Infiniti G37x
The Following 2 Users Say Thank You to carbonBLUE For This Useful Post:
ESBjiujitsu (05-31-2012), Guff (06-01-2012)
Old 05-31-2012, 09:17 AM   #7
ESBjiujitsu
MUST HAVE MORE 86 ! ! !
ESBjiujitsu's Avatar
Drives: Mazdaspeed 6 2.3 AWD Turbo
yup yup yup cant wait to her straight pipes
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC
92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!!
ESBjiujitsu is offline   Reply With Quote
Old 05-31-2012, 11:06 AM   #8
ahausheer
Re-member
To the above:
Im not concerned with aftermarket, im simply interested to learn exactly how the sound tube works.
Old 05-31-2012, 03:46 PM   #9
carbonBLUE
Reverse Burnouts
To the above:
Took the sound tube apart, lools lile there is a resonating plate in the baffle that only let's sound s through when the vibrations from the intake are great enough, below that the baffle silences the engine sound through the tube, I may have that wrong Burt that's what i'm guessing
(wont forget you)
2011 Infiniti G37x
Old 05-31-2012, 03:48 PM   #10
vividracingcom
vividracingcom's Avatar
Drives: FR-S, Porsche 997.2, CLS63 AMG
It sounds really good
A little raspy for street use, though.
Vivid Racing - Your #1 Source for Aftermarket and OEM Parts!
Cusco | Greddy | Agency Power | HKS | Clutch Masters | etc
Check out the VividRacing.com Scion FR-S Catalog
Arsha @ Vivid Racing | 480-966-3040 ext:225
vividracingcom is offline   Reply With Quote
The Following User Says Thank You to vividracingcom For This Useful Post:
ESBjiujitsu (06-05-2012)
Old 05-31-2012, 04:10 PM   #11
ESBjiujitsu
please please post videos of the straight pipe setup, i drive a ms6 with straight pipes I can handle it Did you also dyno the straight pipe setup? both with and without the high flow mid pipe? results? thank you!!!!!!!!
Old 05-31-2012, 09:49 PM   #12
dsgerbc
Drives: BRZ(sold), STI
Yeap, did that too.
First, from service manual:
(b) Chamber Assembly
(1) A new mechanism has been developed which utilizes the air vibrations present in the intake
system and, linked with the driver's operation of the accelerator pedal, draws the air intake
sound directly into the vehicle cabin.
(2) Modulation of the air intake sound for city driving and sports driving is carried out so that
during slow acceleration, consideration has been made with the air intake sound to avoid
feelings of stress from city driving, and during full-throttle acceleration, a sports car-like air
intake sound is produced.
(3) The damper inside the chamber assembly resonates to provide the optimal air intake sound.
So the tube does nothing useful. It's just a metal piece that resonates when designed to.
Two small 10mm bolts and a clamp and I had it out:
It doesn't let air through.
At the other end - it terminates with a grommet in the firewall. You can see it in passenger foot well, if you bend the carpet a bit:
I'm gonna give the thing a chance (haven't revved past 4k so far anyway). If I don't like it I'll get two grommets - one to plug the firewall and one to patch the intake.
The Following 2 Users Say Thank You to dsgerbc For This Useful Post:
ESBjiujitsu (06-05-2012), Fly Guy (06-01-2012)
Old 05-31-2012, 10:10 PM   #13
ahausheer
Re-member
Sweet pics, keep in mind, apparently below about 4K there is no increase in cabin sound levels, although the timbre may be altered.
Timbre = the characteristic quality of a sound, independent of pitch and loudness, from which its source or manner of production can be inferred.
Old 05-31-2012, 11:25 PM   #14
carbonBLUE
Reverse Burnouts
Originally Posted by dsgerbc View Post
Yeap, did that too.
the car sounds great after 4.5k rpms lol slowly getting my car higher and higher rpms i think i maxed out at 5200 today as my highest rpm but i also have 600 miles on my FR-S
shifts are defiantly smoother at higher rpms, sometimes when around 3-4k then shifting to third the computer takes a second before 3rd is all locked up
(wont forget you)
2011 Infiniti G37x
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 08:50 PM
Official 86 GT Modded/Tuned track times. GT5 PAImportTuner FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-26-2011 02:30 AM
The intake sound tube MrVito Scion FR-S / Toyota 86 GT86 General Forum 8 12-09-2011 08:32 PM
Sound induction tube Yay, or ay? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 22 12-04-2011 10:30 PM
Speed hunters first drive and closer look reviews (with photos of modded blue TRD 86) Spaceywilly Scion FR-S / Toyota 86 GT86 General Forum 19 11-28-2011 11:41 PM
