#43 |
Shut up baby, I know it
Drives: 2013 BRZ DMG
Not sure if anyone mention this (too lazy to read yall messages) changing the tranny oil with motul 300 and let the car warm up usually help with the shift. If all fails you still have a power train warranty to get it check out for free. Make sure that they actually have a solution before messing with your car. I had bad experience with toyota service. Had my high pressure fuel pump changed 4 times!!! Each time they "promise" that it will fix the problem, was about to file a lemon case but didn't have time on hand due to school. Goodluck!
#44 | |
Drives: 2015 FR-S Raven Manual
#45 |
Drives: '13 Whiteout FR-S M/T
The loud "clunk" from 1st-2nd is known in this car, it's normal. Some have gone the route of changing the trans oil, but it's not entirely necessary. The trans is a bit finicky when cold, allow your engine to warm up before driving. During your first 5-7 mins of driving, shift at a higher RPM (3.5k-4k). The clunk will not go away entirely, but will feel easier to get into gear as the car gets to optimal operating temps.
| The Following User Says Thank You to kthxbai For This Useful Post: | OctaneFRS (07-13-2015) |
#46 |
There's alot of noise coming from the frs tranny
Some of us get the infamous "quack" noise from each shift. Some have very loose shifter. I just got my brz limited today and my shifter is very tight compared to my frs . You should be covered under the 60k miles for the tranny. So get it check out before more problems occur . My frs was so terrible to the point that 1st and 2nd gear would grind often. |
#47 | |
#48 |
Meh prolly my frs had some sort of defect. It just feels alot different . My friend has an frs and his steering and tranny feels alot looser while his car is currently at 3k miles . Might also that the original brz owner installed mtec springs (heard this effects the shifting)
| The Following User Says Thank You to BlackJesus For This Useful Post: | Tcoat (07-16-2015) |
#49 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | BlackJesus (07-16-2015) |
#50 |
#51 |
Haven't felt the need to do anything to mine just yet. I seem to be lucky in it has always shifted perfectly. Will leave it be unless something changes.
| 2014 BRZ Owner's Manual | hiroanz | BRZ First-Gen (2012+) — General Topics | 2 | 10-09-2013 07:52 PM |
| Manual shift in local traffic? A soon-to-be FRS owner | doctortt | Scion FR-S / Toyota 86 GT86 General Forum | 38 | 01-16-2013 12:28 AM |
| Owner's Manual Error - Recall?? | Re~Mix | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 06-08-2012 01:41 PM |
| FR-S Owner's Manual? | kmbkk | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 05-17-2012 11:12 PM |
| I read the BRZ owner's manual, and I learned... | Phaedrus29 | BRZ First-Gen (2012+) — General Topics | 4 | 04-19-2012 02:25 AM |
