Old 07-15-2015, 10:48 AM   #1
86Hiro
A/C Vent Not Snapping in.....
I removed both A/C Vents, and then removed the trim ring around them to Plasti Dip them white. Passenger vent and trim went on without a hiccup, Drivers side is another story. Trim ring snapped into place, Vent however seems to not want to set correctly. Any ideas? I've tried spinning it in different spots and the only spot it fits, is the problem Im at. See the pics below and give me your input:
86Hiro is offline   Reply With Quote
Old 07-15-2015, 11:04 AM   #2
Shady195
Drives: '13 10 Series FRS #1203
It does only go in one way, it also takes a little force to get it in. I usually give it a whack with my fist quick.
Shady195 is offline   Reply With Quote
Old 07-15-2015, 11:05 AM   #3
86Hiro
Is there a marking on the side that goes in for you? Mine has the Subaru Logo on the top left. I giggled when I seen that logo on the inside of the FRS
Old 07-15-2015, 11:17 AM   #4
Shady195
IIRC there is a little "tab" on the vent and a cutout in the spot on the dash where it snaps in.
Old 07-15-2015, 11:25 AM   #5
86Hiro
Size:  157.3 KBName:  ImageUploadedByTapatalk1436970329.671149.jpg
Size:  156.0 KBName:  ImageUploadedByTapatalk1436970338.976155.jpg
Theres 3 tabs......
Old 07-15-2015, 01:16 PM   #6
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Make sure it's lining up correctly. It doesn't take much force to snap it back in.
sprintertrueno86 is offline   Reply With Quote
Old 07-15-2015, 01:24 PM   #7
86Hiro
Is anything broken here as to why it WONT snap in?
Old 07-15-2015, 01:49 PM   #8
86Hiro
I 98% think its lined up, correctly but no matter how hard I push it in, that one side wont stay in
Old 07-15-2015, 02:09 PM   #9
Maybe you busted the tab off when you pried it out ..... ??
Did you on accident, switch the right and left vents .... ??
Super glue time ...... ??
Old 07-15-2015, 02:13 PM   #10
86Hiro
I compared both vent holes, and vents themselves, both are there 100%.....Makes no sense the passenger one snaps into place easily, and yet the drivers one is being a biatch
Old 07-15-2015, 02:18 PM   #11
G-awesome
Drives: 2015 Firestorm Scion FRS
hmm...when I plastidip my ac trim pieces, I didn't take off the entire vent. I just pulled out the trim piece.
Did you try rotating the part to see if it clips in any other way? Since the ac vent sits at a slight angle to the dash. Or..when in doubt, just mash the sucker back in in clip holders. I I took a bunch of trim pieces off and on many times and the hard plastics can surprisingly take a beating.
G-awesome is offline   Reply With Quote
Old 07-15-2015, 02:23 PM   #12
sprintertrueno86
Drives: 2018 BMW M2
This.
Old 07-15-2015, 02:32 PM   #13
86Hiro
No I did not. The driver and passenger vents are not the same. Passenger side gas a slight angle on the plastic housing, different from the drivers housing where as that one is flat
Old 07-15-2015, 02:36 PM   #14
86Hiro
Would anyone like to volunteer to show their drivers side vent opening to make sure mine isn't broke somewhere?
WTT: my Raven frs fender vent for BRZ fender vent VakaGT Exterior Parts (Aero, Lighting, Etc.) 2 11-13-2014 03:56 AM
WTT FR-S fender vent for BRZ fender vent (white) Anthony Exterior Parts (Aero, Lighting, Etc.) 8 12-02-2013 08:52 PM
WTT: My Asphalt fender vent covers for your DGM BRZ fender vent covers SkAsphalt Canada Classifieds 0 10-07-2013 02:25 PM
TRADE: FT86 Fender Vent for BRZ Fender Vent xia Exterior Parts (Aero, Lighting, Etc.) 0 10-04-2013 10:56 PM
hot air thru vent boonFRS Issues | Warranty | Recalls / TSB 28 09-13-2012 01:35 PM
