Old 07-10-2015, 04:51 PM   #1
Purdue FR-S
Boiler Up!
Purdue FR-S's Avatar
Drives: 2018 BRZ tS
Engine/Drivetrain Squeak Upon Deceleration in Gear - 2013 M/T FR-S
Shortly after letting off the gas while in gear, while I'm enjoying the sound of the exhaust as the RPMs slowly drop from 4k to 2k or so, I will have an intermittent and difficult to repeat "Chirp" come from the engine bay / drivetrain.
Metallic Chirp / Squeak is the best way to describe it. Might get a video if necessary.
This occurred during slower speeds going from stoplight to stoplight.
*accelerate to 4k or so and remove foot from gas, in gear* "Vrrrrrrrr-CHIRP-rrrrrrrrr." Can't really hear it if say you had music and the windows up. Doesn't affect the driveability or affect tach, etc.
Any input would be greatly appreciated!
Thanks
Purdue FR-S is offline   Reply With Quote
Old 07-10-2015, 05:36 PM   #2
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
A/C clutch noise?
Hard to tell from your description.
Try driving in a parking lot at 5-10 mph at a constant speed with A/C on.
More noticeable in a covered parking lot with windows open.
Is that the metal bar hitting another metal bar like "TING" noise that happens every 15 seconds or so? If it's the same noise, then that probably is the A/C clutch noise.
Old 07-11-2015, 08:28 AM   #3
Purdue FR-S
Boiler Up!
Drives: 2018 BRZ tS
Does the A/C need to be on or off? Happens when slowing only.
This was with the A/C off.
Old 07-11-2015, 08:43 AM   #4
aagun
Drives: 86
that tek tek sound . I believe it is happened when u go rev up around 4k-5k . and remove the gad it active once and after that press the gas 60% it jumps again once . Sametimes happen and not happened. if so that's is from clutch description springs holders . it cozed by melt the plastic springs lock or heated xclutch spring. that sound from the springs mean the engine push the clutch hard but the spring can not take the high tourqes
aagun is offline   Reply With Quote
Old 07-12-2015, 10:15 AM   #5
jbailey8748
jbailey8748's Avatar
Drives: 2013 Satin White Pearl BRZ
+1 for a/c chirp noise. I get it and it sounds exactly like what you described. I turn off the a/c and it stops.
Sent from my SAMSUNG-SM-G900A using Tapatalk
jbailey8748 is offline   Reply With Quote
Old 07-13-2015, 05:49 PM   #6
Sigh-on-Rice
If it happens with A/C off, then it's something else. And my car doesn't make that type of noise when doing what you described.
Old 07-14-2015, 10:09 AM   #7
jbailey8748
My car didn't make that noise at first. Around 20k miles is where it started.
Old 07-15-2015, 09:47 AM   #8
Purdue FR-S
Boiler Up!
Drives: 2018 BRZ tS
Mine has 25k or so at the moment. Doesn't interrupt the engine or anything, but in the middle of coasting (no foot on clutch) you hear a metallic squeak.
It's really just a minor annoyance at this point, but I don't want to miss out on something if I need to address it. Just wondered if it was a common occurrence.
2013 FR-S complete drivetrain: engine, trans, DS, rear, axles, wiring fe Engine, Exhaust, Bolt-Ons 19 03-24-2015 07:03 PM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 02:06 PM
Max power for factory drivetrain and engine internals solidONE Forced Induction 64 09-23-2013 02:16 PM
FS Stock Engine/Trans/Drivetrain ecda Engine, Exhaust, Bolt-Ons 1 02-13-2013 06:04 PM
Occasional drivetrain thump when putting into 1st gear chaotichoax Engine, Exhaust, Transmission 5 10-21-2012 02:30 PM
