Old 07-12-2015, 05:26 AM   #15
Kodename47
Kodename47's Avatar
Drives: UK GT86
Thought I'd update this with my "finished" scale:
.: Stealth 86 :.
Kodename 47 DJ:
ztan (07-12-2015)
Old 07-24-2015, 07:57 PM   #16
ztan
Drives: Toyota 86
Thanks, that has prompted me to do a bit more tweaking. I found, as you did, that my last scale at the top of the post read a bit rich. I tried your finished scale against my PLX Bosch 4.9 and it made the Denso sensor read a bit lean compared to that reference. I also had significant STFT oscillation at closed loop cruise operation, possibly related to the sharper elbow on your last curve under AFR 12.5.
Latest scale attached with sensor correlations and summary curves of different scalings; this one is working pretty well for me with good closed loop and WOT tracking of my Bosch 4.9 wideband, there are some hysteresis issues as the Bosch wideband responds much more quickly to transients.
ztan is offline   Reply With Quote
The Following 6 Users Say Thank You to ztan For This Useful Post:
Compelica (09-18-2023), Kodename47 (07-25-2015), solidONE (09-20-2015), steve99 (07-24-2015), Wayno (07-24-2015), Yobiwan (11-01-2015)
Old 10-07-2016, 03:16 AM   #17
Kodename47
Kodename47's Avatar
Drives: UK GT86
The MY17 seems to have improved scaling. It's going to be hard to confirm at this point of the sensors are the same however the scaling is quite similar to @ztan's. I've added the graph below
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Wayno (10-07-2016), ztan (10-07-2016)
Old 05-16-2017, 01:13 AM   #18
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Sorry to bring up such an old thread, but I was wondering if non-FI folks like me would benefit from using @ztan's sensor scales specifically for more accurate logging in OL situations?
Is this a bad idea if I don't have a wideband sensor to correlate against? It wouldn't directly affect the operation of the engine much (0 lambda is still 14.7 AFR), but would affect any future changes I make.
Old 05-16-2017, 07:34 AM   #19
steve99
Drives: FT86
Been using that scaling in my car for years, it just allows you to see and log afr llwer than 12.17, its handy when scaling maf or logging tunes that run richer targett afr than 12.17. oft tunes for example target 11.8, but thier tunes has rescaled o2 to read that but not as low as 10.
Basicly their is no harm in running this scaling
Spuds (05-16-2017)
Old 05-16-2017, 08:51 AM   #20
Spuds
The Dictater
Spuds's Avatar
Exactly the information I was looking for. Thanks!
Old 05-17-2017, 12:49 AM   #21
Spuds
The Dictater
Spuds's Avatar
So I went to go do this in my tune using romraider and Kodname's OFT definitions and there is only one front O2 sensor scaling. It doesn't indicate A or B like the screenshots above. Is this expected? It's the same for the regular OFT definitions as well.
Im also working under the assumption that I can just match my scale to the screenshot, so let me know if I am wrong on that.
Old 05-17-2017, 02:32 AM   #22
steve99
Drives: FT86
yes only one occurrence listed in kodes defs.
yes copy the entire table
Spuds (05-17-2017)
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Scaling for vortech 2.5 bar map sensor? Frs32907 Software Tuning 2 11-08-2015 05:41 PM
Front Oxygen Sensor Scaling - How do we make it read richer values? D-VO Software Tuning 7 05-08-2014 04:48 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
