#15 |
First 86 member
Drives: FRS, Tacoma, Honda CB1100
According to DadHawk, his AT is running at 2350 at 70 MPH whereas my MT is running a bit over 3000 rpm at same speed. That is quite a big difference.
And that is why I'm looking to get the 3.727... it would split the difference between the two. Last edited by HotLavaMann; 05-30-2012 at 03:04 PM. Reason: added last line. |
#16 | |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
41201-80050 - Ring & Pinion Gear Set, 3.727:1 41201-80052 - Ring & Pinion Gear Set, 3.909:1 41201-19605 - Ring & Pinion Gear Set, 4.100:1 41201-29606 - Ring & Pinion Gear Set, 4.300:1 Pricing is probably going to be quite a bit higher than what you were quoted for those wrong parts. Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
| The Following 8 Users Say Thank You to Jeff Lange For This Useful Post: | 37 (07-22-2013), Dave-ROR (06-01-2012), ESBjiujitsu (05-30-2012), rice_classic (06-22-2012), Ryephile (01-23-2013), Tad_07 (05-30-2012), TRD_07 (01-22-2013), WRXGuy1 (01-23-2013) |
#17 |
First 86 member
Thanks much Jeff. Great info. Do you know if those part kits would also include the appropriate "crush sleeve" (according to my mechanic this would also need to be replaced) or is that yet another part to be ordered?
#18 |
The kit includes the ring gear, pinion gear, pinion seal, pinion stake nut, crush sleeve, ring gear bolts and ring gear bolt locking plates.
The 4.300:1 gear kit listed above is for a different model, so the pinion seal is different for that kit. If you went 4.3, you'll probably also need a new pinion seal. Jeff
#19 | |
First 86 member
#20 |
That's correct.
![]() Jeff
#21 |
First 86 member
Local pricing through my Lexus dealer for 41201-80050 is $1106... ouch.
That doesn't include tax and actually having it installed. Hm. I may reconsider priority of changing that out at that price. |
#22 |
#23 |
MUST HAVE MORE 86 ! ! !
Drives: Mazdaspeed 6 2.3 AWD Turbo
this thread is full of good info!!!!!
WISH LIST: Whiteout FRS- Bronze 18' race rims, Cooper Zeon RS3-S tires,
Cusco Coilovers, Cusco 6 point cage, CF Lip spoiler, CF F1 Mirrors, HKS GT-86 SC 92 carmy -> 86 corolla-> Honda S2000 -> Audi TT -> Mazdaspeed6 -> NEXT UP TOYOTA FT-86!!!! |
| The Following User Says Thank You to ESBjiujitsu For This Useful Post: | WRXGuy1 (01-23-2013) |
#24 | |
Drives: '06 AM V8V Coupe
Apparently on some Japanese site the 3.727 gets about 5% better fuel economy on their test cycle, which is probably around what you can expect cruising on the highway. If you drive a lot the savings could add up quickly. |
#25 |
That Guy
Drives: 2013 asphalt FRS MT
How much gas are people expecting to save by doing this? Why not just disconnect the sound tube after the diaphrame? That would cut down on the noise at least.
#26 |
First 86 member
Well in theory you could on the MT get the same mileage as the AT which would move it from 30 to 34 or about 13% (EPA estimates of course). I don't think it's going to be that high as the total gear ratio will still be shorter than the AT even with the 3.727. But 10% might be within reach.
#27 | |
#28 |
Drives: 2009 135i
+1 this is a great idea, Cruising around 70mph would bring the rpms down a bit as well as lengthen the ratios a little. Should come in handy once power upgrades are available
| GT86 GEAR BOX | FIRECAR | Engine, Exhaust, Transmission | 10 | 11-24-2013 02:25 PM |
| Reverse gear on the first and second gear side | randytindoggy | Scion FR-S / Toyota 86 GT86 General Forum | 50 | 01-29-2012 02:21 PM |
| 86,BRZ MT gear ratio | Yobiwan | Engine, Exhaust, Transmission | 1 | 01-26-2012 03:40 AM |
| Top gear USA | 4agze | Off-Topic Lounge [WARNING: NO POLITICS] | 25 | 12-09-2010 12:01 AM |
