Old 07-02-2015, 07:25 PM   #1
mightaswell
Drives: 2015 WRB BRZ Sport-Tech
Slight pull to the left on accel, pull to the right on decel
Hi all,
Most noticeable at speeds over 80kph, I get a pull to the left on acceleration (even slight throttle, lower RPMs), and then a pull back to the right when I decelerate.
Car is 2 months old, 5500km, 2015 BRZ. Thinking of bringing it into the dealer.
Anyone had this issue before?
mightaswell is offline   Reply With Quote
Old 07-02-2015, 08:45 PM   #2
Poodles
Drives: 2015 Series.Blue
Bring it in, definitely not normal. Sounds like a suspension component is loose.
Old 07-03-2015, 11:40 AM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Originally Posted by mightaswell View Post
Hi all,
First thing I'd do is check the alignment.
N1rve
Old 07-03-2015, 01:33 PM   #4
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Mine just needed tightening said tech. Of what? Idk
Old 07-03-2015, 01:44 PM   #5
stugray
Drives: 2013 GBS BRZ Limited
Hi all,
When you say "pull back to the right when I decelerate" Do you mean you just lift the throttle or this happens under braking?
Have you done anything to the suspension? (lowering springs, etc)?
Have you ever clipped a curb? Inspect all 4 wheels for curb rash.
I would take it to an alignment shop for a check before I worry.
The dealer might send it for an alignment on their dime if they are in a good mood.
Old 07-03-2015, 11:42 PM   #6
Fakk
Drives: 13 BRZ Limited 6MT CBS
Tire pressure. Same issue last week. Nail in right rear tire's sidewall. ..Still there
Fakk is offline   Reply With Quote
Old 07-05-2015, 12:10 AM   #7
d1ck
Drives: Black 2013 FRS
What he said ^^^^
d1ck is offline   Reply With Quote
Old 07-06-2015, 08:37 PM   #8
Poodles
TPMS light would be on...
The Following User Says Thank You to Poodles For This Useful Post:
Fakk (07-06-2015)
Old 07-06-2015, 11:05 PM   #9
Fakk
True, mine's perma-on, so that didn't occur to me. I got home and googled, most of people's reponses for other cars was check tire pressures. Bam, right rear. Tire off, found a nail. Sad day
Old 07-07-2015, 02:06 AM   #10
Packofcrows
Mine wasn't. How low tire pressure have to be so light goes on?
Old 07-07-2015, 02:15 PM   #11
mightaswell
Hi all, thanks for your responses. Solution found: turned out to be low pressure in the rear driver tire. Almost no pressure actually. TPMS was not on. No nail found yet.
When I lift the throttle.
Old 07-07-2015, 02:33 PM   #12
Poodles
Weird, I just had this exact thing happen and my light was on
Old 07-10-2015, 11:39 AM   #13
motoxman
motoxman's Avatar
Drives: 2013 fr-s firestorm red
same issue with my car 24k miles...
Having the same exact issue with my 2013 FRS... Took it to the Stealership and they are telling me I have a blown/leaky rear strut. I initially thought it was tire pressure but all the tires are at 34psi so that wasn't it. Dealer ordered new strut yesterday so it will take 2-3 days before it comes in. I can keep you in the loop about whether or not this solution fixes the issue.
motoxman is offline   Reply With Quote
Old 07-16-2015, 12:27 AM   #14
motoxman
motoxman's Avatar
Dealership Diagnosis
Took my FRS to the dealership and let them drive the car to feel and experience the car pulling left on acceleration and then pulling right on deceleration. They kept my car for 4 hours, drove a new FRS with manual transmission to compare. Put my car up on the rack to check everything out and found a blown right rear strut. So, they ordered a new replacement strut for it and will call me when it gets in. I'll keep you all up to speed as to whether or not this fixes the issue...
NOTE: this is the second time it's gone to the dealership for the same issue. They called me back to drive the car again...
The Following User Says Thank You to motoxman For This Useful Post:
mightaswell (07-16-2015)
Fender pull pleong Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-30-2014 12:59 AM
Fender Roll/Pull FRS-IT Cosmetic Modification (Interior/Exterior/Lighting) 6 11-14-2014 11:45 PM
If they Pull The Plug exam2300 Scion FR-S / Toyota 86 GT86 General Forum 18 06-26-2014 12:59 PM
Help about to pull the trigger.... JerryMichaels7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 02-25-2014 07:12 PM
Cops Pull over dealer.... Neilus AUSTRALIA 15 06-21-2012 11:10 PM
