Old 06-26-2015, 04:53 PM   #505
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Originally Posted by bspec View Post
really? I see the ECU go into open loop at what feels like 50-60% throttle, if not higher.
If you log "fuel sys status" you'll be able to see when the ecu transitions from closed loop fueling to open loop fueling.
I believe 4 indicates open loop, 2 is closed loop and i think 0 or something is cold-start/warm up. Double check this information in the "maf scaling" thread.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 06-26-2015, 05:43 PM   #506
bspec
A man
Drives: 14 BRZed
Yes I know, I've been logging that. I actually went back and looked through the logs and I guess you're right, seems that 30% is the transition point. Could have sworn I saw differently when grabbing low-speed data for the VGI tool. Meh.
Thanks
bspec is offline   Reply With Quote
Old 06-29-2015, 04:40 PM   #507
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
OK, pretty new to this. Should I be concerned? Totally stock car (intake|exhaust). Just put on 80 miles since my first Tune (D00C). Running Shell 92 OCT. 1AM has been as low as 46, gradually creeping up but seems to be staying around the 80 mark. Gas? Find a 91 tune or just let it keep learning?
http://datazap.me/u/pnw-brz/80-miles...h?log=0&data=1
PNW-BRZ is offline   Reply With Quote
Old 06-29-2015, 04:48 PM   #508
phrosty
Go with a 91 tune. A constant IAM of 0.8 indicates steady knock. Alternately, you could log Load, RPM, FLKC, and FBKC, and take timing out of your current tune in the problem spots.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
PNW-BRZ (06-29-2015)
Old 07-02-2015, 10:06 PM   #509
Sweet48
Sweet48's Avatar
Drives: 2013 Subaru BRZ
Hey, I've been running Stg2 UEL 91 OCT tune running Shell 91 OCT for a few days. finally decided to do a good data log on it and it seems to be knocking a bit. any input would be very appreciated.
(currently have MXP UEl header & OP, stock mid pipe, corsa cat back, stock intake)
http://www.datazap.me/u/sweet48/log-...8?log=0&data=1
Sweet48 is offline   Reply With Quote
Old 07-03-2015, 01:12 AM   #510
JB86'd
JB86'd's Avatar
Drives: JAWS
You don't have much knock in that log, but being that your IAM is around .7 you definitely had some knock prior to the logging. Ideally when logging you want your IAM to be at 1, and log full throttle from 2000-7400 rpms in 3rd gear at least once. Your IAM is around .7 and you did casual driving. You did log the correct parameters though.
JB86'd is offline   Reply With Quote
The Following 2 Users Say Thank You to JB86'd For This Useful Post:
Sweet48 (07-03-2015), Vroomin86 (07-03-2015)
Old 07-03-2015, 01:15 AM   #511
Vroomin86
Drives: 2015 Fire
Guess I should put my oft tablet to use and log.
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued...
Vroomin86 is offline   Reply With Quote
Old 07-03-2015, 01:31 AM   #512
D_Thissen
D_Thissen's Avatar
You could also try running different gas and see if that helps. I've had good luck on petro 94.
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 07-03-2015, 01:55 AM   #513
steve99
Drives: FT86
As the other guy said try some differnt brands of fuel some are better than others.
else do jb86d,s mods to timing here will likely sort it out
http://www.ft86club.com/forums/showt...47#post2216047
while your at it you might as well look through the tune tweaks thread link below
Old 07-03-2015, 01:08 PM   #514
D_Thissen
D_Thissen's Avatar
@Sweet48 here is a quick pull I did yesterday on Shiv's Stg 1 93 tune running petro 94.
http://www.datazap.me/u/dthissen/log...1?log=0&data=1
Old 07-06-2015, 09:33 AM   #515
Sweet48
Sweet48's Avatar
*quick update*
Started using Petro Canada Ultra 94 Octane (was using Shell 91 previous), looks like the knocking has pretty much stopped and IAM has leveled out at 1. Will continue to log during the week and see how it goes.
Thanks for all the tips and advice guys, I appreciate it!
Old 07-11-2015, 01:31 AM   #516
Rockz222
Drives: 2013 Subaru BRZ Sport Tech
Canadian B.C. car here, worried about the 94 octane Chevron gas. IAM went down to 0.98 and then recovered. Should I be concerned?
94 octane gas is only available at Chevron. (Also does not have ethanol content)
Running OFT Stage 2 EL tune.
http://datazap.me/u/rockz222/log-143...og=0&data=1-10
Rockz222 is offline   Reply With Quote
Old 07-11-2015, 04:50 AM   #517
Kodename47
Kodename47's Avatar
Drives: UK GT86
0.98 is insignificant
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-11-2015, 02:13 PM   #518
Rockz222
Very helpful. Thank you so much.
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
