| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2014 Silver BRZ Limited
My first performance mod?
So I am looking into my first mod for my new BRZ.
The thing I have been noticing is that even on very small spirited rides, it gets a bit tuckered out... I am at a loss of words on how best to explain it quickly. But it doesn't shift as quickly, accelerate as quickly, feel as zippy. So with a ton of talk of engine oil temps being the culprit of many issues, I am wondering if my first mod should be an oil cooler? More specifically a Cusco since I am living in Detroit and will be driving the BRZ in the winter. Other thoughts? |
#2 |
Drives: 2010 MS3
The answer is always tires.
#3 |
Bilge monkey
Drives: '13 BRZ, 82 starlet
1. get rid of those hideous wheels.
2. put good tires on the new wheels. 3. OFT and E85 |
| The Following User Says Thank You to Sammakko For This Useful Post: | FloridaBRZ (07-02-2015) |
#4 |
+1. But burn thru your stock set first. Those tires are a lot of fun.
Also, there's an 86 driving academy coming this month, a worthwile investment. I know this is not a mechanical part. But 'you' are still part of the car ![]() https://www.facebook.com/86DDA?fref=ts |
| The Following 2 Users Say Thank You to mixxxx For This Useful Post: | Frogamazog (07-02-2015), JS + BRZ (07-02-2015) |
#5 |
BRZerhood Lurker #13
Drives: 15 DGM BRZ Premium
1) Driver Mod: Track days, AutoX, Seat Time, etc.
2) Tires 3) E85 and Tune
Yesterday is history. Tomorrow is a mystery. Today is a gift and that's why it's called the present.
#6 |
Drives: Panda FR-S
The only answer is Forced Induction.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
| The Following User Says Thank You to Cal3000 For This Useful Post: | hmong337 (07-02-2015) |
#7 |
Drives: 2015 Series.Blue
The OEM tires have a mileage warranty on them...wear them out and have the money put towards MPSS's
But that's not really what the OP was asking since it sounds like he's got an auto and it's not being as aggressive while hot. |
#8 |
Drives: '13 FRS - STX
Always upgrade the weakest component first:
1) Driver Mod: Track days, AutoX, Seat Time, etc. 2) Alignment 3) Brakes 4) Tires |
#9 |
Drives: AT 2013 BRZ Limited
I really doubt it would be an issue with the oil temps if you are just doing some spirited driving on public roads, but I could be wrong...
I'd get a tune first, it makes the most difference and is the best bang for the buck. Just use the OEMs until winter hits, get winter tires and then come next spring get sticker tires and maybe wheels at the same time? unless you have another car for winter then meh. As someone mentioned, the OEMs have just enough grip to be fun, not to mention good MPG. They are good enough to learn on. My 2 cents Good luck!
'13 BRZ (sold)
'17 STI |
#10 | |
#11 |
Drives: 5555
I suggest long travel rally suspension for Michigan roads
#12 |
Drives: 2014 Pearl White BRZ
Seafoam.
![]() If you don't buy that, throw in a K/N and a Perrin inlet hose. You will feel like you are faster. Don't bother with an oil cooler. In short - just go FI + e85/flex fuel. |
#13 |
Don't listen to anybody and do what you feel you need/want to do to the car first!
| The Following 2 Users Say Thank You to fika84 For This Useful Post: | soulreapersteve (07-03-2015), strat61caster (07-02-2015) |
#14 |
Drives: 2015 Limited
Personally, unless your really driving this hard an Oil Cooler won't make much of a difference. It will even be cooling the oil when your not driving the car hard and in the winter which can have other issues. Tuning is where I'd start, optimize it for what you have and see if you can log what's happening when the car is acting "less spirited" and take it from there.
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 10:23 PM |
| Excelerate Performance: Your Northeast Performance and Installation Center | ExcelerateRep | NY / NJ / CT / PA | 40 | 07-22-2014 06:55 PM |
