Old 06-29-2015, 08:24 PM   #211
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Originally Posted by yomny View Post
Yep, about 20 or so for both. Could also get away with not replacing it but I like to have piece of mind anytime I remove or replace anything.
Totally understandable. I'd probably end up being cheap and not purchasing more gaskets, but I might if it needed to be a clean install again.
Either way, wishing you luck.
Rybot is offline   Reply With Quote
Old 06-29-2015, 08:28 PM   #212
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Brackets are done and heading to coating tonight
JDLAutoDesign is offline   Reply With Quote
The Following 2 Users Say Thank You to JDLAutoDesign For This Useful Post:
drambo136 (06-29-2015), yomny (06-29-2015)
Old 06-29-2015, 08:32 PM   #213
Rybot
Rybot's Avatar
That thing is WAY down there. I really don't wanna delete my fogs.
Old 06-29-2015, 08:38 PM   #214
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
On an FI car with an Intercooler there's not many other places to put a properly sized oil cooler. You could easily route air from the front grill opening to this cooler with some simple ducting.
Jesse@JDLAutodesign is offline   Reply With Quote
Old 06-29-2015, 08:47 PM   #215
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Update on my last attempt to stop this leak. Use permantex copper ultra high temp gasket making silicone, leaked! It had no way out and it leaked through the rear bolt. This is unbelievable. At this point I'm just waiting to send it to precision, hoping for a replacement because this thing is possessed.
Front side, clear.
Rear side, notice the drip on the head of the bolt, maybe hard to see but i confirmed with my finger, fresh oil. This was minutes after shutting down the car.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-29-2015, 08:50 PM   #216
Rybot
Rybot's Avatar
I assume that's as recessed as it can be? Ducting would be easy enough.
I forgot to ask if it still requires deleting the fogs. Is that still true?
Old 06-29-2015, 08:50 PM   #217
Rybot
Rybot's Avatar
Front side, clear.
Man, I don't wanna even know the emotional rollercoaster you've been on with this leak.
Hand it off to Precision. They'll get it sorted out.
Old 06-29-2015, 08:53 PM   #218
yomny
yomny's Avatar
Thats my only option at this point, its a horrible feeling thinking you've got it fixed and next morning or even minutes after, there it is. I've jacked up my car so many times my jacking points are crushed. I really wish no one has to deal with this. Thanks
Old 06-29-2015, 09:46 PM   #219
erok81
Drives: 2015 BRZ
Front side, clear.
.j]
I'm sorry but I have to laugh. I tried all of this same stuff with my pte6262 so it's funny to see someone do the exact thing. I even tried torquing it all then filling the remaining bolt hole with jb weld. Didn't help. Nothing did.
erok81 is offline   Reply With Quote
Old 06-29-2015, 09:50 PM   #220
erok81
Drives: 2015 BRZ
Originally Posted by nelsmar View Post
I think you are confused on what these different components are. The pipe that was "wrapped" was wrapped in a reflective tape to help reduce radiant heat. This pipe is a charge pipe. It has pressurized air that has been cooled via the intercooler. The turbo charger compresses air which increase the temperature and the intercoolers role is to attempt to get it as close as possible to ambient once again.
*snipping very helpful post*
Wrapping the charge pipes is not at all required, and the car will run just fine without it. The difference when really getting aggressive with the car is minimal on that one piece but when people are trying to perfect everything every little bit adds up.
I measured before and after in my WRX. Granted my cold side piping was a lot longer and went in front of the radiator but I saw a 10*F drop by wrapping the pipe. That was done over a couple trips along the same way to work on very similar temp days.
Old 06-29-2015, 09:58 PM   #221
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Can u please sell me just the brackets? I already have a oil cooler but wanna mount it behind the fog light and this is so clean? Can it be on either the driver or passenger side?
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 06-29-2015, 11:17 PM   #222
yomny
yomny's Avatar
Lol it's cool at this point I could only laugh myself or I'll lose my head. I won't continue as anything else will likely cause more issues than a solution. I'll wait on JDL to get my RMA number to ship off to precision. So what you end up doing, garret?
Old 06-30-2015, 12:10 AM   #223
erok81
Drives: 2015 BRZ
Yep. The GTX 2767 or something like that. Should be running by the weekend.
Old 06-30-2015, 12:40 AM   #224
ft86me
ft86me's Avatar
Drives: 2013 FRS
GTX2867R ordered today! That'll be replacing my pte4854b.
As for the oil cooler, as you can see in my previous post w the pic of my engine bay, I have a Perrin oil cooler. Where is it mounted? Well, when I got my kit, I got the JDL crash bar which replaces the Oem crash beam. At that time, I don't think there was a solution for oil cooler mounting so @nelsmar and I mmmm "fabbed" a mount and I use the word "fabbed" loosely lol. You guys can ask him about that. As of right now, it is mounted on the crash beam above the front mount interposed. Seems to be doing it's job well with it's current location. I wonder if putting the cooler behind the fogs will still work with keeping things cool. Someone wanna try it and do some logs?!👍
ft86me is offline   Reply With Quote
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
