Old 06-29-2015, 03:11 AM   #1
DarrenFord
DarrenFord's Avatar
Drives: Toyota x86 GRT
Door lighting issue...
Hi All,
Hoping that someone can "shed some light" on an issue I am having with my door lights, I have followed a guide on the site to replace the inner door light globes with a bright led globe, this was easy enough however I have had to take them out due to the light now staying on permanently.
I close the doors lock the car but the light stays on.
Anyone have any ideas?
Thanks in advance...
DarrenFord is offline   Reply With Quote
Old 06-29-2015, 08:10 AM   #2
LED86
LED86's Avatar
Drives: Black 86 GTS
Normally this is a result of a short and the biu or bui? has been fried. If this is the case then it needs to be replaced.
I recommend putting the stock bulbs in and try to make a claim under warranty that something is wrong with the door lights. Play dumb and don't mention the led swap.
LED86 is offline   Reply With Quote
The Following User Says Thank You to LED86 For This Useful Post:
meWant (06-30-2015)
Old 06-29-2015, 02:24 PM   #3
Jake_86
Jake_86's Avatar
make sure you correctly connected the wires to the door open detectors. it grounds it should that when the door is closed it turns off
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 06-29-2015, 03:09 PM   #4
Chimera
Drives: FRS
did you disconnect the battery when doing this?
the BCU (body control unit) if shorted here by something like a screw driver will malfunction.
Old 06-29-2015, 05:33 PM   #5
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
can you post the link to the guide you used? may be helpful in figuring out what could have gone wrong.
phanguy is offline   Reply With Quote
Old 06-29-2015, 08:19 PM   #6
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
You fried the BIU... Like others have said put your stock bulbs back in. Go to the dealership and play dumb lol otherwise you'll probably be stuck paying for the replacement which I think some have said cost around $400ish.
Below is a link to a thread a while back. I had a post on there (post 13) with two other threads with the same issue.
http://www.ft86club.com/forums/showthread.php?t=66721
Hopefully you can get it taken care of!
Husker BRZ is offline   Reply With Quote
Old 06-30-2015, 02:42 AM   #7
DarrenFord
DarrenFord's Avatar
Erg that's not good !
Thanks all, I used this http://www.ft86club.com/forums/showthread.php?p=1738567
but should have read it all , I will try see if I can get it done by Toyota.
Thanks again for the help !
Old 06-30-2015, 03:52 AM   #8
LED86
LED86's Avatar
Good luck man. Like I said, don't mention the led caused the issu because they will likely use that as an excuse not to cover it. Heard it's pretty expensive to replace.
Old 06-30-2015, 12:58 PM   #9
phanguy
phanguy's Avatar
definitely see if the dealership will take care of it. if not then there is a solution. it isn't pretty, but it should be a lot cheaper than getting a whole new ecu/biu from them. let us know what happens.
Old 06-30-2015, 04:02 PM   #10
Poodles
Drives: 2015 Series.Blue
Think I'm gonna have to make a better write up to do this so people stop frying this thing. But quick run down:
- Disconnect battery OR have the door switch depressed so power is cut to the light
- Use a plastic pry tool and not anything metal (so as not to short or to damage the door panel)
- Disconnect the light assembly at the connector
- Change bulbs
- Reverse order
Also, it's still really fucking stupid these lights aren't fused. It's in a door that can get wet quite easily...
Old 06-30-2015, 11:09 PM   #11
LED86
LED86's Avatar
I think the guide should also mention to make sure the pins on the led base are straight and before connecting the power to check the pins haven't crossed over. I think that's also where the short occurs.
Old 07-01-2015, 05:14 AM   #12
Poodles
Yeah, doesn't help that they don't actually use a socket but a huge bracket on either side that's one piece with the pins. Anything metal will short it, and some of the good LEDs have aluminum heatsinks on them which could touch.
This is why I went for the full replacement assemblies...
Old 07-01-2015, 06:39 AM   #13
LED86
LED86's Avatar
Completely agree! Poor design and no fuse just leads to these problems. I only deal with the full LED lamp units because the bulbs are just too risky on this area of the car.
Old 07-01-2015, 11:01 AM   #14
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Who makes/sells full replacement assemblies?
jawn is offline   Reply With Quote
Door Unlock Issue TONYpepperon1 Issues | Warranty | Recalls / TSB 20 01-05-2018 08:06 PM
Need help on door lighting phanguy Electronics | Audio | NAV | Infotainment 18 10-30-2014 12:10 PM
Door lock issue BRZ323 Scion FR-S / Toyota 86 GT86 General Forum 3 04-13-2014 11:07 PM
FS: Cool White LED Lighting (dome, door, and trunk lights) fourvalleys Interior Parts (Incl. Lighting) 0 11-18-2013 07:55 PM
Door Rattle Issue DriftEightSix AUSTRALIA 4 06-28-2012 02:11 AM
