Old 06-25-2015, 01:38 AM   #57
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Originally Posted by xxscaxx View Post
I think 30 and up go to 4"...gtx28 is a baby turbo
The PTE B Compressor Cover (Base Turbo)is 2.75", The GTX28 Compressor Cover is 3", and the GTX30s are 4" While the space is extremely limited if you take you time you can get the filter/intake positioned without it touching anything. It does require patience
I wish I would have got a better angle
JDLAutoDesign is offline   Reply With Quote
Old 06-25-2015, 01:50 AM   #58
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
Originally Posted by JDLAutoDesign View Post
The PTE E Compressor Cover (Base Turbo)is 2.75", The GTX28 Compressor Cover is 3", and the GTX30s are 4" While the space is extremely limited if you take you time you can get the filter/intake positioned without it touching anything. It does require patience
Are the turbo specs not listed when using the page for the single scroll kit?
I'm trying to figure what I have room for.
Rybot is offline   Reply With Quote
Old 06-25-2015, 02:04 AM   #59
JDLAutoDesign
Drives: 13 FRS
Sorry typo B not E Cover. The specs are listed on each turbo manufacturers sites. There really isnt much more as far as room goes. If you have OEM HIDs or the Japanese HIDs/Headlights there is even less room
Old 06-25-2015, 07:36 AM   #60
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Use what they provide, it turns out to be the best fit and I'm sure they arrived at this design after thorough testing. I only decided to eliminate the intake pipe because i didn't use it but most would, either for crankcase plumbing or something else. Aside from this i had the wiring my for HID's kinda messy so i opted for a filter right off the turbo inlet. Its default game to play though, i had to buy two different ones and local autocrats rarely have anything good in stock. Plus JDL's stock configuration would guarantee oil cooler fitments
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-25-2015, 07:38 AM   #61
yomny
yomny's Avatar
I could confirm the filter location won't touch anything.. i had my filter installed slightly misclocked, after messing around with other filters, i reinstalled the original intake system and clocked the filter and intake pipe correctly and it was clear of everything around it.
Old 06-25-2015, 09:00 AM   #62
xxscaxx
Drives: 2013 SWP BRZ
Good to know. I only assumed the GTX28 was 2.75 because I was sent a 2.75" intake cone and silicone hose. I didn't pull the hose out of the bag yet but i'm pretty certain its not a transition hose from 3-2.75 and is just a straight. Hope it fits lol
xxscaxx is offline   Reply With Quote
Old 06-25-2015, 09:03 AM   #63
xxscaxx
How can you let that car sit for that long? It's crying for some attention. I can hear it from here.
Easy - winter, then having the car apart waiting for my turbo kit
Do we know if any of the ball bearing upgrades they offer are really any better? Faster spooling? Longevity?
I pulled this from Yomny who quoted Jesse from another thread:
Originally Posted by yomny View Post
Quote from another thread from Jesse @ JDL with regards to GTX upgrade.
"My opinion and i try to make it clear to anyone with the same question is that if you can fit the Ball bearing turbo into your budget then it is definitely worth it. The lag is improved slightly in terms of rpm's.. ( talking a couple hundred rpm's, nothing too major). The massive difference is felt in the transient response. How it builds boost on and off the throttle and in between gears. Kinda hard to measure this stuff on a dyno, more of a you have to experience it driving different setups. With that said the base turbo is still very enjoyable and the kit allows an upgrade to BB turbos down the road without changing any hardware"
The Following User Says Thank You to xxscaxx For This Useful Post:
ShadowReaper (04-07-2017)
Old 06-25-2015, 09:26 AM   #64
Rybot
Rybot's Avatar
That was my assumption. I'll probably be going with BB in any case. What turbo did they say they used on the single scroll kit? GTX28?
I couldn't find what models they used through the selection boxes on their site.
Old 06-25-2015, 09:35 AM   #65
xxscaxx
They don't give you a direct option because you can choose more than one BB turbo.
I think they recommend the GTX28 for most but I want to say you can even go with a 30, but i'd reach out and email them to be sure. Then you can choose trim sizes, i.e GTX2867r, GTX2863r, etc.
Old 06-25-2015, 11:05 AM   #66
Rybot
Rybot's Avatar
So when you purchase it, you have to specify which one you want? Wouldn't it make sense to add all the options to the drop down menu?
I don't know, it was just confusing me while picking the kit only seeing the single option of BB upgrade.
Old 06-25-2015, 11:13 AM   #67
xxscaxx
idk man Reach out to Ronnie, he will give you a hand. Not sure why they don't list their options, but I had contacted them up front first and discussed what they thought was the best turbo option and options in general and just went from there. You can probably use a vast amount of turbos which is why they don't list it, but thats just an assumption.
Old 06-25-2015, 11:24 AM   #68
JDLAutoDesign
Drives: 13 FRS
Give us a call when you have some free time. We can get these details hammered out.
Old 06-25-2015, 02:17 PM   #69
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
There's a TON of options with our kit and it allows for pretty much any upgrade in the future. It's really best to call and talk to one of us. It's a big purchase and we want to ensure that you get exactly what you're looking for.
Jesse@JDLAutodesign is offline   Reply With Quote
The Following User Says Thank You to Jesse@JDLAutodesign For This Useful Post:
Kris86 (06-27-2016)
Old 06-25-2015, 02:42 PM   #70
yomny
yomny's Avatar
Can't really say you get that flexibility with many stores out there. Pretty much a custom kit for a predefined price(almost) and yeah great service included. Just had Ronnie reach me yesterday offering to send me a replacement flange. Big thumbs up. Guys post some more pics, it makes people wanna buy stuff lol.
The Following 2 Users Say Thank You to yomny For This Useful Post:
JDLAutoDesign (06-25-2015), Kris86 (06-27-2016)
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 02:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 03:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 08:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 07:27 PM
