Old 06-23-2015, 06:11 PM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by Lust View Post
How much power would deem 18x9.5 necessary? I plan to slowly build up the motor with an end result of probably 350+ whp
Oh at 350+whp, you'll want it
I also preach getting upgrades that you won't outgrow if possible. If you're 100% sure you'll get that much power later, get wider wheels now, but know that you'll be hurting your car's overall performance in the short term.
wparsons (06-24-2015)
Old 06-23-2015, 11:18 PM   #16
Lust
Drives: 2017 Subaru BRZ
As far as supporting suspension mods go. For an approx 1-2 inch drop on 18x9.5 will there be anything else I need? I plan on ordering the parts in the OP.
Lust is offline   Reply With Quote
Old 06-24-2015, 03:28 AM   #17
CSG Mike
CSG Mike's Avatar
I'd recommend something a bit better in the damper department...
Probably won't need camber bolts at all with proper camber plates.
Bushings are usually a "all or nothing" deal; go with nothing until you get some more experience.
JoeBoxer (06-24-2015), Lust (06-24-2015)
Old 06-24-2015, 11:25 AM   #18
Racecomp Engineering
Oh boy the decisions... Just to clarify one last time, will I need the toe kit? If so, what do you recommend?
Not unless you're going really low (past 1.5 inches).
I do as well, but generally not for wheels and tires...especially for someone who's relatively new to the track. Most important part of the system, you shouldn't compromise.
Of course you would...
- Andrew
Old 06-24-2015, 02:40 PM   #19
CSG Mike
CSG Mike's Avatar
I'm not sure what you mean here... would you prefer a newer driver have smaller wheels and tires or larger?
Old 06-24-2015, 02:50 PM   #20
OkieSnuffBox
Drives: '23 BRZ Limited
I took as he meant he doesn't feel newer drivers should overtire/over-"compound" their car.
More grip can mask a lot of mistakes, which I know you're well aware of.
Old 06-24-2015, 03:01 PM   #21
Lust
Do you think I'll be fine without the camber plates for a while? I am already super close to my budget and don't think I can afford going for the Raceseng camber plates.
Old 06-24-2015, 03:20 PM   #22
BAMF86
much slow
BAMF86's Avatar
Drives: 13 Raven FRS, 05 Rio Yellow S2000
You can just run camber bolts for the time being, depending if your coils are slotted or not. You can get up to -3 negative camber in the front with RCE 0s or any slotted struts.
Ran camber bolts for a year now on the track with RCE 0s, no slipping of the bolt whatsoever
BAMF86 is offline   Reply With Quote
The Following User Says Thank You to BAMF86 For This Useful Post:
Racecomp Engineering (06-24-2015)
Old 06-24-2015, 03:33 PM   #23
CSG Mike
CSG Mike's Avatar
Swap the LCAs for Camber plates. The natural camber gain in the rear from a drop will be "close enough", whereas the natural camber gain in the front will not.
nathand (11-23-2022)
Old 06-24-2015, 03:41 PM   #24
This. Also it just feels like a dog.
- Andy
Old 06-24-2015, 08:20 PM   #25
Lust
After talking with my friend I think I'll just invest more in just suspension and run stock wheels for now. This means I'll probably go with RCE Tarmac 2s since they have the adjustable damping. I am curious though of the ride quality for DD... This also means I can get the Raceseng camber plates, SPL LCAs, and SPL toe kit. Will I want upper mounts for the rear or anything else for a good setup?
Old 06-24-2015, 08:43 PM   #26
CSG David
CSG David's Avatar
We essentially can get the whole package setup for you if you really want.
The Following User Says Thank You to CSG David For This Useful Post:
Lust (06-24-2015)
Old 06-24-2015, 08:49 PM   #27
Lust
Oh really? That'd be sweet. You have more info on that?
Old 06-24-2015, 09:46 PM   #28
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Heavier, more angular momentum
:') its like being a proud teacher watching your students give proper advice, ah so humbling ^-^
Ideal Exhaust setup cjcoupe AUSTRALIA 4 02-07-2014 07:40 AM
Ideal ride height for best suspension geometry? Hachi86Roku Tracking / Autocross / HPDE / Drifting 8 11-19-2013 07:46 AM
Different Suspension setup on BRZ? Trmx2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 11-13-2013 08:36 PM
setup of suspension jdzumwalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-21-2012 03:03 PM
Ideal CCW specs for street with occasional track bambbrose Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-11-2011 03:12 PM
