Old 05-29-2012, 04:04 PM   #1
MTeator
First 86
Speedometer Accuracy
Has anyone else tested their speedometers? With my phone GPS and those police signs on the side of the road my car registers 63mph when the speedometer says 65mph.
This is probably good for me because I'm going to a 225/45 tire which will be slightly taller than the 215/45.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 05-29-2012, 04:07 PM   #2
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
I find most vehicles are like this, my Dodges are always 4-5mph slower, my Celica and Sentra (was) is 2-3mph slower. My wife's old MX-6 was 2 over due to a larger tire size.
Also most speedo's get more off the faster you go, doing 125 in my Celica recorded 119 on my various GPS's.
michaelahess is offline   Reply With Quote
Old 05-29-2012, 04:15 PM   #3
MTeator
First 86
Yeah, Generally they're off by a percentage, not a fixed amount. I'm figuring mine is off by 3%.
Old 05-29-2012, 04:19 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Subarus tend to be universally 3mph slower at 60mph.
I just clock my car against a GPS speedometer whenever I get new tires and mentally calibrate the mechanical speedometer.
Old 05-29-2012, 04:33 PM   #5
That's consistent with what I've seen on mine when running with the GPS, and I believe is pretty standard.
Old 05-29-2012, 04:41 PM   #6
MTeator
First 86
I've found it all over the place on the cars I've owned, both up and down. My Tundra was one of the only cars I've had that it was dead on.
Old 05-29-2012, 04:52 PM   #7
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
according to GPS on my phone, car shows 65mph whereas the phone varies between 60-62mph depending on how it feels. Road side speedo signs clock me 60-61 when Im doing 65mph, so thats cool.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 05-29-2012, 04:58 PM   #8
MTeator
First 86
Now if mine was that big I'd probably worry cause of the extra miles being tacked on to your odo can get quite large.
Old 05-29-2012, 05:06 PM   #9
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Odometers and speedometers are no longer mechanically linked like the old days. Odometer checks should be performed separately from speedometer checks.
On my Subaru, the speedo will read high, but the ECU will read correctly if you are logging. As an aside, the tachometer also gets a bit ahead of itself under acceleration. Both are most likely done to protect you. The ECU generally knows what is going on, and the odometer may interpret differently or get a different signal than the speedometer.
TheRipler is offline   Reply With Quote
Old 05-29-2012, 05:21 PM   #10
MTeator
First 86
Now that's just weird.
Unfortunately I won't have any longer trips to test the odo until after I put on the new tires.
Old 05-29-2012, 05:48 PM   #11
TheRipler
Reap the BReeZe
Federal regulations mandate accuracy of speedometers. It's generally safer for the manufacturer to error on the high side, rather than have customers getting angry about tickets because it reads low.
You can do an odometer check in a relatively short distance using the posted mile markers on an Interstate or many US Highways.
Old 05-29-2012, 06:54 PM   #12
MTeator
First 86
Learn something new every day.
I took a detour on the way home and a 14 mile trip according the the mile markers on I-64 registered exactly 14.0 miles on the odo.
Old 05-29-2012, 07:01 PM   #13
AshWilliams
Groovy
AshWilliams's Avatar
Drives: GMC Sierra
Most speedos are set up to read faster because there is a good chance people will install bigger tires...
It's a common thing for pickup/4x4 owners who increase tire size and suddenly realize 75 is really 80.
Share the road.
AshWilliams is offline   Reply With Quote
Old 08-22-2012, 06:39 AM   #14
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
Finally decided to post about this...
Anyone else have a problem where their speedos are off (on the fr-s/brz). It doesn't matter what speed I'm going, but the analog speedo will read slightly faster than the digital speedo. E.g. if the digital speedo says I'm goin 35mph, the analog will read ~37/38mph. 60mph : 62/63mph, etc.....
Not sure which one to believe. I've just been using the digital one. Everything on the car is stock.
But officer, I was going both 80 And 83mph!
Propaganda is offline   Reply With Quote
An example of rumour accuracy. Dimman Scion FR-S / Toyota 86 GT86 General Forum 7 01-04-2011 09:53 PM
