#29 |
Stig's dark passenger
This is all Im able to show since the rest of our conversation was not something Im willing to share. David If possible please use a serpentine, since all our testing is done with this type of belt. As long as timing is not required we recommend s-belts for many reasons. |
| The Following 5 Users Say Thank You to D K For This Useful Post: | ATL BRZ (06-23-2015), ck-GT86 (06-23-2015), CSG Mike (06-23-2015), themajesticone (06-23-2015), zc06_kisstherain (09-21-2015) |
#30 | |
Drives: 2013 WRB BRZ
#31 |
Bilge monkey
Drives: '13 BRZ, 82 starlet
| The Following User Says Thank You to Sammakko For This Useful Post: | Sportsguy83 (09-21-2015) |
#32 | |
Drives: '13 UM86
It is plenty clear and there is no room for confusion or doubt.
![]() JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport Last edited by themajesticone; 06-23-2015 at 10:18 PM. |
#33 |
Drives: 2014 Pearl White BRZ
Wow - OP - so sorry you are dealing with an issue like this. What a total buzzkill. GL in your effort to get a stable ride.
#34 |
Drives: WRB JR BRZED
#35 |
Drives: Neptune GR86
I'm assuming this is rhetorical?
#36 |
Proud of Boxer
Seems like KW could resolve this easily enough by offering or changing the kut to a ribbe belt. However the shock explanation makes a hell of a lot of sense to this engineering student. Damn shame that kraftwerks doesn't seem to want to recognize the issue either as I believe they honestly have the superior tubing route.
#37 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Please elaborate; from what I've observed the charge piping on both the JR and KW kits follow the same route.
From the SC outlet they both route the piping under the driver's headlight down around the washer fluid reservoir with a bend feeding the intercooler and then back up under the opposite headlight and onward into the intake manifold. |
#38 | |
| The Following User Says Thank You to Andrew025 For This Useful Post: | s0sl0w (06-24-2015) |
#39 |
Proud of Boxer
That's exactly it, I'd also like to see the j/r utlize a more sealed filter. I can fix the filter quibbles myself. Not much I can do about the curve ahead of the TB.
#40 | ||
After looking at the dyno comparisons between the kits and understanding how they both measure airflow and manifold pressure again I don't see anything superior about the routing of the KW kit's charge piping. Quote:
If you're really that worried about it and have money to burn then you can buy what Pure made for the Vortech kit. Should be relatively easy to adapt or put your own together.
#41 |
Proud of Boxer
If you looks at the exhaust data, the Kraft kit makes almost all of the power of the JR but is doing it with a cat back and 2 cats in play vs the JR car having no cats and "full exhaust" (header?). Since the tuner and gas was the same and they use the same blower that pretty much leaves the tubing. Kraft has placed the blower and filter better (more efficiently) but then fucked it all with belt/pulley setup. Ideally a Kraft kit with non cogged pulleys/belt would be the best I'd hazard.
#42 | |
I don't think the tubing will make much of a difference either.
| Tags |
| forced induction, kraftwerks, supercharger |
| Wtb: kraftwerks supercharger | darnbry | Want-To-Buy Requests | 1 | 08-31-2014 02:04 PM |
| F/S Kraftwerks supercharger kit | captain_jack | Engine, Exhaust, Bolt-Ons | 27 | 06-10-2014 10:34 AM |
| Kraftwerks Supercharger kit-Now stocked at JRP | Stav | Canada Classifieds | 4 | 05-27-2014 09:07 PM |
| KraftWerks SuperCharger | Ocho Seis | CANADA | 18 | 04-06-2014 10:33 PM |
| Kraftwerks Supercharger?? | umpadupa | Forced Induction | 1 | 08-05-2013 05:27 PM |
