Old 06-17-2015, 11:53 PM   #127
toby714
Drives: whiteout
i have the splash standard hub and i installed the resistor exactly like this guy in the video:
[ame="https://www.youtube.com/watch?v=-8IucJHAl3s"]FT86Speedfactory - FRS & BRZ Aftermarket Steering Wheel Install - YouTube[/ame]
the airbag light is still on and my horn doesnt work. i have personal grinta 330 wheel.
any help would be appreciated. i notice that works bell has two resistor compared to the splash, which only has one
toby714 is offline   Reply With Quote
Old 06-18-2015, 01:51 AM   #128
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Factory airbag wiring has two, make another resistor like i did. The video from ft86sf is wrong
Here is my. DIY: http://www.ft86club.com/forums/showthread.php?t=86415
. ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following User Says Thank You to ck-GT86 For This Useful Post:
toby714 (06-18-2015)
Old 06-18-2015, 11:07 PM   #129
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
. ck
Hey can the blue resistor that is included with the hub can be swapped in the black harness? Ex. If two blue resistors are used.
Old 06-18-2015, 11:10 PM   #130
ck-GT86
ck-GT86's Avatar
Yep, the components underneath the heat shrink are the same.
|| My Build Thread ||
NyC Zn6 (06-18-2015)
Old 07-09-2015, 01:02 AM   #131
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
i'm having issues with my horn i have the splash hub how do you connect it?
Old 07-09-2015, 03:41 AM   #132
ck-GT86
ck-GT86's Avatar
Which steering wheel do you have? Can you post a backside picture of the horn button?
. ck
|| My Build Thread ||
Old 07-09-2015, 12:46 PM   #133
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
. ck
It's a grip royal wheel and horn/wheel. I just don't know where to connect the ground. Name:  ImageUploadedByTapatalk1436456805.123763.jpg
Old 07-09-2015, 12:50 PM   #134
NyC Zn6
NyC Zn6's Avatar
connect the ground to the hub between the hub(in front) and steering wheel(behind). That's how I got my Personal horn to work.
Old 08-25-2015, 09:01 AM   #135
smudge
Drives: Supercharged GT86
Sorry if this has been asked/answered before, but does the Works Boss hub come with the ability to keep the cruise control stalk?
And just want to double check I'm reading this right, I can use the Works Boss hub with an NRG quick release?
Thanks
smudge is offline   Reply With Quote
Old 08-25-2015, 09:31 AM   #136
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Aftermarket steering wheel..
Thanks
You can not use the cruise control with works bell out of the box. But can with a custom bracket and some modification.
You can use an NRG quick release with the works hub but I'd recommend the short hub or else it will be out further then your oem wheel position.
The Following User Says Thank You to ZOMFGAARON For This Useful Post:
smudge (08-25-2015)
Old 08-25-2015, 11:16 AM   #137
smudge
Thanks very much now just to get a peak at how these custom brackets look
Old 08-25-2015, 11:44 AM   #138
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
Someone make a diy for cruise control
Sent from my LG-H812 using Tapatalk
Scalzo is offline   Reply With Quote
Old 08-25-2015, 04:25 PM   #139
smudge
Looks like a small bracket needs to be made up
Old 08-25-2015, 06:17 PM   #140
Scalzo
Scalzo's Avatar
I'm not good with that shit , make a diy :O
The Following User Says Thank You to Scalzo For This Useful Post:
smudge (08-26-2015)
steering wheel controls inimitable BRZ First-Gen (2012+) — General Topics 79 09-05-2016 01:56 AM
do you want steering wheel buttons? Spaceywilly BRZ First-Gen (2012+) — General Topics 125 04-09-2012 09:46 AM
That steering wheel poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 26 12-04-2011 01:16 AM
Anybody not liking the steering wheel? Levi BRZ First-Gen (2012+) — General Topics 40 12-03-2011 11:43 AM
FT-86 concept's steering wheel Dark Scion FR-S / Toyota 86 GT86 General Forum 35 08-07-2010 07:17 AM
