Old 06-16-2015, 04:15 AM   #29
ducky369
Drives: 2014 Frs
Put Car in Reverse While Going 15mph
Originally Posted by AznBRZer View Post
Ok, I tried it and apparently, you CAN "row" the shifter through the gate with no problem. You can go from R-N-D and back without stepping on the brake. You can even put it in P without hitting the brake too. I'll try taking it out of P without the brake tomorrow.
But can you go from D to P or R doing 10mph? I think it locks when you are over 5 10 15 mph or something
Sometimes I can't get it to go R without being in full stop
ducky369 is offline   Reply With Quote
Old 06-16-2015, 03:45 PM   #30
FirestormFRS
Modern AT's will not engage reverse internally if the car is moving forward at speed. The shifter may go into the gate but the transmission will not.
FirestormFRS is offline   Reply With Quote
Do you have VALENTI Reverse Bar + Reverse cam? *SOLVED tiz22 Electronics | Audio | NAV | Infotainment 16 07-18-2017 01:36 PM
Debate: Reverse in or reverse out. paulca Other Vehicles & General Automotive Discussions 31 07-21-2014 10:56 PM
Reverse LED? nbafandan Cosmetic Modification (Interior/Exterior/Lighting) 5 02-23-2013 06:30 PM
Reverse LED's Cajun Cosmetic Modification (Interior/Exterior/Lighting) 50 01-22-2013 02:44 AM
Reverse JayWoop Scion FR-S / Toyota 86 GT86 General Forum 21 11-01-2012 01:13 PM
