View Poll Results: Is the chattering engine sound normal when accelerating in 2nd gear at 1500-2000rpm?
Yes, the sound is normal. (please explain what the sound is) 19 44.19%
No, you should slip the clutch a bit 11 25.58%
None of the above. (tell me what is right below ) 13 30.23%
Voters: 43. You may not vote on this poll
Old 06-11-2015, 02:10 AM   #43
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
The chattering/rattle is NOT perfectly ok. You are interpreting the engine's struggle correctly. It's universally bad technique and I'm surprised at many people's responses here.
Are you ruining your engine? Not exactly. Not right away, at least[/U]
I wouldn't want my advice being confused with trying to purposely put a load on the motor when you can hear any struggle btw, purpose of my last post in this thread. The point is to know how to drive your car more intimately. You can slowly work out of low rpms but with the motor wanting to bring itself back to speed without a severe enough load, aka a significant knocking noise to warrant concern for locking anything up on these modern motors. However, you should be able to feel when you are beyond that gears usefulness and the clutch is needed, which is a more disposable wear and tear item than some others.
Perhaps I'm misinterpreting people's description of noises because I'm assuming everyone's being dramatic with sounds these days. You can hear the motor work differently at all stages of stress.
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
Ultramaroon (06-11-2015)
Old 06-11-2015, 02:54 AM   #44
Hell, I was being dramatic. "many people?" Duh.
To your point though, this car is super chatty but that's a great thing. Lots of opportunity to hone those M/T skills.
OP questioned going uphill with passengers in second at low speed. That's definitely first gear territory. I detest having to come to a full stop just to get into first.
Double-clutching is just another option. Options are good.
Toyarzee (06-11-2015)
Old 06-11-2015, 07:33 AM   #45
Teseo
Drives: frs
Originally Posted by awhatzable View Post
Sometimes I can't slow down to down shift to first because of traffic behind me and its unnecessary to slow all the way down ahead.. I can't be slowing down to first gear at every turn especially round abouts that I can just enter without the need to give way to anyone.
Does your car make noise from 1500-2000 in 2nd gear when feathering the gas ? If so, Do you drive it with the noise or do you slip your clutch ?
2nd gear at 2000 rpm is "ok" just dont slam the gas pedal and slipping the clutch its unnecesary.
Also dont look much your mirrors if you have ppl behind you. Dont pay attention when they honk at you for driving slow (happen to me in shitty roads) and pay attention on what you are doing. Keep calm and live mas
The Following User Says Thank You to Teseo For This Useful Post:
Ultramaroon (06-12-2015)
Old 06-11-2015, 01:02 PM   #46
Tromatic
OP, post mileage when you need a new clutch.
The Following User Says Thank You to Tromatic For This Useful Post:
Tcoat (06-11-2015)
Old 06-11-2015, 01:09 PM   #47
Tromatic
Im in 2nd gear... and im not moving slow enough to down shift to 1st gear!!
Well, if you are at 2K in second and lugging, shifting to first would put you at approx 3200. Shift the thing, that's why the lever is there. The source of this issue is you, nothing else. Why abuse the drivetrain when you don't have to?
JohnJuan (06-11-2015)
Old 06-11-2015, 01:28 PM   #48
Don't make me bust out my A/T jokes.
Old 06-11-2015, 01:49 PM   #49
awhatzable
Drives: GTS86
You can't down shift from 2>1 at 2000 rpm in 2nd gear.
awhatzable is offline   Reply With Quote
Old 06-11-2015, 02:02 PM   #50
awhatzable
Drives: GTS86
The chattering/rattle is NOT perfectly ok. You are interpreting the engine's struggle correctly. It's universally bad technique and I'm surprised at some people's responses here.
Are you ruining your engine? Not exactly. Not right away, at least. I've become more comfortable operating at stupid low RPM because this engine still makes pretty good oil pressure down low.
So, what's happening? At low RPM the engine does not rotate smoothly. It's much worse when asking it for any real power. The little pulses feed into the transmission where, although only one pair of gears is coupled to the output shaft at any one time, they all rotate all the time. The rest of the gears all have a little backlash so they chatter.
I drive in shitty rush hour traffic every day. The first gear lockout is really aggressive. It is impossible to downshift into first above maybe 5 Km/h - walking speed.
So, what do we do?
1. In second gear, from 1000-2000 RPM, very gently ask the engine to accelerate. I'm comfortable with stomping on it above 2K.
2. Get into first but never force it. Especially if you are going uphill, get into first. Learn to double-clutch. Fuck the naysayers. Learn to double clutch.
Is double clutching down to gear 1 better for the clutch than just staying in 2nd and slipping the clutch?
Old 06-11-2015, 04:28 PM   #51
Far better. Night and day.
And to be clear, I'm not talking about some F&F showoff move. It's just a blip to spin up the input shaft before engagement. Not too much or you end up pressing the gearshift against the syncro waiting for it to spool back down. That ends up being tough on the syncro. You'll get the feel for it.
awhatzable (06-12-2015), JohnJuan (06-11-2015)
Old 06-11-2015, 11:57 PM   #52
Tromatic
Go ahead.
In a MT?
Old 06-12-2015, 12:25 AM   #53
Go ahead.
Fuck. I don't have any.
Old 06-12-2015, 01:58 AM   #54
JB86'd
JB86'd's Avatar
Drives: JAWS
From what I've gathered slipping the clutch briefly and especially at low rpms isn't going to have any ill effect on your car. Clutches aren't a perfectly "ON/OFF" mechanism for a reason. Even if it does cause slight wear over the lifetime of your car..the clutch is a wear item.
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Old 06-12-2015, 02:17 AM   #55
Tromatic
Or shift into a more appropriate gear. Too hard, I guess. OP gives the impression he does it all the time.
Old 06-12-2015, 02:46 AM   #56
No, Trom. It's impossible to shift into first gear above 4-ish MPH without double-clutching into it. But you wouldn't know that because you have the auto.
2nd gear grind while slowing down NO clutch Muskokan Issues | Warranty | Recalls / TSB 12 07-18-2017 01:35 PM
What's this clunk sound coming from 2nd gear after letting go of the clutch ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 17 04-30-2015 02:14 AM
Limited Slip diff oil Motul GEAR 300 LS 75W-90 FRSToyota86 Canada Classifieds 12 08-22-2014 12:47 PM
clutch/gear box getting softer zERoTu Issues | Warranty | Recalls / TSB 3 06-05-2014 08:18 AM
Display current gear without clutch engaged? cfusionpm Scion FR-S / Toyota 86 GT86 General Forum 45 03-26-2013 04:08 PM
