Old 04-14-2015, 10:13 PM   #155
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
You're taking that statement way too seriously lol. My point was replacing the awesome sounding top speed with something that looks identical but has aligned tips.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
ck-GT86 (04-14-2015)
Old 04-22-2015, 02:02 PM   #156
pepe
Drives: gt86
Hello!I have this axleback ... and I doubt change the midline by a midline resonated but 2'5 "diameter ...
you who gains the depth in the sound think?
you advise me to do this installation?
thank you very much!
pepe is offline   Reply With Quote
Old 06-10-2015, 11:31 PM   #157
B-R-Z
B-R-Z's Avatar
Has anyone gotten their tips to align with messing with hangers or bending pipes? I'm itching to replace this thing. As much as I love the look and sound, the uneven passenger side tips annoys my OCD. Might go with the Greddy SP Elite.
Anyone with exhaust fabrication experience, if the pipe is heated, can it be bent?
Old 06-10-2015, 11:43 PM   #158
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Don't bend the pipe, bend the hangers. I just used pieces of rubber hose and zipties on the hangers to force them closer. The right way is to bend the hangers though.
KoolBRZ is offline   Reply With Quote
The Following 3 Users Say Thank You to KoolBRZ For This Useful Post:
B-R-Z (06-11-2015), Respect BRZ (06-07-2016), Strife26 (06-10-2015)
Old 06-11-2015, 12:28 AM   #159
B-R-Z
B-R-Z's Avatar
I thought about that too.. I think someone in the past mentioned using fuel injector clamps on the metal bar to change where the rubber hanger sits on the metal bar.
Were you able to fix it decently? Any pics?
Old 06-11-2015, 01:52 AM   #160
KoolBRZ
KoolBRZ's Avatar
It's real close. It's dark out. I'll take pictures tomorrow. I spent about an hour cutting hose and hose-clamping them. It's about the same side-to-side, but the passenger side sticks out further. That will require bending the hanger.
Old 06-12-2015, 08:03 PM   #161
KoolBRZ
KoolBRZ's Avatar
Pictures
Here's a top view showing the right tip sticking out .25", rear views showing hole spacing, and under views showing rubber spacers used to align it. It's close without spending a lot of time or money. I'm fine with it.
Old 06-13-2015, 02:08 AM   #162
steve99
Drives: FT86
http://m.ebay.com.au/itm/390678669999?nav=SEARCH
use some appropiate size rubber gromets to pack out hanger
Old 06-13-2015, 02:47 AM   #163
B-R-Z
B-R-Z's Avatar
Was thinking of using hose clamps to be more secure
Old 06-13-2015, 11:38 AM   #164
B-R-Z
B-R-Z's Avatar
Thanks @KoolBRZ, do you have a pic from 10-15 feet away?
Old 06-13-2015, 01:07 PM   #165
KoolBRZ
KoolBRZ's Avatar
Not yet. Maybe later today, with a video.
I tried grommets and hose clamps. The grommets weren't stiff enough, and the hose clamps to hard to tighten. I used split 3/8" fuel/hydraulic hose, and the black zip ties, because they are more UV resistance.
use some appropriate size rubber grommets to pack out hanger
Please, somebody buy Steve's grommets. He needs to make a car payment.
The Following User Says Thank You to KoolBRZ For This Useful Post:
B-R-Z (06-13-2015)
Old 06-13-2015, 02:11 PM   #166
B-R-Z
B-R-Z's Avatar
I was thinking something like this http://pages.ebay.com/motors/link/?n...444119&alt=web
Old 06-13-2015, 02:29 PM   #167
KoolBRZ
KoolBRZ's Avatar
I wouldn't use that clamp for the following reasons.
1. I wouldn't want the sharp edges to cut the hanger donut, possibly causing failure.
2. I wouldn't want to tighten or loosen a hose clamp that hasn't got a hex head to use a socket on. Since I can use a flex extension to get into tight spaces.
3. Nobody's going to look at it, so why not use a zip tie? It's easy to install, just pull tight and trim. It's easy to remove, just stab it with something sharp.
4. Zip ties are much cheaper than hose clamps.
5. The short pieces of fuel line are rubber, so they can flex with the donuts, then push back into alignment. You can set it once and forget it.
Old 06-14-2015, 01:28 PM   #168
B-R-Z
B-R-Z's Avatar
Do you have a lot of confidence in zip ties that are getting battered by the conditions? I live in the northeast where salt is laid heavily on roads in winter.
Those clamps I posted, it appears I could get a stainless steel screw with a hex head. Maybe wrap the hanger in rubber then secure it with the clamp, as you did with zip ties
axleback, ebay, pro-1, top speed auto
FS (NY): OEM axle back exhaust abutterman Engine, Exhaust, Bolt-Ons 7 06-13-2016 10:47 AM
FS: custom axle-back exhaust rondeezy Engine, Exhaust, Bolt-Ons 5 04-07-2013 06:08 AM
Axle back exhaust BMWDavid Engine, Exhaust, Transmission 1 12-15-2012 10:41 AM
Custom Axle back Exhaust Do Boy Engine, Exhaust, Transmission 13 08-19-2012 08:54 AM
