Old 05-24-2012, 02:27 PM   #99
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Call has been made..
Bill
Scooby South is offline   Reply With Quote
Old 05-24-2012, 03:29 PM   #100
ubersoph
Heh, aren't we going to be in ASP or something anyway this year? Guessing you're running Milwaukee SCCA?
Btw, do you have your car yet? I wanna see the white this Saturday!
ubersoph is offline   Reply With Quote
Old 05-24-2012, 07:33 PM   #101
Scooby South
Conedancer
I will be doing some Milwaukee events...but more Eau Claire and Minni area..
Bill
Old 05-24-2012, 08:06 PM   #102
Scooby South
Conedancer
well...looks like the suspension might come to fruition as long as the concerns will.be addressed...Wahoooooo..
Old 05-24-2012, 08:16 PM   #103
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Shit I may come up and run in Mill if you are going to have the car up there. Still waiting on mine. I know a few of my buds from chicago will be up there. need some help with lug choices if you have time. So I can run my autocross wheels.
http://www.ft86club.com/forums/showthread.php?t=6900
feldy is offline   Reply With Quote
Old 05-26-2012, 03:10 PM   #104
Scooby South
Conedancer
Originally Posted by Scooby South View Post
Ok...I need some opinions....I have the opportunity to purchase some OMG No Kidding Real suspension for some decent money...New these were around $5500...They are custom Valved, Billet Dual Adjustable: Rebound And Compression, Custom Camber plates. Inverted front struts with all the goodies...They are Custom Built KONI 2812's..
If you could...would you??? thanks for the input..
Bill
Well ...I am pulling the trigger on these.......I can't wait to get them going ... ..In case you didn't make the connection...
These...Came off of This:
They have a couple of modifications to do to make them work on the BRZ/FRS...like the Mounting tab for the Front Sway bar...that and making sure the valving and spring Rates. are where they need to be.....Soooo Excited..
Bill
Old 05-26-2012, 07:55 PM   #105
Dimman
Kuruma Otaku
Dimman's Avatar
Are the lower brackets for the struts removable?
I haven't had a good look at how the front bar mounts to the struts. Just this:
In this pic the stock ones look like they mount higher than the bracket. The links also look pretty flimsy. If shorter links will work, will you weld lower?
Post pics of your solution. Thanks.
Because titanium.
Old 05-26-2012, 07:59 PM   #106
Scooby South
Conedancer
Better Pic for you..
Old 05-26-2012, 08:03 PM   #107
Dimman
Kuruma Otaku
Dimman's Avatar
Thanks. That link looks like a toothpick...
Because titanium.
Old 05-26-2012, 08:04 PM   #108
Scooby South
Conedancer
supposedly...Brian At AST said they have something that might work...I will have to see when its time...Definitely will post the updates....
Bill
Old 05-26-2012, 08:23 PM   #109
Scooby South
Conedancer
BMW's and Saabs have a similar setup..
Bill
Old 05-27-2012, 08:59 AM   #110
feldy
feldy's Avatar
Can't wait for you to try your wheel set up. I'm hoping it works as its the same wheel specs that I was looking at. Worried about the 245 in the front as soon as we add -2degrees on camber the tire at the top will be much closer to the strut.
Old 05-27-2012, 09:27 AM   #111
Scooby South
Conedancer
not if you use plates....then you will gain clearance as it moves the whole strut inward...the camber bolts only adjusts the hub bringing it closer to the strut.....make sense???
Bill
Old 05-27-2012, 09:40 AM   #112
feldy
feldy's Avatar
Not sure that I will be going that route right off the bat. that's why I'm worried. Are you going to try and fit the wheels on the stock spring and shocks first? Coils are not in the budget this year. Plates maybe if they work good with the stock setup.
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
