| CANADA Canada |
#29 |
Sarcastic SOB
I have read that high ZDDP levels sometimes damage the cats.
#30 |
AMSOil in motor last 2 changes i do have amsoil gear oil for the dif and tranny but not in any hurry to change that right now.
#31 |
Drive From Home
Drives: BRZ STI Performance
Ah okay that explains that rotten egg smell I used to get after an oil change.
![]() I've read that competition oils like Motul 300V is really bad for the cat. Had no choice cuz the early VAG 2.0T came with a flat tappet cam follower and without adequate ZDDP the high pressure fuel pump will punch a hole thru it, destroying the camshaft lobe in the process. That engine also tend to burn a lot of oil when running Mobil 1 0W40 or Castrol SLX 5W40 compare to Motul 8100 5W40. FA20 I think Mobil 1 0W40 should be okay since this engine doesn't burn oil even with a light oil like 0W20. I think Mobil 1 always comes out all black during an oil change which to me means it holds dirt very well in suspension. I understand Mobil 1 also comes in a 5W50 weight. Last edited by krayzie; 06-01-2015 at 03:45 PM. |
| The Following User Says Thank You to krayzie For This Useful Post: | wbradley (06-01-2015) |
#32 |
Drives: 2016 Scion FR-S
How is that RP in your trans and diff so far? Planning on trying RP for my trans and diff also.
| AT Trans Shift Knob Replacement | sapphire | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 11-15-2012 12:08 AM |
| How many hp more can the AT trans handle? | K-R | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-18-2012 02:21 PM |
| Sat Aug. 25th, Trans Am Nationals Cruise In | oops86 | Other Vehicles & General Automotive Discussions | 1 | 08-09-2012 11:09 PM |
| Greddy Oil and Diff Cooler | pdreams | Engine, Exhaust, Transmission | 3 | 06-13-2012 09:41 PM |
| Launch control with auto trans | Dbringer | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 06-12-2012 05:54 PM |
