Old 06-10-2012, 05:36 AM   #1
Smokinbuffalo
BRZ Owner
Smokinbuffalo's Avatar
Drives: SWP Ltd MT BRZ, Scion xA
Alarm System on the Limited
Have any of you played around with the alarm system yet? I was reading up on it (owner's manual pg 81).
Setting the alarm system
  • Lock the doors using the "keyless access" entry function --- Button on key
  • Lock the doors using the remote keyless entry system. --- Sensor on door
  • Lock the doors from the outside without using a key (pg 44) --- Manual lock nub
The system will be set automatically after 30 seconds or more elapse.
The indicator light changes from being on to flashing when the system is set.
And then this is on page 82.
Activating/deactivating the alarm system steps
  1. Check that both side doors and the trunk lid are closed
  2. Turn the push-button ignition switch to "ON" mode.
  3. Open the driver's doorwhile pressing and holding (unlock icon) on the power door lock switch and continue to press (unlock icon) for approximately 10 seconds after the driver's door has opened.
I followed the instructions on page 81 and thought it was all set up. But then I read the steps on page 82, and did that. Whatever I did seemed to work. The alarm went off when I tried to unlock the doors manually from inside.
Anyone else try this out yet? How'd it go?
Buy the ticket, take the ride
Smokinbuffalo is offline   Reply With Quote
Old 06-11-2012, 01:15 AM   #2
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
Is it supposed to alarm when you unlock your door from inside? Seems not right..
mechaghost is offline   Reply With Quote
Old 06-11-2012, 01:18 AM   #3
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
It will go off whenever the door is unlocked using anything but the key fob. This I how it's been in every car I've owned. FWIW the dealer can set it so that the key being used in the door doesn't set the alarm off, but it will still go off if you set the alarm while in the car and open it using the door handle.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 06-11-2012, 01:21 AM   #4
mechaghost
mechaghost's Avatar
even if you use the unlock all doors button?
Old 06-11-2012, 01:22 AM   #5
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
No. Actually not sure if the alarm is set it might... never tried it before. Basically if the car doesn't beep and flash it's lights then you haven't disarmed it and it will go off.
Edit... Actually it does. I've locked my keys in my car before and gotten it out by pushing the unlock button with a stick. This set off the alarm. I've also been too lazy to take out my keys and pushed the unlock button through an open window and this also set off the alarm. Haven't tried this on the BRZ though.
Old 06-11-2012, 01:23 AM   #6
Smokinbuffalo
BRZ Owner
It will go off from the inside if unlocked via the knob. The manual warns about leaving someone in the car with the doors locked because it will go off if they try to get out. I was able to unlock using the door switch without setting it off.
Old 05-29-2015, 09:09 PM   #7
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
is there a way to kill the ignition if someone drives away without the key? (carjacking scenario)
Sammakko is offline   Reply With Quote
Old 05-29-2015, 09:29 PM   #8
swarb
No. Built in safety feature so if the key runs out of battery the car stays on.
Old 05-29-2015, 09:31 PM   #9
swarb
So I have the alarm activated on my brz (alarm light goes on) but I tried to set it off by someone locking the car while I was in it and I unlocked the car and opened the door but nothing happened. Any ideas?
Old 05-29-2015, 10:08 PM   #10
BRZnut
Drives: BRZ DGM Limited
make sure you have it really turned on. (page 82 of the manuel) .The alarm comes set to off from the dealer.
Also, make sure the key fob is nowhere near the car when you open the door.
Old 05-29-2015, 10:17 PM   #11
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Let's try again !!
N1rve
alarm, keyless entry, lock, push button start, unlock
Touch nav system! madfast Electronics | Audio | NAV | Infotainment 102 09-03-2013 02:48 PM
Delete driver01 Electronics | Audio | NAV | Infotainment 20 01-31-2013 02:02 AM
86 Sound System Skorov AUSTRALIA 25 05-09-2012 04:51 PM
Oil System? swift996 BRZ First-Gen (2012+) — General Topics 5 04-13-2012 09:44 PM
BRZ Limited adds Security System.. What? Sportsguy83 BRZ First-Gen (2012+) — General Topics 49 04-07-2012 11:49 AM
