Old 05-28-2015, 12:41 AM   #449
Bobblehead
Bobblehead's Avatar
Drives: 2013 BRZ (gone) 2016 Ford Fusion SE
I took two more datalogs, same stretch of road, same map, just this time at night. Yesterday the car almost felt like it pulled timing going up a hill, tonight is the earliest I could check it.
Run 1: 4th gear, AC on.
http://www.datazap.me/u/bobblehead94/run2?log=0&data=1
Run 2: 3rd gear, AC off.
http://www.datazap.me/u/bobblehead94/run3?log=0&data=1
It seems like the engine is running a touch lean? 11.25AFR at WOT?
Bobblehead is offline   Reply With Quote
Old 05-28-2015, 05:49 AM   #450
steve99
Drives: FT86
Originally Posted by bspec View Post
Hi there.. I'm trying to scale my MAF for an AEM airbox + HKS duct, and I'm getting something funky out of the YIKES spreadsheet. I'm still using the AEM in-line MAF module, which I think might be causing an issue, but thought I'd check here first.
When I go to publish new MAF scaling, I get an error 'MAF g/s Values must change at a positive rate'. All of the suggested cor % values are negative or 0.
I'm on OFT v2.066 stage 1 91oct tune.
Here's a recent datalog, FWIW (probably very little).
http://datazap.me/u/bombino/oft-ots-...0?log=0&data=1
Thanks very much
1. Use the VGI utility not the yikes spreadsheet, the vgi utility is very easy to use, see links below
2. If the AEM intake is the one that comes with that electronic device to fool maf sensor get rid of the electronic box and just scale maf without it.
3. use AFR for your measurements not Wideband AFR unless you have installed the correct wideband senso/controller in the second 02 position
Old 05-28-2015, 09:54 AM   #451
steve99
Drives: FT86
Its actually running Rich over about 6400 its pegged at 11.25 which is the rich limit of the 02 sensor scaling so its might be even richer than that.
As per the OL Fuel table below should be around 11.7 over 6400.
you could fix it with maf scaling but its not really going to hurt anything.
low afr numbers = richer
their is virtually no knock in either of those logs
Bobblehead (05-28-2015)
Old 05-28-2015, 10:22 AM   #452
Shady195
Drives: '13 10 Series FRS #1203
Here is a log from last night. I apologize its about 15 minutes worth or so after I was done fixing an issue I was having with tactrix logging.
Its the OFT Stage 2 EL 93 tune.
I think it may be a little rich at WOT and I only noticed a little knock correction at the start as I started driving. I think it looks decent otherwise? However I'm just finally getting familiar with looking at these things and understanding them.
I think my ST/LT Fuel trims are okay too? That is what I was most interested in when I logged due to not being sure if I had a leak at my header or not.
http://www.datazap.me/u/shady195/log-1432779782
Shady195 is offline   Reply With Quote
Old 05-28-2015, 10:51 AM   #453
steve99
Drives: FT86
Read links below on logging maf scaling and Knock correction
You IAM is dropping due knock. Their is some knock shown in that log -1.3 flkc arround 6300 occurred a couple of times.
But their was some knock before that log started that has dropped your IAM to 0.86. In that log IAM climbing back towards 1 where it should be.
Try and catch the knock that dropping your IAM its probably around 2000-3500 rpm
AFR looks ok , bit on the rich side higher rpm (needs Maf scaling to fix)
LTFT look ok so you probably only need to do OL maf scaling.
It ok and nothing is going to blow up.
Maybe try some different brands of petrol some are better than others.
Old 05-28-2015, 12:11 PM   #454
Bobblehead
Bobblehead's Avatar
Oh, lower AFR = RICH. Learned something new today haha.
All I have in the way of an intake is a K&N Panel filter, and a Blitz intake tube. Is that enough to make it run so rich? I thought that would lean it out a little.
Old 05-28-2015, 01:14 PM   #455
steve99
Drives: FT86
My intake is stock and mine ran rich (well it used too) , on oft tune. Appears their are some differences in MAF sensors
Old 05-28-2015, 01:31 PM   #456
Bobblehead
Bobblehead's Avatar
Okay, so it looks like MAF scaling is needed. Any tips and tricks or anything I should look out for/avoid?
Old 05-28-2015, 02:21 PM   #457
bspec
A man
Drives: 14 BRZed
Appreciate the reply.
I was plugging data into both the VGI utility and yikes in parallel.. I'll dump the spreadsheet then. Thanks
I did bypass the AEM in-line MAF thing, and unexpectedly, the ECM is no longer throwing a Po170/172 (rich fuel bank 1), which was the reason for trying to scale MAF. Car does feel a little sluggish though so it's likely still running rich at low RPM, with low air-speed.
I'll ditch the Wideband AFR metric as well, thanks.
bspec is offline   Reply With Quote
Old 05-28-2015, 02:42 PM   #458
steve99
Drives: FT86
just use the VGI utility it has help pages as well
see maf scaling link below
Old 05-28-2015, 02:47 PM   #459
Shady195
At the .8 on the IAM was right after i started the car and as it warmed up is where it seemed to settle off at .955 and thats where it stayed.
I thought the FLKC was the learning correction that kept the motor from actually applying the knock correction IE FBKC?
Old 05-28-2015, 02:51 PM   #460
steve99
Drives: FT86
Have a read of the knock correction link below
or here
http://www.ft86club.com/forums/showthread.php?t=61820
also have a look at romraider site
http://www.romraider.com/forum/topic1840.html
Old 05-28-2015, 11:50 PM   #461
P5yk0t1c
Drives: 2014 FR-S
I have been reading a bit about the altitude where I am and there are a few people that say running the 93 maps on 91oct can be ok up here. So I decided to load up the Stage 2 UEL BPB 93 map and give it a shot. These are the first 3 logs that I have taken....after looking at these, I believe my car runs better than it did on the 91 map.
Can someone have a look at these and let me know if I am wrong?
1. http://www.datazap.me/u/p5yk0t1c/first-0?log=0&data=1 (IAM=1, FLKC=0, Knock corr.= 0)
2. http://www.datazap.me/u/p5yk0t1c/second-0?log=0&data=1
3. http://www.datazap.me/u/p5yk0t1c/dee...0?log=0&data=1
P5yk0t1c is offline   Reply With Quote
Old 05-29-2015, 01:42 AM   #462
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I'm on Stage 2 91 UEL Tune. Before I started to modify tables & what not, I've seen my IAM go as low as ~.30 IAM that is how bad 91 octane is. I've seen that much knock just running the Stage 1 91 Tune (w/o headers) & similar numbers on the Stage 2 91 UEL Tune, unmodified.
For any SOCAL people, this is what I'm running. Run @JB86'd timing first but if you get more knock, this is pretty much where I ended up.
Stage 2 91 UEL Tune, modified to the tables below. I've seen the least amount of knock with Chevron, Shell was a bit more knocky for me. I've logged alot on this revision & IAM doesn't drop much anymore, my last canyon run it went down to .95 climbed back to 1.0 pretty quickly. In hotter weather, you are gonna get more knock regardless.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 02:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 10:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 05:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 10:27 AM
