Old 05-26-2015, 02:59 PM   #1
Byrd
Drives: 2013 BRZ Limited
I'm getting a supercharger! Will my car be ready?
Automatic transmission
Conclusion: for cooling with a Jackson racing supercharger I'm going with a stark automatic transmission cooler, Jackson racing oil cooler, catch can and check valve.
Byrd is offline   Reply With Quote
Old 05-26-2015, 06:39 PM   #2
DAEMANO
Time Traveller
Get catch cans and oil cooler. If you end up with a lot more power, you might need more tire too and in that case, perhaps more brakes. Suspension mods not required, but are more of a nice to have at this point.
Old 05-26-2015, 06:52 PM   #3
gramicci101
Off Topic
Originally Posted by Byrd View Post
I'm going with either the Jackson Racing or Vortech.
-Oil cooler that comes with Supercharger
Neither system comes with an oil cooler. Jackson Racing has an oil cooler that you can purchase separately, if that's what you're referring to.
Old 05-26-2015, 09:21 PM   #4
Byrd
Yea man I meant the Jackson oil cooler
Old 05-26-2015, 09:42 PM   #5
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Get some headers. Maybe some forged internals, better fuel pump, and larger injectors. Custom dyno tune will help, too.
MS, CSCS, TSAC-F, CPT
Old 05-27-2015, 05:22 AM   #6
kbogarto
Drives: 2013 BRZ limited WRB
Go jacksons. Also I think if you run e85 you will probably need bigger injectors.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 05-27-2015, 06:21 AM   #7
Calum
That Guy
Drives: 2013 asphalt FRS MT
Automatic Transmission
I'm going with either the Jackson Racing or Vortech. My goal is not to be the best on the track, but to have a blast without breaking or overheating. I'll make it easy and show you my list of mods; If any of these mods are extras and not really needed for the longevity of my engine please let me know, as well as suggesting other parts.
***Maximum of 6 track days a year + beginner autocross + shit loads of mountain runs***
Currently Own:
-Perrin Lightweight Crank Pulley
Not required, and very little will be gained from this.
-Borla catback Exhaust
-Borla fp / op (catless)
You'll likely gain a couple of horsepower from this, but it's not required.
Going to buy:
- Bilstein B14 Coilovers
Cool, but not going to effect the engine
- Flex Fuel Kit
Good idea.
-Stage 1 or 2 Brake package (ft86speedfactory)
Very little will be gained from this, if anything. It might increase brake pedal stiffness, but it wont be noticably more effective on track.
-Catch Can
Good idea.
-Sway Bar
Just one? Which? Increasing just the rear sway bar is not a good idea on this car. On others it certainly is, but not so much here. Try the suspension section for a more detailed explaination.
I know you answered this, but just to make sure, there will be an oil cooler for the superchager itself. This does not cool the engine's oil. You'll end up with two oil coolers, but the one for the engine is an additional purchase.
&& get everything ECUTEK tuned of course
I added my .02. Take it for what it's worth.
Old 05-27-2015, 08:24 AM   #8
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
You will also need an AT cooler for your transmission. With the added hp, the AT can get pretty hot on the track. Getting a larger radiator will also help cool down the AT and overall temps.
Tye300 is offline   Reply With Quote
Old 05-27-2015, 09:20 AM   #9
Byrd
Really? I've only heard of needing bigger injectors for turbos
Old 05-27-2015, 09:21 AM   #10
Byrd
Do you think a engine oil cooler and mishimoto radiator / hose / caps will be cool enough for the AT?
Old 05-27-2015, 09:41 AM   #11
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
I don't think you know what you're really getting into or for what reason you're putting parts on your car.
For brakes, you're spending too much money for what you're going to do. Get some good pads, stainless steel lines, and fluid, then call it a day. You don't need slotted/drilled rotors.
You need a separate cooler for the transmission. The stock radiator is pretty sufficient for cooling itself.
Injectors are needed if you do run e85, otherwise, they will max out with tuning and you'll leave a chunk of gains on the table.
You'll also want catch cans and a check valve on the PCV side if you're running any kind of boost.
Just simply getting a supercharger and hoping for the best is not the right way to do it. You need the proper supporting mods:
engine oil cooler, catch cans, a really good tune, internals depending on power levels, and be ready to replace an engine if it blows or a transmission if it goes out.
The Jackson kit is really solid for a daily driver and occasional track user. Stays pretty cool, and gives a nice bump in power. If you don't drive like a bat out of hell everywhere, I'm sure your engine can stay pretty reliable with it too, but the tune is the most important part of this along with a proper install.
2016 Camaro SS is offline   Reply With Quote
Old 05-27-2015, 10:10 AM   #12
Byrd
Thanks a lot man. I know a little of what I'm getting into but I have only started this project two months ago and it is my first car project. I'm confused on my AT and what I need to do to keep it cool with a Jrsc. I get different answers everywhere I go and everybody I ask....
Old 05-27-2015, 10:33 AM   #13
gramicci101
Off Topic
You'll have four separate puddles of liquid that would all benefit from having their own cooler.
1. The engine coolant, which runs through the car's radiator. The OEM radiator is pretty nice, but you could upgrade if you wanted to. Use Subaru Blue coolant.
2. The engine oil, which doesn't have a cooler normally. This is where a JR, Perrin, or any other oil cooler would be beneficial.
3. The supercharger oil, completely separate from the engine oil. A number of kits don't have supercharger oil coolers; some do. If you're tracking your car, it helps prolong the life of your supercharger.
4. The automatic transmission fluid. Running a supercharged auto on the track is going to put some serious heat into your transmission fluid, beyond the transmission's ability to cool itself. An aftermarket cooler here would be very beneficial.
Old 05-27-2015, 10:54 AM   #14
raven1231
GET A 6 SPD! oh...wait never mind I guess I'm in the wrong thread.
VORTECH SUPERCHARGER KITS!! READY TO SHIP F-T Forced Induction 4 12-03-2013 01:00 AM
>>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! Circuit Motorsports Forced Induction 91 10-24-2013 12:07 PM
Evasive Breaks 405WHP and 306TQ on HKS Supercharger and getting ready for Pikes Peak! Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 34 09-05-2013 01:09 AM
supercharger ready this year for FR-S? carbonBLUE Engine, Exhaust, Transmission 11 04-04-2012 02:56 PM
