Old 05-22-2015, 11:43 PM   #15
Scaldy
Scaldy's Avatar
Drives: 2013 red FR-S mt
Originally Posted by OnionTou View Post
I'm planning on running a 18x9.5 +45 squared with 255/35/18 setup with TEIN coilovers. (and even the same car color and wheel color)
I see you are running coilovers, did you need spacers or anything to make it work?
If you are not sure if you have spacers, can you take a picture from where the wheel meets up with the brake rotors? a little on the side looking where the wheel and the brake rotors meet.
Can you please send me pictures of how the wheels are with the body? (are they a little in, flush with the body)
They are pretty flush with the body, just a little inward. No spacers needed IMO.
Originally Posted by JellyForSale View Post
Been looking for rims and think I've found a perfect set for an FRS with TRD lowering springs. 18x8 seems to be the winner to me, I only have one question...
Are ANY of the Raijin colorways finished or coated? I live in the Northeast of USA and dont want another unfinished or uncoated rim. The corrosion and upkeep is too much for me daily this car if the rims cloud up every week
I believe the grey and black rims are finished/ coated, the polished set might not be.
Scaldy is offline   Reply With Quote
Old 05-26-2015, 12:41 AM   #16
DCStorm
DCStorm's Avatar
Drives: 2013 FR-S (RIP), 2017 Toyota 86
I'm looking into getting some enkei's 18x9.5 +45 all around and was worried about inner clearance issues. I'm glad I found this thread. So do you guys think I'll be fine? I'll be running them with 235/40/18 tires so they may stretch a tad
DCStorm is offline   Reply With Quote
Old 05-26-2015, 11:40 PM   #17
DCStorm
DCStorm's Avatar
Bump for answers!
Old 05-27-2015, 12:00 AM   #18
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by DCStorm View Post
Bump for answers!
You would need coilovers or they will hit the strut i'm about 98% sure.
Old 05-27-2015, 04:22 PM   #19
DCStorm
DCStorm's Avatar
Thanks, I'm running BC BR coilovers. I really want these wheels so I'm hoping it's fine
Old 12-07-2015, 01:54 AM   #20
x18999
Enkei Raijin 18x9.5 +45 with 255/35/18 Bridgestone Potenza S04 tires lowered on ST coilovers.
x18999 is offline   Reply With Quote
Old 12-09-2015, 10:52 AM   #21
sweetspeed
sweetspeed's Avatar
Drives: 2014 Raven Black FR-S
Lowering Amount
Are you lowered about 1.5 inches or so from the looks of it? Looks pretty sweet...
sweetspeed is offline   Reply With Quote
Old 12-10-2015, 12:07 AM   #22
x18999
Not sure about the lowering amount, but likely close to 1.5" drop.
It rubs a little bit at full lock on, so I'll try raising 1/4" to see if it helps.
Otherwise, no issues.
Old 12-17-2015, 03:59 PM   #23
phongtphan21
Drives: 2013 Fr-s
Which camber kit do you guys use? I've been trying to research a few but I havent find any that caught my attention, Im also thinking of purchasing Godspeed coilovers or KW v1. Thanks in advance!
phongtphan21 is offline   Reply With Quote
Old 12-26-2015, 08:14 PM   #24
StinkyLinky8
Drives: Subaru BRZ Limited
18x9.5 All Around
Are coilovers a must to run these wheels on the BRZ? I'm considering purchasing a set of Eibach Sportline Spings when purchasing these wheels. I'm still mulling over tire sizes but I have so many other questions I need to find answers to first.
StinkyLinky8 is offline   Reply With Quote
Old 12-26-2015, 08:18 PM   #25
swarb
Won't fit. Offsets too high.
Old 12-31-2015, 12:43 PM   #26
StinkyLinky8
As in they wont fit with the Eibach springs, or wont fit if i go with coil overs?
Old 12-31-2015, 01:08 PM   #27
swarb
Won't fit with springs unless you add 8-10mm+ of spacers. 8-10mm spacers won't fit on stock studs, so you need to get extended lugs or bolt on spacers.
It will fit with coilovers.
Old 01-11-2016, 03:10 PM   #28
x18999
Any spacers would make the wheel poke out of the fender which would cause rubbing on the fender and look terrible.
Wheel Directory: Enkei NT-03M 18x9.5 +40 Touge Factory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 140 12-08-2021 12:15 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Wheel Directory: Enkei Raijin 18x8.0 +45 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 03-30-2018 11:37 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 SWPBRZ415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 62 11-28-2016 03:51 PM
Wheel Directory: Enkei Raijin 18x8.0 +40 / 18x9.5 +45 seanmc69 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 07-08-2013 12:38 PM
